- Thank you received: 37
EtherCAT RC Servo Motor & PWM Output Interface Board
- emresensoy
- Topic Author
1 year 2 months ago #333607
by emresensoy
EtherCAT RC Servo Motor & PWM Output Interface Board was created by emresensoy
image missing https://assets.zyrosite.com/cdn-cgi/image/format=auto,w=768,h=694,fit=crop,trim=22.833684210526318;0;22.833684210526318;0/A1aKgerO5wc88Nkj/ethercat_rc_servo_pwm_interface-YZ9jRW6pjLHKzJ51.jpg– ETHERCAT RC SERVO MOTOR INTERFACE
– 4x RC SERVO MOTOR CAN BE CONNECTED SAME TIME
– 24VDC SUPPLY
www.egerobotics.com/ethercat-pwm-rc-servo-interface
– 24VDC SUPPLY
The following user(s) said Thank You: tommylight, Hakan
1 year 2 months ago #333628
Replied by tommylight on topic EtherCAT RC Servo Motor & PWM Output Interface Board
No triple posting.
Two posts with the same contents were deleted.
Thank you.
Thank you.
- emresensoy
- Topic Author
1 year 2 months ago - 1 year 2 months ago #333633
by emresensoy
Replied by emresensoy on topic EtherCAT RC Servo Motor & PWM Output Interface Board
there was no "same content"
every 3 boards are different
Last edit: 1 year 2 months ago by emresensoy.
1 year 2 months ago #333636
Sorry, can you please upload them again.
And what did i miss?
Again, i am really sorry for the mess, they did seem the same form a quick glance and the tittles were very similar.
Oh cr@P!there was no "same content"
- Hakan
- Thank you received: 454
1 year 2 months ago #333662
by Hakan
Replied by Hakan on topic EtherCAT RC Servo Motor & PWM Output Interface Board
Where do you see this board being used?
Haven't seen much use for RC servos in linuxcnc.
Is it in robotics maybe?
- emresensoy
- Topic Author
1 year 2 months ago #333676
by emresensoy
I don't actually know where it's used. However, this board essentially has open-collector PWM outputs. It could be used in PWM-controlled proportional valves, etc., and other components.
As you mentioned, an RC servo motor could offer a fast way to mechanically implement LinuxCNC's powerful robotic infrastructure.
Time to create page: 0.306 seconds
