M3 SOURCE CODE
21 Nov 2018 20:05 #121166
Ah, yes, sorry.
Create a complete new signal name for the lines with mux2.0.out and hm2_7i92.0.7i77.0.1.analogout4
(that's the link you need to make, mux2.0.out to analogout4)
Replied by andypugh on topic M3 SOURCE CODE
That did not work. It raised a conflict with the following line;
net spindle-output <= pid.s.output mux2.0.in0
Ah, yes, sorry.
21 Nov 2018 22:20 - 21 Nov 2018 22:21 #121180
by COlger81
Replied by COlger81 on topic M3 SOURCE CODE
Is it possible to feed MDI from python during an M6 routine without remapping?
forum.linuxcnc.org/10-advanced-configuration/35567-m6-remap-atc
Last edit: 21 Nov 2018 22:21 by COlger81.
21 Nov 2018 22:26 #121182
Yes, using the linuxcnc.command() interface.
linuxcnc.org/docs/2.7/html/config/python-interface.html
Though depending on what you want to do a pure G-code remap routine can often work well for a tool changer.
21 Nov 2018 22:45 #121183
by COlger81
The linuxcnc.command() interface is what i'm using with gmoccapy. M6 ignores all MDI commands from python though.
21 Nov 2018 22:52 #121184
by COlger81
All MDI commands are ignored.
import time
import linuxcnc
import sys
s = linuxcnc.stat()
c = linuxcnc.command()
SO = hal.component("SO")
ATC = hal.component("ATC")
motion = hal.component("motion")
motion.newpin("spindle-gear", hal.HAL_FLOAT, hal.HAL_IN)
ATC.newpin("active-tool", hal.HAL_S32, hal.HAL_IN)
ATC.newpin("turret-actual-count", hal.HAL_S32, hal.HAL_IN)
ATC.newpin("tool-prep-number", hal.HAL_S32, hal.HAL_IN)
ATC.newpin("turret-status", hal.HAL_BIT, hal.HAL_IN)
ATC.newpin("tool-change", hal.HAL_BIT, hal.HAL_IN)
ATC.newpin("turret-forward-in", hal.HAL_BIT, hal.HAL_IN)
ATC.newpin("turret-reverse-in", hal.HAL_BIT, hal.HAL_IN)
ATC.newpin("turret-active", hal.HAL_BIT, hal.HAL_IN)
ATC.newpin("turret-forward-out", hal.HAL_BIT, hal.HAL_OUT)
ATC.newpin("turret-reverse-out", hal.HAL_BIT, hal.HAL_OUT)
ATC.newpin("from-gcode", hal.HAL_BIT, hal.HAL_IN)
ATC.newpin("tool-changed", hal.HAL_BIT, hal.HAL_OUT)
ATC.newpin("tool-prepare", hal.HAL_BIT, hal.HAL_OUT)
ATC.newpin("carousel-homing", hal.HAL_BIT, hal.HAL_OUT)
ATC.newpin("turret-ready", hal.HAL_BIT, hal.HAL_IN)
ATC.newpin("turret-toggle", hal.HAL_BIT, hal.HAL_IN)
ATC.newpin("turret-on", hal.HAL_BIT, hal.HAL_OUT)
ATC.newpin("readyorientforward", hal.HAL_BIT, hal.HAL_OUT)
ATC.newpin("turret-sensor", hal.HAL_BIT, hal.HAL_IN)
ATC.newpin("turret-ready-stop", hal.HAL_BIT, hal.HAL_IN)
SO.newpin("so-atc-prepare", hal.HAL_BIT, hal.HAL_IN)
SO.newpin("so-atc-prepared", hal.HAL_BIT, hal.HAL_OUT)
SO.newpin("so-atc-active", hal.HAL_BIT, hal.HAL_IN)
SO.newpin("so-atc-readyorient", hal.HAL_BIT, hal.HAL_IN)
SO.newpin("so-atc-turslide", hal.HAL_BIT, hal.HAL_IN)
SO.newpin("so-atc-turslide-home", hal.HAL_BIT, hal.HAL_IN)
SO.newpin("so-sen", hal.HAL_BIT, hal.HAL_IN)
motion.newpin("atc-position", hal.HAL_BIT, hal.HAL_IN)
SO.newpin("so-stat-out", hal.HAL_BIT, hal.HAL_OUT)
SO.newpin("so-or-lock", hal.HAL_BIT, hal.HAL_OUT)
SO.newpin("atc-turslide-in", hal.HAL_BIT, hal.HAL_OUT)
SO.newpin("atc-turslide-out", hal.HAL_BIT, hal.HAL_OUT)
SO.ready()
ATC.ready()
try:
while 1:
def ok_for_atc():
s.poll()
return ATC['tool-change'] == 1 and motion['spindle-gear'] == 0 and motion['atc-position'] == 1
return round(ATC['turret-actual-count'] - ATC['active-tool']) >= 1 or round(ATC['turret-actual-count'] - ATC['active-tool']) <= -1
def ok_for_orient():
return SO['so-atc-readyorient'] == 1 and SO['so-sen'] == 0
def ok_for_turslide():
s.poll()
return not s.estop and s.enabled and s.homed and SO['so-atc-readyorient'] == 1 and SO['so-sen'] == 0 and SO['so-atc-turslide'] == 1 and SO['so-or-lock'] == 1 and motion['atc-position'] == 1
def ok_for_turslide_home():
s.poll()
return not s.estop and s.enabled and s.homed and SO['so-atc-readyorient'] == 1 and SO['so-sen'] == 0 and SO['so-atc-turslide-home'] == 1 and SO['so-or-lock'] == 1 and motion['atc-position'] == 1
def ok_for_turret():
s.poll()
return ATC['turret-ready'] == 1 and round(ATC['turret-actual-count'] - ATC['active-tool']) >= 1 or round(ATC['turret-actual-count'] - ATC['active-tool']) <= -1 #not s.estop and s.enabled and s.homed and and
def ok_for_turret_stop():
s.poll()
return ATC['turret-ready-stop'] == 1 and int(ATC['turret-actual-count'] - ATC['active-tool']) == 0 and ATC['turret-sensor'] == 1
def turret_forward():
s.poll()
return ATC['turret-forward-in'] == 1
def turret_reverse():
s.poll()
return ATC['turret-reverse-in'] == 1
if ATC['turret-forward-in'] == 1 and ATC['readyorientforward'] == 0:
c.mode(linuxcnc.MODE_MDI)
c.mdi("M3 S50")
ATC['readyorientforward'] = 1
if SO['so-sen'] == 0 and ATC['readyorientforward'] == 1:
c.mdi("M5")
SO['so-or-lock'] = 1
time.sleep(.1)
ATC['readyorientforward'] = 0
ATC['turret-forward-out'] = 1
if ATC['turret-active'] ==0:
time.sleep(.2)
ATC['turret-forward-out'] = 0
SO['so-or-lock'] = 0
time.sleep(.1)
if ATC['turret-reverse-in'] == 1:
ATC['turret-reverse-out'] = 1
time.sleep(.2)
ATC['turret-reverse-out'] = 0
#while turret_reverse():
#ATC['turret-forward-out'] = 1
#ATC['turret-reverse-out'] = 1
#if ATC['from-gcode'] == 1:
#ATC['tool-prepare'] = 1
#c.mdi("M65 P0")
#pass
#time.sleep(.2)
#SO['so-atc-readyorient'] = 1
#if ok_for_orient():
#c.mdi("m5")
#SO['so-or-lock'] = 1
#time.sleep(.1)
#SO['so-or-lock'] = 0
#time.sleep(.1)
#SO['so-atc-readyorient'] = 0
#ATC['turret-ready'] = 1
#if ok_for_turret():
#ATC['turret-on'] = 1
#time.sleep(.1)
#ATC['turret-ready'] = 0
#ATC['turret-ready-stop'] = 1
#if ok_for_turret_stop():
#ATC['turret-ready-stop'] = 0
#pass
#if ATC['turret-sensor'] == 1:
#time.sleep(.1)
#ATC['turret-on'] = 0
#c.wait_complete()
#time.sleep(.2)
#ATC['tool-prepared'] = 1
#time.sleep(.2)
#ATC['tool-changed'] = 1
except KeyboardInterrupt:
raise SystemExit
21 Nov 2018 23:18 #121187
Is that a HAL component or a remap? It looks possibly like a bit of both.
I suspect that MDI inside a HAL component won't work because the system is in auto mode and MDI only works when idle.
Inside a remap you _can_ use the canonical interface to move axes, there is an example here in this remapped lathe roughing cycle:
github.com/LinuxCNC/linuxcnc/blob/andypu...python/remap.py#L441
I think if you need to use G-code in the tool change it is simpler to do all the tool change in G-code. (G code can read HAL pins as long as they are connected to the G-code analog and digital inputs)
There is an example of an all-G-code tool change routine here:
github.com/LinuxCNC/linuxcnc/blob/master...hange/toolchange.ngc
21 Nov 2018 23:36 #121189
by COlger81
Round and round i go... I have gone the remap with g code route, the last tool upon shutdown won't load, etc. etc...... I have all of the pieces together, as far as i can execute every step individually without issue. The python code i posted is not a remap. I would love to just remap in G code but then either M6 doesn't execute or it doesn't load last tool on startup. Please show me a path that leads to success. Either i can issue MDI or canonical commands without remapping, or i have to remap.
21 Nov 2018 23:43 #121190
What happened to the idea of storing the tool in a persistent G-code parameter?
21 Nov 2018 23:45 - 21 Nov 2018 23:48 #121191
by COlger81
The last tool loads on startup just fine if i'm not remapping. As soon as i change INI and load remap from NGC then the tool does not load and M6 does not start tool change.
Last edit: 21 Nov 2018 23:48 by COlger81.
21 Nov 2018 23:47 #121192
by COlger81
Canonical commands sound great. Can you give me an example of how to rotate spindle at 50 rpm and how to move Z up to 4"?
Time to create page: 0.523 seconds
