Arduino IO Expansion
3 years 4 weeks ago #282287 by AlexMagToast
Replied by AlexMagToast on topic Arduino IO Expansion
Sorry, i am really busy lately.
Please check the latest Update on Github. I believe it works now as intended.
3 years 3 weeks ago #282316 by AlexMagToast
I have now uploaded a couple of Videos where the functionality and setup is explained. This one showcases the use of Encoders and Joysticks. @COFHAL, maybe this helps?
The following user(s) said Thank You: besriworld, COFHAL
2 years 10 months ago #287201 by mehdidadash
Replied by mehdidadash on topic Arduino IO Expansion
hi
thanks for great job.
is it possible to read data from i2c modules like HX711 using this?
2 years 10 months ago #287226 by AlexMagToast
That is a great idea! I'd like to implement it for you.
It will take some time unfortunately, i am realy busy right now, but i'l let you know when it's done.
Can you describe what kind of usecase you have in mind and how you'd like to use the data you get from the HX711?
I guess we need a tare funktion and a varriable to calculate a weight?
The following user(s) said Thank You: tommylight, mehdidadash
2 years 10 months ago #287495 by mehdidadash
Thank you.
I want to calculate brake torque of a wire under torsion and bending
There are three steppers that bend and rotate the wire and i should measure the torque at the same time.
2 years 10 months ago #287499 by AlexMagToast
Although i have no clue, how you want to build this using LinuxCNC, i can provide you a Halpin, which displays the current HX711 reading as Number. I guess minium and Maximum readings could be provided too. I'll update you later.
The following user(s) said Thank You: mehdidadash
Time to create page: 0.551 seconds
