CAM232 - 2.5 Axis CAM Software (First 2 Code Free, than 1$ for each)
  • emresensoy
  • Topic Author
  • Senior Member
  • Senior Member
6 months 2 weeks ago #345709 by emresensoy
  We developed a web-based, free G-Code generator for CNC users.
  Features:
  - 13 machining operations (pocket, contour, drilling, slot, counterbore, chamfer and more)
  - Auto cutting parameter suggestion based on material & tool
  - 3D toolpath simulation with interactive viewer
  - Estimated machining time calculation
  - Mobile ready (PWA) - works on your phone
  - 2 free G-Codes per day
  Try it now in your browser: cam232.com/cam.html
  #CNC #CAM #GCode #Manufacturing #Machining #CNCMachining #Industry40 #EgeRobotics #CAM232
6 months 2 weeks ago #345710 by tommylight
Had a quick look, seems OK.
It says 5 gcodes there, and then 1$ for every gcode.
  • emresensoy
  • Topic Author
  • Senior Member
  • Senior Member
6 months 2 weeks ago #345711 by emresensoy
I made discount :D
6 months 2 weeks ago #345713 by MaHa
While reaching the limit before generating gcode, just had a look at the operation options. Missing essential selection for ucs, and in general a preamble to be set. It seems corner radius is missing for pocket and contour, to have smooth direction change, and desired cornerradius. Stepover as percentage of the cutter diameter is more preferable than fixed value. The contour operations have no rough dimension input? Zig zag facing, is it using stepover? And the drilling operations, eg grid drill have no selection for cycle, retract, clear z (G98)
As i was not able to test for free, this is just from looking at the interface.
  • emresensoy
  • Topic Author
  • Senior Member
  • Senior Member
6 months 2 weeks ago #345714 by emresensoy
Thank you for your valuable feedback; I will look into each and every one of it.
  • emresensoy
  • Topic Author
  • Senior Member
  • Senior Member
6 months 2 weeks ago #345719 by emresensoy
all done, thanks
  • emresensoy
  • Topic Author
  • Senior Member
  • Senior Member
6 months 2 weeks ago #345720 by emresensoy
all done, thanks
  • emresensoy
  • Topic Author
  • Senior Member
  • Senior Member
6 months 1 week ago - 6 months 1 week ago #345886 by emresensoy
A 1-month free Pro membership will be automatically added to any account upon first login.
If you experience any problems, please write here.
Last edit: 6 months 1 week ago by emresensoy.
Time to create page: 0.066 seconds
