o codes and grbl
8 years 7 months ago #107147 by agarthetiger
I've got a Sienci Mill One which runs grbl on an Arduino Uno. I know grbl only supports a sub-set of g-codes and am wondering if LinuxCNC would do any post-processing of o codes such that I could write 'g-code' using O codes and have a .ngc output file generated which would be valid grbl?
I'm starting to write g-code by hand to learn what's going on with my mill, and am hoping there is some way to write concise g-code (using subroutines etc) which will still convert to valid grbl. Will LinuxCNC (or any software) be able to do this?
8 years 7 months ago #107210 by andypugh
Replied by andypugh on topic o codes and grbl
LinuxCNC does exactly the same job as GRBL. So it won't be able to help.
LinuxCNC is a consumer of G-code, not a producer of it.
The following user(s) said Thank You: agarthetiger
7 years 9 months ago #125353 by roycegb
Replied by roycegb on topic o codes and grbl
I have the same question. I have loads of standard routines that I wrote in LinuxCNC GCode. I would like to utilize these on my GRBL machine. They include named variables and flow control codes, particularly o sub and o while. I would like to find a preprocessor that would convert this compact, CNCLinux GCode to the expanded code fo the GRBL subset.
I do most of my designs directly in GCode using these routines. I find the overall code very compact and readable.
7 years 9 months ago #125380 by andypugh
sai (The stand alone interpreter) might be part of the answer.
I am not at a LinuxCNC machine at the moment. Does the command "sai" do anything?
7 years 9 months ago #125416 by roycegb
SAI, good idea, but the output didn't look very useful. Further, it seemed to ignored literal parameters, o while and o sub. I didn't get any syntax errors when I processed the test files so it accepted everything just didn't make it to the output file.
7 years 9 months ago #125419 by andypugh
I was thinking that the output could either be converted my simple find-and-replace or the file itself could be modified to output simple G codes.
Time to create page: 0.069 seconds
