M3 SOURCE CODE
21 Nov 2018 15:33 #121132
by COlger81
Replied by COlger81 on topic M3 SOURCE CODE
They're both 1:1 ratio. Motor internal.
21 Nov 2018 15:34 #121133
by COlger81
GEARCHOICE component parameter of max low 2500 handles everything i need.
21 Nov 2018 15:37 #121135
Replied by andypugh on topic M3 SOURCE CODE
Does the motor run at constant frequency? Or is there a VFD?
I assume you have a VFD or closed-loop spindle speed will never work!
21 Nov 2018 17:38 #121142
by COlger81
It's a Fadal with a Baldor drive.
21 Nov 2018 17:49 #121146
And how is the drive controlled?
(This is like squeezing blood out of a stone, I am trying to help here, can you try to be a bit more forthcoming with your answers?)
21 Nov 2018 18:05 #121148
by COlger81
Hah, sorry Andy. It's a Baldor VFD that receives +/-10v from 7i77 and passes through encoder signal to 7i77. Wye Delta motor has a quad encoder with index. The GEARCHOICE works as it should.
21 Nov 2018 18:13 #121150
Right, I think that
needs to be
Assuming that you do mean +/- 10V and not 0-10V (in which case the spindle-output needs to connect at the other side of abs.spindle)
#net spindle-fb-rpm mux2.0.out => abs.spindle.in
needs to be
net spindle-output mux2.0.out => abs.spindle.in
21 Nov 2018 19:14 #121156
by COlger81
That did not work. It raised a conflict with the following line;
net spindle-output <= pid.s.output mux2.0.in0
21 Nov 2018 19:16 #121157
by COlger81
How can i just remap M19? I can achieve the same thing by;
M3S50
WHEN SENSOR IS TRUE
M5
LOCK ORIENT
M3S50
WHEN SENSOR IS TRUE
M5
LOCK ORIENT
21 Nov 2018 19:22 #121158
by COlger81
The end goal is ATC. Getting pretty frustrated. Link to my other post which explains end goal.
forum.linuxcnc.org/10-advanced-configuration/35567-m6-remap-atc
Time to create page: 0.214 seconds
