M3 SOURCE CODE
19 Nov 2018 19:02 #121016
by COlger81
M3 SOURCE CODE was created by COlger81
Can someone point me to the source code location for the M3 routine?
20 Nov 2018 14:27 #121059
Replied by andypugh on topic M3 SOURCE CODE
If only it was so simple....
github.com/LinuxCNC/linuxcnc/blob/2.7/sr...erp_convert.cc#L3084
calls
github.com/LinuxCNC/linuxcnc/blob/7fb914...interp_queue.cc#L154
Then this puts the spindle start message onto the motion queue
github.com/LinuxCNC/linuxcnc/blob/349512...sk/emccanon.cc#L1788
Then to here:
github.com/LinuxCNC/linuxcnc/blob/349512...emctaskmain.cc#L1988
And so on, through motion, task, NML into the realtime layers.
The simplest way to find it is probably to look at the multispindle patch, as that makes it fairly clear which files changed:
github.com/LinuxCNC/linuxcnc/commit/e3ca...4d855e13c1771dcc9f85
The final output is where the HAL pins are written here:
github.com/LinuxCNC/linuxcnc/blob/master...tion/control.c#L1860
calls
Then to here:
20 Nov 2018 16:54 #121072
by COlger81
Replied by COlger81 on topic M3 SOURCE CODE
I realized that was not a path i want to go down. I'm setting up spindle orient and i'm pretty close. I think the missing piece is where to place the Mux2 out. I have attached my configs if you can take a look.
# This config file was created 2017-11-26 08:54:27.459061 by the update_ini script
# The original config files may be found in the /home/fadal/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.old directory
# Generated by PNCconf at Mon Nov 20 15:07:44 2017
# overwritten when you run PNCconf again
[EMC]
# The version string for this INI file.
VERSION = 1.1
MACHINE = my_LinuxCNC_machine
DEBUG = 0
[DISPLAY]
DISPLAY = gmoccapy
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/fadal/linuxcnc/nc_files
INCREMENTS = .01in .001in .0001in
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.016670
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
ORIENT_OFFSET = 0
#REMAP=M6 modalgroup=6 ngc=toolchange
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[HAL]
HALUI = halui
HALFILE = my_LinuxCNC_machine.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
MDI_COMMAND = 1
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 0.10
MAX_LINEAR_VELOCITY = 8.3333
NO_FORCE_HOMING = 0
[EMCIO]
EMCIO = io
CYCLE_TIME = .10
TOOL_TABLE = tool.tbl
TOOL_CHANGE_QUILL_UP = 1
RANDOM_TOOLCHANGER = 0
# Axis X
[KINS]
KINEMATICS = trivkins
#This is a best-guess at the number of joints, it should be checked
JOINTS = 3
[AXIS_X]
HOME = 0.0
MIN_LIMIT = -15.0
MAX_LIMIT = 15.0
MAX_VELOCITY = 8.3333
MAX_ACCELERATION = 40.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 1.0
MIN_FERROR = .05
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.00003
MAX_OUTPUT = 0.0
ENCODER_SCALE = -100000.0
OUTPUT_SCALE = -10.0
OUTPUT_MIN_LIMIT = -10.0
OUTPUT_MAX_LIMIT = 10.0
MIN_LIMIT = -15.0
MAX_LIMIT = 15.0
HOME_OFFSET = 0.1700
HOME_LATCH_VEL = .05
HOME_USE_INDEX = YES
HOME_SEQUENCE = 0
#BACKLASH = 0.0005
# Axis Y
[AXIS_Y]
HOME = 0.0
MIN_LIMIT = -8.0
MAX_LIMIT = 8.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 1
MIN_FERROR = 0.05
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.00003
MAX_OUTPUT = 0.0
MIN_LIMIT = -8.0
MAX_LIMIT = 8.0
HOME_OFFSET = 0.1000
HOME_SEQUENCE = 0
#BACKLASH = 0.001
# Axis Z
[AXIS_Z]
HOME = 0.0
MIN_LIMIT = -16.0
MAX_LIMIT = 4.0
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 1
MIN_FERROR = 0.05
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.00003
MAX_OUTPUT = 0.0
ENCODER_SCALE = 100000.0
OUTPUT_SCALE = 10.0
MIN_LIMIT = -16.0
MAX_LIMIT = 4.0
HOME_SEQUENCE = 0
#BACKLASH = 0.0003
# Spindle
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
# Spindle
[SPINDLE_9]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 7500.0
ENCODER_SCALE = 4000.0
#OUTPUT_SCALE = -7640
OUTPUT_SCALE = -7500
OUTPUT_MIN_LIMIT = -7500
OUTPUT_MAX_LIMIT = 7500
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 7500.0
# Generated by PNCconf at Mon Nov 20 15:07:45 2017
#---LINK TO PYTHON FILES-START---
loadusr python lube.py
loadusr python ATC.py
loadusr python axisselector.py
loadusr python pyautoguitest.py
loadusr python programresume.py
#---LINK TO PYTHON FILES-END---
#---CRITICAL-THREAD-COMPONENTS-START---
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip=10.10.10.10 config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=300xxx"
setp hm2_7i92.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s,pid.o
loadrt abs names=abs.spindle
loadrt lowpass names=lowpass.spindle
loadrt scale names=scale.spindle
#---CRITICAL-THREAD-COMPONENTS-END---
#---LOAD-THREAD-COMPONENTS-START---
loadrt matrix_kb config=8x8s
loadrt carousel pockets=21 encoding=index num_sense=1 dir=2
loadrt and2 count=1
loadrt mux4 count=1
loadrt ilowpass
loadrt toggle count=7
loadrt or2 count=2
loadrt gearchoice
loadrt orient
loadrt mux2 count=1
#---LOAD-THREAD-COMPONENTS-END---
#---CRITICAL-FUNCTIONS-START---
addf hm2_7i92.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf pid.o.do-pid-calcs servo-thread
addf scale.spindle servo-thread
addf abs.spindle servo-thread
addf lowpass.spindle servo-thread
#---CRITICAL-FUNCTIONS-END---
#---ADD-FUNCTIONS-START---
addf matrix_kb.0 servo-thread
addf carousel.0 servo-thread
addf and2.0 servo-thread
addf mux4.0 servo-thread
addf ilowpass.0 servo-thread
addf toggle.0 servo-thread
addf toggle.1 servo-thread
addf toggle.2 servo-thread
addf toggle.3 servo-thread
addf toggle.4 servo-thread
addf toggle.5 servo-thread
addf toggle.6 servo-thread
addf or2.0 servo-thread
addf or2.1 servo-thread
addf gearchoice.0 servo-thread
addf orient.0 servo-thread
addf mux2.0 servo-thread
#!!---KEEP-hm2_7i92.0.write-LAST-addf---!!
addf hm2_7i92.0.write servo-thread
#---ADD-FUNCTIONS-END---
#---ADD-PARAMETERS-START---
setp matrix_kb.0.negative-logic false
setp matrix_kb.0.key_rollover 2
setp mux4.0.in0 .000001
setp mux4.0.in1 .00001
setp mux4.0.in2 .0001
setp mux4.0.in3 .0
setp ilowpass.0.scale 100
setp ilowpass.0.gain 0.03
setp halui.rapid-override.count-enable true
setp halui.rapid-override.direct-value true
#setp gmoccapy.rapid.rapid-override.analog-enable true
#setp halui.rapid-override.counts 1
#setp halui.rapid-override.increase true
#setp halui.rapid-override.decrease true
#setp halui.rapid-override.scale .01
#---ADD-PARAMETERS-END---
#---START-OF-MESA-PNCCONFIGURATION---
# AXIS X
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
#net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# ---PWM Generator signals/setup---
setp hm2_7i92.0.7i77.0.1.analogout0-scalemax [JOINT_0]OUTPUT_SCALE
setp hm2_7i92.0.7i77.0.1.analogout0-minlim [JOINT_0]OUTPUT_MIN_LIMIT
setp hm2_7i92.0.7i77.0.1.analogout0-maxlim [JOINT_0]OUTPUT_MAX_LIMIT
net x-output => hm2_7i92.0.7i77.0.1.analogout0
net x-pos-cmd joint.0.motor-pos-cmd
net x-enable joint.0.amp-enable-out
# enable _all_ sserial pwmgens
net x-enable hm2_7i92.0.7i77.0.1.analogena
setp hm2_7i92.0.encoder.00.counter-mode 0
setp hm2_7i92.0.encoder.00.filter 1
setp hm2_7i92.0.encoder.00.index-invert 0
setp hm2_7i92.0.encoder.00.index-mask 0
setp hm2_7i92.0.encoder.00.index-mask-invert 0
setp hm2_7i92.0.encoder.00.scale [JOINT_0]ENCODER_SCALE
net x-pos-fb <= hm2_7i92.0.encoder.00.position
net x-vel-fb <= hm2_7i92.0.encoder.00.velocity
net x-pos-fb => joint.0.motor-pos-fb
net x-index-enable joint.0.index-enable <=> hm2_7i92.0.encoder.00.index-enable
net x-pos-rawcounts <= hm2_7i92.0.encoder.00.rawcounts
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [JOINT_1]P
setp pid.y.Igain [JOINT_1]I
setp pid.y.Dgain [JOINT_1]D
setp pid.y.bias [JOINT_1]BIAS
setp pid.y.FF0 [JOINT_1]FF0
setp pid.y.FF1 [JOINT_1]FF1
setp pid.y.FF2 [JOINT_1]FF2
setp pid.y.deadband [JOINT_1]DEADBAND
setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.y.error-previous-target true
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
#net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp hm2_7i92.0.7i77.0.1.analogout1-scalemax [JOINT_1]OUTPUT_SCALE
setp hm2_7i92.0.7i77.0.1.analogout1-minlim [JOINT_1]OUTPUT_MIN_LIMIT
setp hm2_7i92.0.7i77.0.1.analogout1-maxlim [JOINT_1]OUTPUT_MAX_LIMIT
net y-output => hm2_7i92.0.7i77.0.1.analogout1
net y-pos-cmd joint.1.motor-pos-cmd
net y-enable joint.1.amp-enable-out
setp hm2_7i92.0.encoder.01.counter-mode 0
setp hm2_7i92.0.encoder.01.filter 1
setp hm2_7i92.0.encoder.01.index-invert 0
setp hm2_7i92.0.encoder.01.index-mask 0
setp hm2_7i92.0.encoder.01.index-mask-invert 0
setp hm2_7i92.0.encoder.01.scale [JOINT_1]ENCODER_SCALE
net y-pos-fb <= hm2_7i92.0.encoder.01.position
net y-vel-fb <= hm2_7i92.0.encoder.01.velocity
net y-pos-fb => joint.1.motor-pos-fb
net y-index-enable joint.1.index-enable <=> hm2_7i92.0.encoder.01.index-enable
net y-pos-rawcounts <= hm2_7i92.0.encoder.01.rawcounts
net y-home-sw => joint.1.home-sw-in
net y-neg-limit => joint.1.neg-lim-sw-in
net y-pos-limit => joint.1.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [JOINT_2]P
setp pid.z.Igain [JOINT_2]I
setp pid.z.Dgain [JOINT_2]D
setp pid.z.bias [JOINT_2]BIAS
setp pid.z.FF0 [JOINT_2]FF0
setp pid.z.FF1 [JOINT_2]FF1
setp pid.z.FF2 [JOINT_2]FF2
setp pid.z.deadband [JOINT_2]DEADBAND
setp pid.z.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.z.error-previous-target true
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
#net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_7i92.0.7i77.0.1.analogout2-scalemax [JOINT_2]OUTPUT_SCALE
setp hm2_7i92.0.7i77.0.1.analogout2-minlim [JOINT_2]OUTPUT_MIN_LIMIT
setp hm2_7i92.0.7i77.0.1.analogout2-maxlim [JOINT_2]OUTPUT_MAX_LIMIT
net z-output => hm2_7i92.0.7i77.0.1.analogout2
net z-pos-cmd joint.2.motor-pos-cmd
net z-enable joint.2.amp-enable-out
setp hm2_7i92.0.encoder.02.counter-mode 0
setp hm2_7i92.0.encoder.02.filter 1
setp hm2_7i92.0.encoder.02.index-invert 0
setp hm2_7i92.0.encoder.02.index-mask 0
setp hm2_7i92.0.encoder.02.index-mask-invert 0
setp hm2_7i92.0.encoder.02.scale [JOINT_2]ENCODER_SCALE
net z-pos-fb <= hm2_7i92.0.encoder.02.position
net z-vel-fb <= hm2_7i92.0.encoder.02.velocity
net z-pos-fb => joint.2.motor-pos-fb
net z-index-enable joint.2.index-enable <=> hm2_7i92.0.encoder.02.index-enable
net z-pos-rawcounts <= hm2_7i92.0.encoder.02.rawcounts
net z-home-sw => joint.2.home-sw-in
net z-neg-limit => joint.2.neg-lim-sw-in
net z-pos-limit => joint.2.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output mux2.0.in0
#======orient-pid---start
setp pid.o.Pgain [SPINDLE_0]P
setp pid.o.Igain [SPINDLE_0]I
setp pid.o.Dgain [SPINDLE_0]D
setp pid.o.bias [SPINDLE_0]BIAS
setp pid.o.FF0 [SPINDLE_0]FF0
setp pid.o.FF1 [SPINDLE_0]FF1
setp pid.o.FF2 [SPINDLE_0]FF2
setp pid.o.deadband [SPINDLE_0]DEADBAND
setp pid.o.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.o.error-previous-target true
net spindle-index-enable <=> pid.o.index-enable
net orient-angle spindle.0.orient-angle orient.0.angle
net orient-mode spindle.0.orient-mode orient.0.mode
net spindle-orient spindle.0.orient orient.0.enable pid.o.enable mux2.0.sel
net spindle-in-pos orient.0.is-oriented spindle.0.is-oriented
net spindle-revs orient.0.position pid.o.feedback
net orient-command orient.0.command pid.o.command
net spindle-output2 pid.o.output mux2.0.in1
#======orient-pid---end
setp hm2_7i92.0.7i77.0.1.analogout4-scalemax [SPINDLE_9]OUTPUT_SCALE
setp hm2_7i92.0.7i77.0.1.analogout4-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT
setp hm2_7i92.0.7i77.0.1.analogout4-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT
net spindle-output => hm2_7i92.0.7i77.0.1.analogout4
#net spindle-enable => hm2_7i92.0.7i77.0.1.spinena
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm gearchoice.0.speed-command <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable gearchoice.0.spindle-on <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake gearchoice.0.brake-enable <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
#net spindle-input-index hm2_7i92.0.encoder.03.input-index
#net spindle-revs spindle.0.revs orient.0.position
sets spindle-at-speed true
#SPINDLE RPM TEST
setp scale.spindle.gain 58.84
setp lowpass.spindle.gain 1.00000
net spindle-vel-fb-rps => scale.spindle.in
net spindle-fb-rpm scale.spindle.out => abs.spindle.in
#net spindle-fb-rpm mux2.0.out => abs.spindle.in
net spindle-fb-rpm-abs abs.spindle.out => lowpass.spindle.in
net spindle-fb-rpm-abs-filtered lowpass.spindle.out
#SPINDLE RPM TEST
net spindle-enable spindle.0.on => hm2_7i92.0.7i72.0.2.output-22 hm2_7i92.0.7i72.0.2.output-23
#net spindle-ccw spindle.0.reverse => hm2_7i92.0.7i72.0.2.output-23 hm2_7i92.0.7i72.0.2.output-22
#ENCODER INFO
setp hm2_7i92.0.encoder.03.counter-mode 0
setp hm2_7i92.0.encoder.03.filter 1
setp hm2_7i92.0.encoder.03.index-invert 1
setp hm2_7i92.0.encoder.03.index-mask 0
setp hm2_7i92.0.encoder.03.index-mask-invert 0
setp hm2_7i92.0.encoder.03.scale [SPINDLE_9]ENCODER_SCALE
net spindle-revs <= hm2_7i92.0.encoder.03.position
net spindle-vel-fb-rps <= hm2_7i92.0.encoder.03.velocity
net spindle-index-enable <=> hm2_7i92.0.encoder.03.index-enable
#net spindle-index-enable <=> hm2_7i92.0.7i77.0.0.input-31
#---END-OF-MESA-PNCCONFIGURATION---
#---HALUI-SIGNALS-START---
net joint-select-a halui.axis.x.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net joint-select-b halui.axis.y.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net joint-select-c halui.axis.z.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
#---HALUI-SIGNALS-END---
#---COOLANT-CONTROL---START---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# --- COOLANT-FLOOD ---
net coolant-flood hm2_7i92.0.7i72.0.2.output-01
# --- COOLANT-MIST ---
net coolant-mist hm2_7i92.0.7i72.0.2.output-02
#net coolant-flood <= matrix_kb.0.key.r3c6
#net coolant-mist <= matrix_kb.0.key.r3c5
#---COOLANT-CONTROL---END---
#---OUTPUT-SIGNALS-START---
# --- POWER-DRAWBAR ---
net power-drawbar hm2_7i92.0.7i72.0.2.output-03
# --- SPINDLE AIR BLAST ---
net spindle-air-blast hm2_7i92.0.7i72.0.2.output-11
#---OUTPUT-SIGNALS-END---
#---MISCELLANEOUS-START---
# ---motion control signals---
net in-position lube.motion-lube <= motion.in-position => motion.atc-position
net machine-is-enabled <= motion.motion-enabled
net tool-out-from-gcode motion.digital-out-00 => ATC.from-gcode
net power-drawbar <= matrix_kb.0.key.r3c1
#---BEACON---NEEDS BULB!!
#net beacon-light hm2_7i92.0.7i72.0.2.output-21
#---MISCELLANEOUS-END---
#---MODE-SELECT-KEYBOARD-START---
net mode-jog matrix_kb.0.key.r6c3 => halui.mode.manual
net mode-auto matrix_kb.0.key.r6c6 => halui.mode.auto
net mode-manual matrix_kb.0.key.r6c5 => halui.mode.mdi
#---MODE-SELECT-KEYBOARD-END---
#---CAROUSEL-ATC-COMPONENT-PINS-START---
#net tool-prepare-loopback ATC.tool-prepare => iocontrol.0.tool-prepared
net tool-prep-number iocontrol.0.tool-prep-number => carousel.0.pocket-number
net tool-change iocontrol.0.tool-change => carousel.0.enable
net atc-tool-change-out iocontrol.0.tool-changed <= carousel.0.ready
net turret-sensor-pocket hm2_7i92.0.7i77.0.0.input-29 => carousel.0.sense-0 carousel.0.sense-1
net tool-number iocontrol.0.tool-number => carousel.0.init-position
net turret-motor-forpin hm2_7i92.0.7i72.0.2.output-09 ATC.turret-forward-out
net turret-motor-revpin hm2_7i92.0.7i72.0.2.output-10 ATC.turret-reverse-out
net turret-motor-fwd carousel.0.motor-fwd ATC.turret-forward-in
net turret-motor-rev carousel.0.motor-rev ATC.turret-reverse-in
net turret-active carousel.0.active ATC.turret-active
net carousel-homing-toggle motion.digital-out-03
net carousel-jog-fwd matrix_kb.0.key.r3c2 => carousel.0.jog-fwd
net carousel-jog-rev matrix_kb.0.key.r3c3 => carousel.0.jog-rev
#net tool-out-from-gcode motion.digital-out-00 => ATC.from-gcode
#---CAROUSEL-ATC-COMPONENT-PINS-END---
#---TURRET-SLIDE-PINS-START---
net turret-slide-in SO.atc-turslide-in => hm2_7i92.0.7i72.0.2.output-08
net turret-slide-out SO.atc-turslide-out => hm2_7i92.0.7i72.0.2.output-07
#---TURRET-SLIDE-PINS-END---
#----PINS---ORIENT SENSOR AND LOCK---START
#net orient-sensor SO.so-sen => hm2_7i92.0.7i77.0.0.input-31
#net orient-lock SO.so-or-lock => hm2_7i92.0.7i72.0.2.output-06
net orient-lock motion.digital-out-01 => hm2_7i92.0.7i72.0.2.output-06
#----PINS---ORIENT SENSOR AND LOCK---END
#----PINS---ESTOP---START
net estop-in iocontrol.0.emc-enable-in <= and2.0.out
net internal-estop and2.0.in1 <= iocontrol.0.user-enable-out
net remote-estop and2.0.in0 halui.estop.activate => hm2_7i92.0.7i77.0.0.input-20-not
net estop-in <= hm2_7i92.0.7i72.0.2.output-00
#net estop-in halui.machine.on
#----PINS---ESTOP---END
#----PINS---JOG PENDANT---START
net x-jog-select axis.x.jog-enable <= axisselect.x
net y-jog-select axis.y.jog-enable <= axisselect.y
net z-jog-select axis.z.jog-enable <= axisselect.z
#net a-jog-select axis.a.jog-enable <= hm2_7i92.0.7i77.0.0.input-03
net axis-sel-0 axisselect.one <= hm2_7i92.0.7i77.0.0.input-00
net axis-sel-1 axisselect.two <= hm2_7i92.0.7i77.0.0.input-01
net x100 hm2_7i92.0.7i77.0.0.input-03 => mux4.0.sel1
net x10 hm2_7i92.0.7i77.0.0.input-04 => mux4.0.sel0
net jogscale mux4.0.out => joint.0.jog-scale axis.x.jog-scale
net jogscale => joint.1.jog-scale axis.y.jog-scale
net jogscale => joint.2.jog-scale axis.z.jog-scale
#net jogscale =>joint.3.jog-scale axis.a.jog-scale
net mpg-out hm2_7i92.0.7i77.0.0.enc0.rawcounts => ilowpass.0.in
net jogcounts ilowpass.0.out => joint.0.jog-counts axis.x.jog-counts
net jogcounts => joint.1.jog-counts axis.y.jog-counts
net jogcounts => joint.2.jog-counts axis.z.jog-counts
#net jogcounts => joint.3.jog-counts axis.a.jog-counts
#----PINS---JOG PENDANT---END
#----PHYSICAL-MESA-PINS---MATRIX KEYBOARD---START---
net key_01 matrix_kb.0.row-00-out <= hm2_7i92.0.7i77.0.0.output-07
net key_02 matrix_kb.0.row-01-out <= hm2_7i92.0.7i77.0.0.output-00
net key_03 matrix_kb.0.row-02-out <= hm2_7i92.0.7i77.0.0.output-01
net key_04 matrix_kb.0.row-03-out <= hm2_7i92.0.7i77.0.0.output-02
net key_05 matrix_kb.0.row-04-out <= hm2_7i92.0.7i77.0.0.output-03
net key_06 matrix_kb.0.row-05-out <= hm2_7i92.0.7i77.0.0.output-04
net key_07 matrix_kb.0.row-06-out <= hm2_7i92.0.7i77.0.0.output-05
net key_08 matrix_kb.0.row-07-out <= hm2_7i92.0.7i77.0.0.output-06
net key_09 matrix_kb.0.col-00-in <= hm2_7i92.0.7i77.0.0.input-08
net key_10 matrix_kb.0.col-01-in <= hm2_7i92.0.7i77.0.0.input-09
net key_11 matrix_kb.0.col-02-in <= hm2_7i92.0.7i77.0.0.input-10
net key_12 matrix_kb.0.col-03-in <= hm2_7i92.0.7i77.0.0.input-11
net key_13 matrix_kb.0.col-04-in <= hm2_7i92.0.7i77.0.0.input-12
net key_14 matrix_kb.0.col-05-in <= hm2_7i92.0.7i77.0.0.input-13
net key_15 matrix_kb.0.col-06-in <= hm2_7i92.0.7i77.0.0.input-14
net key_16 matrix_kb.0.col-07-in <= hm2_7i92.0.7i77.0.0.input-15
#----PHYSICAL-MESA-PINS---MATRIX KEYBOARD---END---
#----KEYBOARD-LAYOUT-PYAUTOGUI---MATRIX KEYBOARD---START---
net keyboard-enter matrix_kb.0.key.r5c2 => pyautopins.enter
net keyboard-m matrix_kb.0.key.r0c2 => pyautopins.m
net keyboard-6 matrix_kb.0.key.r0c5 => pyautopins.6
net keyboard-t matrix_kb.0.key.r1c5 => pyautopins.t
net keyboard-1 matrix_kb.0.key.r4c4 => pyautopins.1
net keyboard-2 matrix_kb.0.key.r4c7 => pyautopins.2
net keyboard-3 matrix_kb.0.key.r4c6 => pyautopins.3
net keyboard-4 matrix_kb.0.key.r4c5 => pyautopins.4
net keyboard-5 matrix_kb.0.key.r0c6 => pyautopins.5
net keyboard-7 matrix_kb.0.key.r0c1 => pyautopins.7
net keyboard-8 matrix_kb.0.key.r4c1 => pyautopins.8
net keyboard-9 matrix_kb.0.key.r4c3 => pyautopins.9
net keyboard-0 matrix_kb.0.key.r4c0 => pyautopins.0
net keyboard-backspace matrix_kb.0.key.r5c4 => pyautopins.backspace
net keyboard-q matrix_kb.0.key.r5c7 => pyautopins.q
net keyboard-w matrix_kb.0.key.r5c6 => pyautopins.w
net keyboard-e matrix_kb.0.key.r5c5 => pyautopins.e
net keyboard-r matrix_kb.0.key.r1c6 => pyautopins.r
net keyboard-y matrix_kb.0.key.r1c1 => pyautopins.y
net keyboard-u matrix_kb.0.key.r1c3 => pyautopins.u
net keyboard-i matrix_kb.0.key.r5c1 => pyautopins.i
net keyboard-o matrix_kb.0.key.r5c3 => pyautopins.o
net keyboard-p matrix_kb.0.key.r5c0 => pyautopins.p
net keyboard-delete matrix_kb.0.key.r7c4 => pyautopins.delete
net keyboard-a matrix_kb.0.key.r7c7 => pyautopins.a
net keyboard-s matrix_kb.0.key.r7c6 => pyautopins.s
net keyboard-d matrix_kb.0.key.r7c5 => pyautopins.d
net keyboard-f matrix_kb.0.key.r1c4 => pyautopins.f
net keyboard-g matrix_kb.0.key.r1c7 => pyautopins.g
net keyboard-h matrix_kb.0.key.r1c0 => pyautopins.h
net keyboard-j matrix_kb.0.key.r1c2 => pyautopins.j
net keyboard-k matrix_kb.0.key.r7c1 => pyautopins.k
net keyboard-l matrix_kb.0.key.r7c3 => pyautopins.l
net keyboard-semicolon matrix_kb.0.key.r7c0 => pyautopins.semicolon
net keyboard-plus matrix_kb.0.key.r7c2 => pyautopins.plus
net keyboard-shiftleft matrix_kb.0.key.r2c4 => pyautopins.shiftleft
net keyboard-shiftright matrix_kb.0.key.r2c2 => pyautopins.shiftright
net keyboard-z matrix_kb.0.key.r2c7 => pyautopins.z
net keyboard-x matrix_kb.0.key.r2c6 => pyautopins.x
net keyboard-c matrix_kb.0.key.r2c5 => pyautopins.c
net keyboard-v matrix_kb.0.key.r0c4 => pyautopins.v
net keyboard-b matrix_kb.0.key.r0c7 => pyautopins.b
net keyboard-n matrix_kb.0.key.r0c0 => pyautopins.n
net keyboard-comma matrix_kb.0.key.r2c1 => pyautopins.comma
net keyboard-period matrix_kb.0.key.r2c3 => pyautopins.period
net keyboard-forwardslash matrix_kb.0.key.r2c0 => pyautopins.forwardslash
net keyboard-space matrix_kb.0.key.r0c3 => pyautopins.space
net keyboard-minus matrix_kb.0.key.r4c2 => pyautopins.minus
#----KEYBOARD-LAYOUT-PYAUTOGUI---MATRIX KEYBOARD---END---
#----PINS---TOGGLE COMPONENTS---START
# Flood Coolant control with one button
#net flood-toggle toggle.0.in <= matrix_kb.0.key.r3c6
#net flood-control toggle.0.out => hm2_7i92.0.7i72.0.2.output-01
# THRU SPINDLE COOLANT with one button
#net thru-spindle-toggle toggle.1.in <= matrix_kb.0.key.r3c5
#net thru-spindle-control toggle.1.out => hm2_7i92.0.7i72.0.2.output-02
# SPINDLE HIGH RANGE!! control with one button
#net spindle-high-toggle toggle.2.in <= matrix_kb.0.key.r1c0
#net spindle-high-control toggle.2.out => hm2_7i92.0.7i72.0.2.output-05
# KEYBOARD SLIDE HOLD!! control with one button
#net slide-hold-toggle toggle.6.in <= matrix_kb.0.key.r3c4
#net slide-hold-control toggle.6.out => motion.feed-hold
# SPINDLE ORIENTATION!! control with one button
#net spindle-orient-toggle toggle.3.in <= matrix_kb.0.key.r5c3
#net spindle-orient-control toggle.3.out => hm2_7i92.0.7i72.0.2.output-06
# SLIDE MOTOR!! control with one button
#net slide-motor-toggle toggle.4.in <= matrix_kb.0.key.r0c2
#net slide-motor-control toggle.4.out => hm2_7i92.0.7i72.0.2.output-07
# SLIDE IN!! control with one button
#net slide-in-toggle toggle.5.in <= matrix_kb.0.key.r0c0
#net slide-in-control toggle.5.out => hm2_7i92.0.7i72.0.2.output-08
# TURRET MOTOR ON!!---KEYBOARD KEY = TURRET CW---control with one button
#net turret-motor-toggle ATC.turret-toggle toggle.6.in <= matrix_kb.0.key.r3c2
#net turret-motor-control toggle.6.out => ATC.turret-status
#net turret-on ATC.turret-on => hm2_7i92.0.7i72.0.2.output-09
#----PINS---TOGGLE COMPONENTS---END
#---PROGRAM-RUN, OPTIONAL-STOP, BLOCK-DELETE, SINGLE-STEP, AND-PAUSE---START---
net program-run1 or2.0.in0 hm2_7i92.0.7i77.0.0.input-19
net program-run2 or2.0.in1 matrix_kb.0.key.r6c4
net program-runout or2.0.out halui.program.run
net program-pause1 or2.1.in0 hm2_7i92.0.7i77.0.0.input-18 progres.panbutton
net program-pause2 or2.1.in1 matrix_kb.0.key.r3c4 progres.matrixbutton
net program-pauseout or2.1.out halui.program.pause
net program-is-paused halui.program.is-paused progres.pausestatus
net program-resume progres.resume => halui.program.resume
net optional-stop-on hm2_7i92.0.7i77.0.0.input-06-not => halui.program.optional-stop.on
net optional-stop-off hm2_7i92.0.7i77.0.0.input-06 => halui.program.optional-stop.off
net block-delete-on hm2_7i92.0.7i77.0.0.input-07-not => halui.program.block-delete.on
net block-delete-off hm2_7i92.0.7i77.0.0.input-07 => halui.program.block-delete.off
net single-step matrix_kb.0.key.r6c1 => halui.program.step
#---PROGRAM-RUN,OPTIONAL-STOP,AND-PAUSE---END---
#---RAPID-OVERRIDE-SELECTOR-SWITCH---START---
net override-scale halui.rapid-override.scale rapidselect.scale-output
net override-value halui.rapid-override.value rapidselect.value
net rapid-sel-0 rapidselect.one <= hm2_7i92.0.7i77.0.0.input-21
net rapid-sel-1 rapidselect.two <= hm2_7i92.0.7i77.0.0.input-22
net rapid-sel-2 rapidselect.three <= hm2_7i92.0.7i77.0.0.input-23
net rapid-sel-inc rapidselect.increase halui.rapid-override.increase
net rapid-sel-dec rapidselect.decrease halui.rapid-override.decrease
#---SPINDLE-GEAR-CHOICE---START---
net high-gear gearchoice.0.high-gear hm2_7i92.0.7i72.0.2.output-05
#---SPINDLE-GEAR-CHOICE---END---
21 Nov 2018 12:57 #121118
At the momement mux2.0.out does not go anywhere, as that line is commented out.
Which means that neither speed nor orient commands will go to the spindle motor.
21 Nov 2018 13:10 #121119
by COlger81
Yes, i commented it out while trying to figure out what it's suppose to be tied to.
21 Nov 2018 13:14 #121120
by COlger81
With Mux2 out active, it was not moving the spindle on M19r0 command.
21 Nov 2018 14:24 #121124
You need to replace this line:With
But I don't see where gearchoice.0.out goes to. (Maybe you are not using gearchoice to modify the drive duty cycle according to high/low gear?)
net spindle-final mux2.0.out gearchoice.0.speed-command
21 Nov 2018 15:07 #121128
by COlger81
It's at the bottom of the hal file.
21 Nov 2018 15:13 #121129
by COlger81
It's a WYE/DELTA internal motor gear.
21 Nov 2018 15:20 #121130
That just selects a gear, what sets the spindle speed within the range?
Time to create page: 0.182 seconds
