DIY CNC router build
  • shpatb
  • shpatb's Avatar Topic Author
  • Premium Member
  • Premium Member
20 Dec 2020 07:18 #192531 by shpatb
DIY CNC router build was created by shpatb
Starting a new project after some deep financial crisis. :laugh:
parts
hgr 20 on Y with 16mm ballscrew
dual hgr 15 on X with 16mm ballsrew
nema 23 2Nm with dm542 drives
steel structure with 10x6cm and 8x8cm with 3mm wall thickness.
will try to upload pics as i progress
regards ,
Shpat
  • Moderator
  • Moderator
20 Dec 2020 07:51 #192538 by tommylight
Replied by tommylight on topic DIY CNC router build
Santa was nice ! :)
The following user(s) said Thank You: shpatb
  • shpatb
  • Premium Member
  • Premium Member
20 Dec 2020 14:44 #192572 by shpatb
Replied by shpatb on topic DIY CNC router build
from 3 pm to 9 nonstop work , rested for like 5mins to stay hydrated
happy with results :woohoo:
ivan torrent and mig welding is good sound to hear ..:laugh: :laugh:
stay tuneDD!!
  • Moderator
  • Moderator
20 Dec 2020 15:29 #192579 by tommylight
Looking nice !
And Ivan Torrent is definitely good for work, but i do some Mick Gordon Doom Eternal when i have to pull 16 hour shifts. :)
  • shpatb
  • Premium Member
  • Premium Member
21 Dec 2020 17:08 - 24 Dec 2020 19:24 #192743 by shpatb
Mounted Y rails today , took a lot of time because i did it all alone, measure , drill , tap , measure ...repeat....
going to mount the gantry of some 3mm thick L i made of some tube , then bolt it with m8 Hex screws, with the 4mm steel sheet.
more to come on future days..busy with education and work..i want it moving as fast as possible ..waited too long for parts :silly:
Mounted side panels for X axis mount,
due to a mistake a made on cad i had to re-cut on my plasma table and fix it...
Took like 5-6 hours , broke 2 drill bits and one counter bolt...
I was at one state of leaving it but then a friend showed and offered a cigarette and i kept going...
came out pretty nice :)
tomorrow i would have completed my X axis mount but my mig welder broke , and there is a mess on that electrician shop i send to fix it...
will try to upload more pics as i complete the build ..
NOTE : I AM GOING TO UPLOAD ALL FUTURE PROGRESS ON THIS MESSAGE BECAUSE THERE IS A WIERD BUG GOING ON THAT WONT ALLOW ME TO ADD OTHER REPLIES ..
Last edit: 24 Dec 2020 19:24 by shpatb.
  • Moderator
  • Moderator
25 Dec 2020 14:53 #193191 by tommylight
I can reply here, testing the OP can not post on this topic for some reason.
  • Moderator
  • Moderator
25 Dec 2020 14:54 #193192 by tommylight
Topic can be moderated.
  • shpatb
  • Premium Member
  • Premium Member
25 Dec 2020 16:46 - 25 Dec 2020 16:53 #193198 by shpatb
puzzle is starting to get shape :side:
got this box from local electronics store its ip 65 rated so its going to be good for dust to be held out of the electronics ...
more to come...
Last edit: 25 Dec 2020 16:53 by shpatb.
  • Moderator
  • Moderator
25 Dec 2020 17:18 #193200 by tommylight
500x400x190mm ?
I used 400x300x190 on the last builds, it got tight !
Nice :)
  • shpatb
  • Premium Member
  • Premium Member
25 Dec 2020 17:39 #193202 by shpatb
yes , for couple of euros its not worth the pain on ur head it gives to mount the electronics ..
the wider the better they say :DD
Time to create page: 0.145 seconds
