Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
08 Feb 2017 16:52 #87585
OK, so the non-appearance of the smart-serial channels was due to the 5V power being shorted?
new2linux: Is the dmesg output the same now that the 5V is wired correctly? Or can you now see the smart-serial channels for the analogue section?
Replied by andypugh on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
The 7I77 analog section is powered by the 5V logic power
08 Feb 2017 21:02 - 09 Feb 2017 23:02 #87599
by new2linux
Replied by new2linux on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
This is the most recent changes to error, ini and hal files:
I have added a 24 v power supply, power going to TB2 at pin 1 (pos field power) and pin 8 ground.
The CR3 light, does light now!!, I have swapped encoder 0 & 1 "went to" encoder 2 & 3 located at TB3 & TB4; in addition to the associated DRV 0 & 1 "went to" DRV 2 & 3, with the hope, if there was something possibly just goofed up at the original settings. In addition the red CR16 (Field I/O fault) and CR15 does not blink, or come on at all.
*************************************error files***********************************************Many thanks for your help!
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.8
Machine configuration directory is '/home/emc/linuxcnc/configs/1st_LinuxCNC_Bridgeport'
Machine configuration file is '1st_LinuxCNC_Bridgeport.ini'
INIFILE=/home/emc/linuxcnc/configs/1st_LinuxCNC_Bridgeport/1st_LinuxCNC_Bridgeport.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./1st_LinuxCNC_Bridgeport.hal
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:04:04.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:04:04.0
config string '0 out'
Running HAL shutdown script
Killing task linuxcncsvr, PID=2425
hm2_5i25.0: dropping AnyIO board at 0000:04:04.0
hm2/hm2_5i25.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./1st_LinuxCNC_Bridgeport.hal:56: parameter or pin 'hm2_5i25.0.7i77.0.1.analogout2-scalemax' not found
2425
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0xb6f6e000
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.7-rt-rt (root@buildsrv) (gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04) ) #2 SMP PREEMPT RT Mon Sep 28 21:38:11 CDT 2015
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000008efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000008f000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001e60ffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001e610000-0x000000001e6fbfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000001e6fc000-0x000000001f597fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001f598000-0x000000001f59ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000001f5a0000-0x000000001f62cfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001f62d000-0x000000001f630fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000001f631000-0x000000001f6a9fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001f6aa000-0x000000001f6e7fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000001f6e8000-0x000000001f6ebfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001f6ec000-0x000000001f6fefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000001f6ff000-0x000000001f6fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001f700000-0x000000001fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fff80000-0x00000000ffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: emachines W3623/D945GCCRG1, BIOS CR94510J.15A.1007.2007.0216.1519 02/16/2007
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x1f700 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 base 01F800000 mask FFF800000 uncachable
[ 0.000000] 2 base 01F700000 mask FFFF00000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT configuration [0-7]: WB WC UC- UC WB WC UC- UC
[ 0.000000] original variable MTRRs
[ 0.000000] reg 0, base: 0GB, range: 512MB, type WB
[ 0.000000] reg 1, base: 504MB, range: 8MB, type UC
[ 0.000000] reg 2, base: 503MB, range: 1MB, type UC
[ 0.000000] total RAM covered: 503M
[ 0.000000] Found optimal setting for mtrr clean up
[ 0.000000] gran_size: 64K chunk_size: 16M num_reg: 3 lose cover RAM: 0G
[ 0.000000] New variable MTRRs
[ 0.000000] reg 1, base: 503MB, range: 1MB, type UC
[ 0.000000] reg 2, base: 504MB, range: 8MB, type UC
[ 0.000000] found SMP MP-table at [mem 0x000fe200-0x000fe20f] mapped at [c00fe200]
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] initial memory mapped: [mem 0x00000000-0x111fffff]
[ 0.000000] Base memory trampoline at [c008b000] 8b000 size 16384
[ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[ 0.000000] [mem 0x00000000-0x000fffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x1f200000-0x1f3fffff]
[ 0.000000] [mem 0x1f200000-0x1f3fffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x00100000-0x1e60ffff]
[ 0.000000] [mem 0x00100000-0x001fffff] page 4k
[ 0.000000] [mem 0x00200000-0x1e5fffff] page 2M
[ 0.000000] [mem 0x1e600000-0x1e60ffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x1e6fc000-0x1f1fffff]
[ 0.000000] [mem 0x1e6fc000-0x1e7fffff] page 4k
[ 0.000000] [mem 0x1e800000-0x1f1fffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x1f400000-0x1f597fff]
[ 0.000000] [mem 0x1f400000-0x1f597fff] page 4k
[ 0.000000] BRK [0x10cdb000, 0x10cdbfff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x1f5a0000-0x1f62cfff]
[ 0.000000] [mem 0x1f5a0000-0x1f62cfff] page 4k
[ 0.000000] BRK [0x10cdc000, 0x10cdcfff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x1f631000-0x1f6a9fff]
[ 0.000000] [mem 0x1f631000-0x1f6a9fff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x1f6e8000-0x1f6ebfff]
[ 0.000000] [mem 0x1f6e8000-0x1f6ebfff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x1f6ff000-0x1f6fffff]
[ 0.000000] [mem 0x1f6ff000-0x1f6fffff] page 4k
[ 0.000000] BRK [0x10cdd000, 0x10cddfff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x1ca14000-0x1e60ffff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000FE020 000014 (v00 GATEWA)
[ 0.000000] ACPI: RSDT 0x000000001F6FD038 000054 (v01 GATEWA SYSTEM 000003EF 01000013)
[ 0.000000] ACPI: FACP 0x000000001F6FC000 000074 (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: DSDT 0x000000001F6F7000 004172 (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: FACS 0x000000001F6AA000 000040
[ 0.000000] ACPI: APIC 0x000000001F6F6000 000078 (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: WDDT 0x000000001F6F5000 000040 (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: MCFG 0x000000001F6F4000 00003C (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: ASF! 0x000000001F6F3000 0000A6 (v32 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: HPET 0x000000001F6F2000 000038 (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: SLIC 0x000000001F6F1000 000176 (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: SSDT 0x000000001F6F0000 0001BC (v01 GATEWA CpuPm 000003EF MSFT 01000013)
[ 0.000000] ACPI: SSDT 0x000000001F6EF000 0001B7 (v01 GATEWA Cpu0Ist 000003EF MSFT 01000013)
[ 0.000000] ACPI: SSDT 0x000000001F6EE000 0001B7 (v01 GATEWA Cpu1Ist 000003EF MSFT 01000013)
[ 0.000000] ACPI: SSDT 0x000000001F6ED000 0001B7 (v01 GATEWA Cpu2Ist 000003EF MSFT 01000013)
[ 0.000000] ACPI: SSDT 0x000000001F6EC000 0001B7 (v01 GATEWA Cpu3Ist 000003EF MSFT 01000013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 503MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1f700000
[ 0.000000] low ram: 0 - 1f700000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] Normal [mem 0x0000000001000000-0x000000001f6fffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000008efff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x000000001e60ffff]
[ 0.000000] node 0: [mem 0x000000001e6fc000-0x000000001f597fff]
[ 0.000000] node 0: [mem 0x000000001f5a0000-0x000000001f62cfff]
[ 0.000000] node 0: [mem 0x000000001f631000-0x000000001f6a9fff]
[ 0.000000] node 0: [mem 0x000000001f6e8000-0x000000001f6ebfff]
[ 0.000000] node 0: [mem 0x000000001f6ff000-0x000000001f6fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000001f6fffff]
[ 0.000000] On node 0 totalpages: 128325
[ 0.000000] DMA zone: 40 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3982 pages, LIFO batch:0
[ 0.000000] Normal zone: 1218 pages used for memmap
[ 0.000000] Normal zone: 124343 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] Reserving Intel graphics stolen memory at 0x1f800000-0x1fffffff
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] smpboot: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] e820: [mem 0x20000000-0xfff7ffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 20 pages/cpu @df5dd000 s50144 r0 d31776 u81920
[ 0.000000] pcpu-alloc: s50144 r0 d31776 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 127067
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.1.7-rt-rt root=UUID=7f5dbdbc-c81e-4d4e-9f8c-40b2959fd243 ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 465028K/513300K available (7055K kernel code, 727K rwdata, 3020K rodata, 924K init, 848K bss, 48272K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff15000 - 0xfffff000 ( 936 kB)
[ 0.000000] pkmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xdff00000 - 0xffbfe000 ( 508 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdf700000 ( 503 MB)
[ 0.000000] .init : 0xd0a90000 - 0xd0b77000 ( 924 kB)
[ 0.000000] .data : 0xd06e42e8 - 0xd0a8ed80 (3754 kB)
[ 0.000000] .text : 0xd0000000 - 0xd06e42e8 (7056 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: HWalign=128, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS:2304 nr_irqs:456 16
[ 0.000000] CPU 0 irqstacks, hard=de836000 soft=de838000
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration failed
[ 0.000000] tsc: PIT calibration matches HPET. 3 loops
[ 0.000000] tsc: Detected 3191.977 MHz processor
[ 0.016018] Calibrating delay loop (skipped), value calculated using timer frequency.. 6383.95 BogoMIPS (lpj=12767908)
[ 0.016020] pid_max: default: 32768 minimum: 301
[ 0.016032] ACPI: Core revision 20150410
[ 0.025004] ACPI: All ACPI Tables successfully acquired
[ 0.025028] Security Framework initialized
[ 0.025052] AppArmor: AppArmor initialized
[ 0.025053] Yama: becoming mindful.
[ 0.025119] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.025122] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.025442] Initializing cgroup subsys blkio
[ 0.025446] Initializing cgroup subsys memory
[ 0.025458] Initializing cgroup subsys devices
[ 0.025461] Initializing cgroup subsys freezer
[ 0.025464] Initializing cgroup subsys net_cls
[ 0.025467] Initializing cgroup subsys perf_event
[ 0.025470] Initializing cgroup subsys net_prio
[ 0.025473] Initializing cgroup subsys hugetlb
[ 0.025513] CPU: Physical Processor ID: 0
[ 0.025514] CPU: Processor Core ID: 0
[ 0.025521] mce: CPU supports 4 MCE banks
[ 0.025533] CPU0: Thermal monitoring enabled (TM2)
[ 0.025537] process: using mwait in idle threads
[ 0.025547] Last level iTLB entries: 4KB 64, 2MB 64, 4MB 64
[ 0.025548] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 64, 1GB 0
[ 0.026288] Freeing SMP alternatives memory: 24K (d0b77000 - d0b7d000)
[ 0.028010] ftrace: allocating 29131 entries in 57 pages
[ 0.040158] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.040587] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.084000] smpboot: CPU0: Intel(R) Pentium(R) 4 CPU 3.20GHz (fam: 0f, model: 06, stepping: 05)
[ 0.084000] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.084000] ... version: 0
[ 0.084000] ... bit width: 40
[ 0.084000] ... generic registers: 18
[ 0.084000] ... value mask: 000000ffffffffff
[ 0.084000] ... max period: 0000007fffffffff
[ 0.084000] ... fixed-purpose events: 0
[ 0.084000] ... event mask: 000000000003ffff
[ 0.120115] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.136130] CPU 1 irqstacks, hard=de978000 soft=de97a000
[ 0.136133] x86: Booting SMP configuration:
[ 0.136136] .... node #0, CPUs: #1
[ 0.020000] Initializing CPU#1
[ 0.148070] x86: Booted up 1 node, 2 CPUs
[ 0.148080] smpboot: Total of 2 processors activated (12767.90 BogoMIPS)
[ 0.149858] devtmpfs: initialized
[ 0.149858] evm: security.selinux
[ 0.149858] evm: security.SMACK64
[ 0.149858] evm: security.SMACK64EXEC
[ 0.149858] evm: security.SMACK64TRANSMUTE
[ 0.149858] evm: security.SMACK64MMAP
[ 0.149858] evm: security.ima
[ 0.149858] evm: security.capability
[ 0.149858] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.152121] pinctrl core: initialized pinctrl subsystem
[ 0.152518] NET: Registered protocol family 16
[ 0.152877] EISA bus registered
[ 0.164027] cpuidle: using governor ladder
[ 0.176036] cpuidle: using governor menu
[ 0.176201] ACPI: bus type PCI registered
[ 0.176206] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.176354] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.176359] PCI: not using MMCONFIG
[ 0.179645] PCI: Using configuration type 1 for base access
[ 0.192507] ACPI: Added _OSI(Module Device)
[ 0.192512] ACPI: Added _OSI(Processor Device)
[ 0.192515] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.192518] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.197214] ACPI: Interpreter enabled
[ 0.197227] ACPI: (supports S0 S5)
[ 0.197230] ACPI: Using IOAPIC for interrupt routing
[ 0.197257] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.197924] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in ACPI motherboard resources
[ 0.197930] PCI: MMCONFIG for 0000 [bus00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000) (size reduced!)
[ 0.197932] PCI: Using MMCONFIG for extended config space
[ 0.197962] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.206615] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.206626] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.206635] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.207740] acpi PNP0A03:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.208037] PCI host bridge to bus 0000:00
[ 0.208043] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.208048] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.208052] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.208056] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.208059] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000effff window]
[ 0.208063] pci_bus 0000:00: root bus resource [mem 0xf8000000-0xfebfffff window]
[ 0.208067] pci_bus 0000:00: root bus resource [mem 0x20000000-0xf0000000 window]
[ 0.208084] pci 0000:00:00.0: [8086:2770] type 00 class 0x060000
[ 0.208266] pci 0000:00:02.0: [8086:2772] type 00 class 0x030000
[ 0.208283] pci 0000:00:02.0: reg 0x10: [mem 0x30100000-0x3017ffff]
[ 0.208293] pci 0000:00:02.0: reg 0x14: [io 0x20e0-0x20e7]
[ 0.208303] pci 0000:00:02.0: reg 0x18: [mem 0x20000000-0x2fffffff pref]
[ 0.208312] pci 0000:00:02.0: reg 0x1c: [mem 0x30180000-0x301bffff]
[ 0.208511] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[ 0.208535] pci 0000:00:1b.0: reg 0x10: [mem 0x301c0000-0x301c3fff 64bit]
[ 0.208625] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.208739] pci 0000:00:1b.0: System wakeup disabled by ACPI
[ 0.208830] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[ 0.208920] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.208999] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.209093] pci 0000:00:1c.2: [8086:27d4] type 01 class 0x060400
[ 0.209182] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.209260] pci 0000:00:1c.2: System wakeup disabled by ACPI
[ 0.209352] pci 0000:00:1c.3: [8086:27d6] type 01 class 0x060400
[ 0.209441] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.209520] pci 0000:00:1c.3: System wakeup disabled by ACPI
[ 0.209610] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[ 0.209662] pci 0000:00:1d.0: reg 0x20: [io 0x2080-0x209f]
[ 0.209791] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.209878] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[ 0.209930] pci 0000:00:1d.1: reg 0x20: [io 0x2060-0x207f]
[ 0.210058] pci 0000:00:1d.1: System wakeup disabled by ACPI
[ 0.210145] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[ 0.210197] pci 0000:00:1d.2: reg 0x20: [io 0x2040-0x205f]
[ 0.210324] pci 0000:00:1d.2: System wakeup disabled by ACPI
[ 0.210412] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[ 0.210463] pci 0000:00:1d.3: reg 0x20: [io 0x2020-0x203f]
[ 0.210591] pci 0000:00:1d.3: System wakeup disabled by ACPI
[ 0.210684] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[ 0.210708] pci 0000:00:1d.7: reg 0x10: [mem 0x301c4000-0x301c43ff]
[ 0.210806] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.210912] pci 0000:00:1d.7: System wakeup disabled by ACPI
[ 0.211005] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.211134] pci 0000:00:1e.0: System wakeup disabled by ACPI
[ 0.211225] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100
[ 0.211324] pci 0000:00:1f.0: can't claim BAR 13 [io 0x0400-0x047f]: address conflict with ACPI CPU throttle [io 0x0410-0x0415]
[ 0.211331] pci 0000:00:1f.0: quirk: [io 0x0500-0x053f] claimed by ICH6 GPIO
[ 0.211337] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0680 (mask 007f)
[ 0.211497] pci 0000:00:1f.1: [8086:27df] type 00 class 0x01018a
[ 0.211516] pci 0000:00:1f.1: reg 0x10: [io 0x0000-0x0007]
[ 0.211528] pci 0000:00:1f.1: reg 0x14: [io 0x0000-0x0003]
[ 0.211541] pci 0000:00:1f.1: reg 0x18: [io 0x0000-0x0007]
[ 0.211553] pci 0000:00:1f.1: reg 0x1c: [io 0x0000-0x0003]
[ 0.211565] pci 0000:00:1f.1: reg 0x20: [io 0x20b0-0x20bf]
[ 0.211590] pci 0000:00:1f.1: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.211593] pci 0000:00:1f.1: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.211597] pci 0000:00:1f.1: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.211600] pci 0000:00:1f.1: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.211746] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f
[ 0.211766] pci 0000:00:1f.2: reg 0x10: [io 0x20c8-0x20cf]
[ 0.211777] pci 0000:00:1f.2: reg 0x14: [io 0x20ec-0x20ef]
[ 0.211789] pci 0000:00:1f.2: reg 0x18: [io 0x20c0-0x20c7]
[ 0.211800] pci 0000:00:1f.2: reg 0x1c: [io 0x20e8-0x20eb]
[ 0.211811] pci 0000:00:1f.2: reg 0x20: [io 0x20a0-0x20af]
[ 0.211857] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.212016] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[ 0.212079] pci 0000:00:1f.3: reg 0x20: [io 0x2000-0x201f]
[ 0.212306] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.212393] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.212476] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.212577] pci 0000:04:04.0: [2718:5125] type 00 class 0x110000
[ 0.212596] pci 0000:04:04.0: reg 0x10: [mem 0x30010000-0x3001ffff]
[ 0.212754] pci 0000:04:05.0: [14f1:2f40] type 00 class 0x078000
[ 0.212776] pci 0000:04:05.0: reg 0x10: [mem 0x30000000-0x3000ffff]
[ 0.212789] pci 0000:04:05.0: reg 0x14: [io 0x1040-0x1047]
[ 0.212870] pci 0000:04:05.0: PME# supported from D3hot D3cold
[ 0.212980] pci 0000:04:08.0: [8086:1094] type 00 class 0x020000
[ 0.213002] pci 0000:04:08.0: reg 0x10: [mem 0x30020000-0x30020fff]
[ 0.213015] pci 0000:04:08.0: reg 0x14: [io 0x1000-0x103f]
[ 0.213096] pci 0000:04:08.0: supports D1 D2
[ 0.213100] pci 0000:04:08.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.213135] pci 0000:04:08.0: System wakeup disabled by ACPI
[ 0.213250] pci 0000:00:1e.0: PCI bridge to [bus 04] (subtractive decode)
[ 0.213257] pci 0000:00:1e.0: bridge window [io 0x1000-0x1fff]
[ 0.213263] pci 0000:00:1e.0: bridge window [mem 0x30000000-0x300fffff]
[ 0.213271] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.213275] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.213279] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.213283] pci 0000:00:1e.0: bridge window [mem 0x000e0000-0x000effff window] (subtractive decode)
[ 0.213287] pci 0000:00:1e.0: bridge window [mem 0xf8000000-0xfebfffff window] (subtractive decode)
[ 0.213290] pci 0000:00:1e.0: bridge window [mem 0x20000000-0xf0000000 window] (subtractive decode)
[ 0.213318] pci_bus 0000:00: on NUMA node 0
[ 0.213446] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.213568] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.213689] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 *9 10 11 12)
[ 0.213809] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.213927] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.214046] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.214168] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 *9 10 11 12)
[ 0.214288] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.215146] ACPI: Enabled 1 GPEs in block 00 to 1F
[ 0.216027] vgaarb: setting as boot device: PCI:0000:00:02.0
[ 0.216027] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.216030] vgaarb: loaded
[ 0.216033] vgaarb: bridge control possible 0000:00:02.0
[ 0.216570] SCSI subsystem initialized
[ 0.216612] libata version 3.00 loaded.
[ 0.216612] ACPI: bus type USB registered
[ 0.216612] usbcore: registered new interface driver usbfs
[ 0.216612] usbcore: registered new interface driver hub
[ 0.216612] usbcore: registered new device driver usb
[ 0.216612] PCI: Using ACPI for IRQ routing
[ 0.217865] PCI: pci_cache_line_size set to 64 bytes
[ 0.217934] e820: reserve RAM buffer [mem 0x0008f000-0x0008ffff]
[ 0.217939] e820: reserve RAM buffer [mem 0x1e610000-0x1fffffff]
[ 0.217943] e820: reserve RAM buffer [mem 0x1f598000-0x1fffffff]
[ 0.217946] e820: reserve RAM buffer [mem 0x1f62d000-0x1fffffff]
[ 0.217950] e820: reserve RAM buffer [mem 0x1f6aa000-0x1fffffff]
[ 0.217953] e820: reserve RAM buffer [mem 0x1f6ec000-0x1fffffff]
[ 0.217956] e820: reserve RAM buffer [mem 0x1f700000-0x1fffffff]
[ 0.218206] NetLabel: Initializing
[ 0.218209] NetLabel: domain hash size = 128
[ 0.218211] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.218231] NetLabel: unlabeled traffic allowed by default
[ 0.220121] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.220128] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.220136] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.222176] Switched to clocksource hpet
[ 0.241279] AppArmor: AppArmor Filesystem Enabled
[ 0.241422] pnp: PnP ACPI init
[ 0.241588] system 00:00: [mem 0xf0000000-0xf3ffffff] could not be reserved
[ 0.241595] system 00:00: [mem 0xfed13000-0xfed13fff] has been reserved
[ 0.241599] system 00:00: [mem 0xfed14000-0xfed17fff] has been reserved
[ 0.241603] system 00:00: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.241608] system 00:00: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.241612] system 00:00: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.241616] system 00:00: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.241620] system 00:00: [mem 0xfed45000-0xfed99fff] has been reserved
[ 0.241625] system 00:00: [mem 0x000c0000-0x000dffff] could not be reserved
[ 0.241629] system 00:00: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.241636] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.241947] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.242052] system 00:02: [io 0x0500-0x053f] has been reserved
[ 0.242058] system 00:02: [io 0x0400-0x047f] could not be reserved
[ 0.242063] system 00:02: [io 0x0680-0x06ff] has been reserved
[ 0.242067] system 00:02: [io 0x0770-0x077f] has been reserved
[ 0.242073] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.242454] pnp 00:03: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.242628] pnp 00:04: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.242917] pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.243081] pnp: PnP ACPI: found 6 devices
[ 0.243090] PnPBIOS: Disabled by ACPI PNP
[ 0.282048] clocksource acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.282075] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
[ 0.282083] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[ 0.282088] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[ 0.282100] pci 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 02] add_size 1000
[ 0.282105] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[ 0.282109] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff] to [bus 02] add_size 200000 add_align 100000
[ 0.282121] pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 03] add_size 1000
[ 0.282126] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[ 0.282130] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff] to [bus 03] add_size 200000 add_align 100000
[ 0.282148] pci 0000:00:1f.0: BAR 13: [io size 0x0080] has bogus alignment
[ 0.282155] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.282159] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.282163] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.282168] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.282171] pci 0000:00:1c.2: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.282175] pci 0000:00:1c.2: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.282180] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.282184] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.282187] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.282191] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.282195] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.282200] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.282204] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.282207] pci 0000:00:1c.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.282211] pci 0000:00:1c.2: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.282215] pci 0000:00:1c.2: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.282219] pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.282223] pci 0000:00:1c.3: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.282233] pci 0000:00:1c.0: BAR 14: assigned [mem 0xf8000000-0xf81fffff]
[ 0.282245] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf8200000-0xf83fffff 64bit pref]
[ 0.282252] pci 0000:00:1c.2: BAR 14: assigned [mem 0xf8400000-0xf85fffff]
[ 0.282261] pci 0000:00:1c.2: BAR 15: assigned [mem 0xf8600000-0xf87fffff 64bit pref]
[ 0.282267] pci 0000:00:1c.3: BAR 14: assigned [mem 0xf8800000-0xf89fffff]
[ 0.282275] pci 0000:00:1c.3: BAR 15: assigned [mem 0xf8a00000-0xf8bfffff 64bit pref]
[ 0.282282] pci 0000:00:1c.0: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.282288] pci 0000:00:1c.2: BAR 13: assigned [io 0x4000-0x4fff]
[ 0.282294] pci 0000:00:1c.3: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.282299] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.282304] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ 0.282311] pci 0000:00:1c.0: bridge window [mem 0xf8000000-0xf81fffff]
[ 0.282317] pci 0000:00:1c.0: bridge window [mem 0xf8200000-0xf83fffff 64bit pref]
[ 0.282325] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.282329] pci 0000:00:1c.2: bridge window [io 0x4000-0x4fff]
[ 0.282336] pci 0000:00:1c.2: bridge window [mem 0xf8400000-0xf85fffff]
[ 0.282342] pci 0000:00:1c.2: bridge window [mem 0xf8600000-0xf87fffff 64bit pref]
[ 0.282349] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.282354] pci 0000:00:1c.3: bridge window [io 0x5000-0x5fff]
[ 0.282360] pci 0000:00:1c.3: bridge window [mem 0xf8800000-0xf89fffff]
[ 0.282366] pci 0000:00:1c.3: bridge window [mem 0xf8a00000-0xf8bfffff 64bit pref]
[ 0.282374] pci 0000:00:1e.0: PCI bridge to [bus 04]
[ 0.282378] pci 0000:00:1e.0: bridge window [io 0x1000-0x1fff]
[ 0.282385] pci 0000:00:1e.0: bridge window [mem 0x30000000-0x300fffff]
[ 0.282397] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.282400] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.282404] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.282407] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000effff window]
[ 0.282411] pci_bus 0000:00: resource 8 [mem 0xf8000000-0xfebfffff window]
[ 0.282415] pci_bus 0000:00: resource 9 [mem 0x20000000-0xf0000000 window]
[ 0.282418] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.282422] pci_bus 0000:01: resource 1 [mem 0xf8000000-0xf81fffff]
[ 0.282425] pci_bus 0000:01: resource 2 [mem 0xf8200000-0xf83fffff 64bit pref]
[ 0.282429] pci_bus 0000:02: resource 0 [io 0x4000-0x4fff]
[ 0.282432] pci_bus 0000:02: resource 1 [mem 0xf8400000-0xf85fffff]
[ 0.282436] pci_bus 0000:02: resource 2 [mem 0xf8600000-0xf87fffff 64bit pref]
[ 0.282439] pci_bus 0000:03: resource 0 [io 0x5000-0x5fff]
[ 0.282443] pci_bus 0000:03: resource 1 [mem 0xf8800000-0xf89fffff]
[ 0.282446] pci_bus 0000:03: resource 2 [mem 0xf8a00000-0xf8bfffff 64bit pref]
[ 0.282450] pci_bus 0000:04: resource 0 [io 0x1000-0x1fff]
[ 0.282453] pci_bus 0000:04: resource 1 [mem 0x30000000-0x300fffff]
[ 0.282457] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7 window]
[ 0.282460] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff window]
[ 0.282464] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.282467] pci_bus 0000:04: resource 7 [mem 0x000e0000-0x000effff window]
[ 0.282471] pci_bus 0000:04: resource 8 [mem 0xf8000000-0xfebfffff window]
[ 0.282474] pci_bus 0000:04: resource 9 [mem 0x20000000-0xf0000000 window]
[ 0.282533] NET: Registered protocol family 2
[ 0.282850] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.282875] TCP bind hash table entries: 4096 (order: 4, 114688 bytes)
[ 0.282944] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.282975] UDP hash table entries: 256 (order: 2, 16384 bytes)
[ 0.282987] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[ 0.283079] NET: Registered protocol family 1
[ 0.283106] pci 0000:00:02.0: Video device with shadowed ROM
[ 0.285029] pci 0000:04:08.0: Firmware left e100 interrupts enabled; disabling
[ 0.285039] PCI: CLS 64 bytes, default 64
[ 0.285148] Trying to unpack rootfs image as initramfs...
[ 1.101573] Freeing initrd memory: 28656K (dca14000 - de610000)
[ 1.101874] microcode: CPU0 sig=0xf65, pf=0x4, revision=0x7
[ 1.101886] microcode: CPU1 sig=0xf65, pf=0x4, revision=0x7
[ 1.102011] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.102067] Scanning for low memory corruption every 60 seconds
[ 1.102608] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 1.102669] Initialise system trusted keyring
[ 1.102709] audit: initializing netlink subsys (disabled)
[ 1.102744] audit: type=2000 audit(1486585858.100:1): initialized
[ 1.103261] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.107488] zpool: loaded
[ 1.107494] zbud: loaded
[ 1.107638] VFS: Disk quotas dquot_6.6.0
[ 1.107735] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.108843] fuse init (API version 7.23)
[ 1.109182] Key type big_key registered
[ 1.109835] Key type asymmetric registered
[ 1.109843] Asymmetric key parser 'x509' registered
[ 1.109880] bounce: pool size: 64 pages
[ 1.109965] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 1.110043] io scheduler noop registered
[ 1.110050] io scheduler deadline registered
[ 1.110069] io scheduler cfq registered (default)
[ 1.111250] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.111290] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.111365] vesafb: mode is 640x480x32, linelength=2560, pages=0
[ 1.111368] vesafb: scrolling: redraw
[ 1.111372] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.111399] vesafb: framebuffer at 0x20000000, mapped to 0xe0000000, using 1216k, total 1216k
[ 1.130444] Console: switching to colour frame buffer device 80x30
[ 1.149356] fb0: VESA VGA frame buffer device
[ 1.149534] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 1.149542] ACPI: Sleep Button [SLPB]
[ 1.149647] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 1.149652] ACPI: Power Button [PWRF]
[ 1.150006] GHES: HEST is not enabled!
[ 1.150058] isapnp: Scanning for PnP cards...
[ 1.460041] isapnp: No Plug & Play device found
[ 1.460232] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.480706] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.484326] Linux agpgart interface v0.103
[ 1.484491] agpgart-intel 0000:00:00.0: Intel 945G Chipset
[ 1.484516] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[ 1.485228] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 1.485409] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0x20000000
[ 1.490759] brd: module loaded
[ 1.493196] loop: module loaded
[ 1.493544] ata_piix 0000:00:1f.1: version 2.13
[ 1.494864] scsi host0: ata_piix
[ 1.495063] scsi host1: ata_piix
[ 1.495156] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x20b0 irq 14
[ 1.495161] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x20b8 irq 15
[ 1.495438] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.495579] ata2: port disabled--ignoring
[ 1.496826] scsi host2: ata_piix
[ 1.497006] scsi host3: ata_piix
[ 1.497100] ata3: SATA max UDMA/133 cmd 0x20c8 ctl 0x20ec bmdma 0x20a0 irq 19
[ 1.497104] ata4: SATA max UDMA/133 cmd 0x20c0 ctl 0x20e8 bmdma 0x20a8 irq 19
[ 1.497305] libphy: Fixed MDIO Bus: probed
[ 1.497312] tun: Universal TUN/TAP device driver, 1.6
[ 1.497314] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.497439] PPP generic driver version 2.4.2
[ 1.497664] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.497677] ehci-pci: EHCI PCI platform driver
[ 1.497934] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.497946] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.497963] ehci-pci 0000:00:1d.7: debug port 1
[ 1.501877] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 1.501951] ehci-pci 0000:00:1d.7: irq 23, io mem 0x301c4000
[ 1.512055] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.512179] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.512183] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.512187] usb usb1: Product: EHCI Host Controller
[ 1.512190] usb usb1: Manufacturer: Linux 4.1.7-rt-rt ehci_hcd
[ 1.512193] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.512450] hub 1-0:1.0: USB hub found
[ 1.512464] hub 1-0:1.0: 8 ports detected
[ 1.512853] ehci-platform: EHCI generic platform driver
[ 1.512878] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.512887] ohci-pci: OHCI PCI platform driver
[ 1.512917] ohci-platform: OHCI generic platform driver
[ 1.512938] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.513153] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.513163] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.513172] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 1.513248] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00002080
[ 1.513343] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.513348] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.513351] usb usb2: Product: UHCI Host Controller
[ 1.513355] usb usb2: Manufacturer: Linux 4.1.7-rt-rt uhci_hcd
[ 1.513358] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.513601] hub 2-0:1.0: USB hub found
[ 1.513614] hub 2-0:1.0: 2 ports detected
[ 1.513993] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.514003] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.514012] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 1.514088] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00002060
[ 1.514178] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.514182] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.514186] usb usb3: Product: UHCI Host Controller
[ 1.514189] usb usb3: Manufacturer: Linux 4.1.7-rt-rt uhci_hcd
[ 1.514192] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.514424] hub 3-0:1.0: USB hub found
[ 1.514440] hub 3-0:1.0: 2 ports detected
[ 1.514853] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.514863] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.514872] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 1.514959] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00002040
[ 1.515051] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.515055] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.515059] usb usb4: Product: UHCI Host Controller
[ 1.515062] usb usb4: Manufacturer: Linux 4.1.7-rt-rt uhci_hcd
[ 1.515065] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.515293] hub 4-0:1.0: USB hub found
[ 1.515307] hub 4-0:1.0: 2 ports detected
[ 1.515713] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.515724] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.515733] uhci_hcd 0000:00:1d.3: detected 2 ports
[ 1.515819] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00002020
[ 1.515909] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.515914] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.515917] usb usb5: Product: UHCI Host Controller
[ 1.515920] usb usb5: Manufacturer: Linux 4.1.7-rt-rt uhci_hcd
[ 1.515923] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.516198] hub 5-0:1.0: USB hub found
[ 1.516211] hub 5-0:1.0: 2 ports detected
[ 1.516516] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.516519] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.517240] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.517487] mousedev: PS/2 mouse device common for all mice
[ 1.517775] rtc_cmos 00:01: RTC can wake from S4
[ 1.517954] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.518031] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
[ 1.518052] i2c /dev entries driver
[ 1.518182] device-mapper: uevent: version 1.0.3
[ 1.518341] device-mapper: ioctl: 4.31.0-ioctl (2015-3-12) initialised: dm-devel@redhat.com
[ 1.518388] platform eisa.0: Probing EISA bus 0
[ 1.518393] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 1.518397] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 1.518400] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 1.518404] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 1.518407] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 1.518410] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 1.518414] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 1.518417] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 1.518420] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 1.518424] platform eisa.0: EISA: Detected 0 cards
[ 1.518436] PCCT header not found.
[ 1.518871] NET: Registered protocol family 10
[ 1.519328] NET: Registered protocol family 17
[ 1.519352] Key type dns_resolver registered
[ 1.519681] Using IPI No-Shortcut mode
[ 1.519976] Loading compiled-in X.509 certificates
[ 1.524273] Loaded X.509 cert 'Build time autogenerated kernel key: 3f0383536490bf33c1a9ed2b39cf1527a2028259'
[ 1.524304] registered taskstats version 1
[ 1.528333] Key type trusted registered
[ 1.535216] Key type encrypted registered
[ 1.535232] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.535240] ima: No TPM chip found, activating TPM-bypass!
[ 1.535280] evm: HMAC attrs: 0x1
[ 1.535745] rtc_cmos 00:01: setting system clock to 2017-02-08 20:30:59 UTC (1486585859)
[ 1.535837] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.535841] EDD information not available.
[ 1.545331] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 1.663054] ata3.00: ATA-8: WDC WD800AAJS-60M0A0, 02.03E02, max UDMA/100
[ 1.663060] ata3.00: 156301488 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.668179] ata3.00: configured for UDMA/100
[ 1.668335] scsi 2:0:0:0: Direct-Access ATA WDC WD800AAJS-60 3E02 PQ: 0 ANSI: 5
[ 1.668650] sd 2:0:0:0: [sda] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 1.668743] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 1.668759] sd 2:0:0:0: [sda] Write Protect is off
[ 1.668763] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.668808] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.710025] sda: sda1 sda2 < sda5 >
[ 1.710589] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.711286] Freeing unused kernel memory: 924K (d0a90000 - d0b77000)
[ 1.711391] Write protecting the kernel text: 7060k
[ 1.711592] Write protecting the kernel read-only data: 3024k
[ 1.711595] NX-protecting the kernel data: 5228k
[ 1.736879] systemd-udevd[129]: starting version 204
[ 1.821528] [drm] Initialized drm 1.1.0 20060810
[ 1.880107] usb 1-7: new high-speed USB device number 3 using ehci-pci
[ 1.899346] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 1.899353] e100: Copyright(c) 1999-2006 Intel Corporation
[ 1.937974] e100 0000:04:08.0 eth0: addr 0x30020000, irq 20, MAC addr 00:19:d1:53:ab:81
[ 1.992075] usb 2-1: new low-speed USB device number 2 using uhci_hcd
[ 2.100100] tsc: Refined TSC clocksource calibration: 3191.999 MHz
[ 2.100108] clocksource tsc: mask: 0xffffffffffffffff max_cycles: 0x2e02c398820, max_idle_ns: 440795273435 ns
[ 2.100324] [drm] Memory usable by graphics device = 256M
[ 2.100334] checking generic (20000000 130000) vs hw (20000000 10000000)
[ 2.100340] fb: switching to inteldrmfb from VESA VGA
[ 2.100388] Console: switching to colour dummy device 80x25
[ 2.101070] [drm] Replacing VGA console driver
[ 2.104498] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.104505] [drm] Driver supports precise vblank timestamp query.
[ 2.106036] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 2.123028] [drm] initialized overlay support
[ 2.123121] [drm] Initialized i915 1.6.0 20150327 for 0000:00:02.0 on minor 0
[ 2.126294] usb 1-7: New USB device found, idVendor=058f, idProduct=6377
[ 2.126303] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.126309] usb 1-7: Product: Mass Storage Device
[ 2.126315] usb 1-7: Manufacturer: Generic
[ 2.126321] usb 1-7: SerialNumber: 920321111113
[ 2.199358] fbcon: inteldrmfb (fb0) is primary device
[ 2.257540] Console: switching to colour frame buffer device 160x45
[ 2.265872] usb-storage 1-7:1.0: USB Mass Storage device detected
[ 2.266058] scsi host4: usb-storage 1-7:1.0
[ 2.266518] usbcore: registered new interface driver usb-storage
[ 2.272770] usbcore: registered new interface driver uas
[ 2.274147] usb 2-1: New USB device found, idVendor=1894, idProduct=5101
[ 2.274151] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.274154] usb 2-1: Product: JPC USB Mouse
[ 2.274156] usb 2-1: Manufacturer: JPC
[ 2.309204] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.330520] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 2.330524] i915 0000:00:02.0: registered panic notifier
[ 2.331779] usbcore: registered new interface driver usbhid
[ 2.331786] usbhid: USB HID core driver
[ 2.337926] input: JPC JPC USB Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/0003:1894:5101.0001/input/input3
[ 2.338264] hid-generic 0003:1894:5101.0001: input,hidraw0: USB HID v1.00 Mouse [JPC JPC USB Mouse] on usb-0000:00:1d.0-1/input0
[ 3.100166] Switched to clocksource tsc
[ 3.264866] scsi 4:0:0:0: Direct-Access Generic USB SD Reader 1.00 PQ: 0 ANSI: 0
[ 3.265485] scsi 4:0:0:1: Direct-Access Generic USB CF Reader 1.01 PQ: 0 ANSI: 0
[ 3.266108] scsi 4:0:0:2: Direct-Access Generic USB SM Reader 1.02 PQ: 0 ANSI: 0
[ 3.266732] scsi 4:0:0:3: Direct-Access Generic USB MS Reader 1.03 PQ: 0 ANSI: 0
[ 3.267337] sd 4:0:0:0: Attached scsi generic sg1 type 0
[ 3.268726] sd 4:0:0:1: Attached scsi generic sg2 type 0
[ 3.269381] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 3.274740] sd 4:0:0:2: Attached scsi generic sg3 type 0
[ 3.280094] sd 4:0:0:1: [sdc] Attached SCSI removable disk
[ 3.281716] sd 4:0:0:2: [sdd] Attached SCSI removable disk
[ 3.287484] sd 4:0:0:3: Attached scsi generic sg4 type 0
[ 3.297869] sd 4:0:0:3: [sde] Attached SCSI removable disk
[ 4.904074] floppy0: no floppy controllers found
[ 5.356833] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.212845] random: nonblocking pool is initialized
[ 6.925325] init: ureadahead main process (280) terminated with status 5
[ 8.010570] Adding 1682428k swap on /dev/sda5. Priority:-1 extents:1 across:1682428k FS
[ 8.220924] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 8.783781] systemd-udevd[406]: starting version 204
[ 9.946140] lp: driver loaded but no devices found
[ 10.015846] ppdev: user-space parallel port driver
[ 10.113900] parport_pc 00:03: reported by Plug and Play ACPI
[ 10.113934] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
[ 10.200342] lp0: using parport0 (interrupt-driven).
[ 11.184504] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 11.349980] intel_rng: FWH not detected
[ 12.123942] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000428-0x0000000000000429 (\GPE0) (20150410/utaddress-254)
[ 12.123964] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 12.124180] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 12.217951] e100 0000:04:08.0 eth3: renamed from eth0
[ 12.232236] systemd-udevd[480]: renamed network interface eth0 to eth3
[ 12.368362] leds_ss4200: no LED devices found
[ 13.054847] Bluetooth: Core ver 2.20
[ 13.054946] NET: Registered protocol family 31
[ 13.054952] Bluetooth: HCI device and connection manager initialized
[ 13.054963] Bluetooth: HCI socket layer initialized
[ 13.054972] Bluetooth: L2CAP socket layer initialized
[ 13.054994] Bluetooth: SCO socket layer initialized
[ 13.124072] Bluetooth: RFCOMM TTY layer initialized
[ 13.124089] Bluetooth: RFCOMM socket layer initialized
[ 13.124104] Bluetooth: RFCOMM ver 1.11
[ 13.232915] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.232922] Bluetooth: BNEP filters: protocol multicast
[ 13.232931] Bluetooth: BNEP socket layer initialized
[ 13.337508] init: cups main process (516) killed by HUP signal
[ 13.337543] init: cups main process ended, respawning
[ 13.586993] device-mapper: multipath: version 1.9.0 loaded
[ 13.799919] snd_hda_codec_realtek hdaudioC0D2: ALC883: SKU not ready 0x411111f0
[ 13.800600] snd_hda_codec_realtek hdaudioC0D2: autoconfig for ALC883: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 13.800611] snd_hda_codec_realtek hdaudioC0D2: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 13.800621] snd_hda_codec_realtek hdaudioC0D2: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 13.800626] snd_hda_codec_realtek hdaudioC0D2: mono: mono_out=0x0
[ 13.800630] snd_hda_codec_realtek hdaudioC0D2: inputs:
[ 13.800638] snd_hda_codec_realtek hdaudioC0D2: Front Mic=0x19
[ 13.800646] snd_hda_codec_realtek hdaudioC0D2: Rear Mic=0x18
[ 13.800653] snd_hda_codec_realtek hdaudioC0D2: Line=0x1a
[ 13.855268] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4
[ 13.868625] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 13.887703] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 13.897784] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 13.898096] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 14.200130] floppy0: no floppy controllers found
[ 14.529566] gpio_ich: GPIO from 462 to 511 on gpio_ich
[ 14.953913] init: failsafe main process (700) killed by TERM signal
[ 22.353880] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
[ 23.575405] init: samba-ad-dc main process (975) terminated with status 1
[ 24.956961] init: plymouth-upstart-bridge main process ended, respawning
[ 24.974840] init: plymouth-upstart-bridge main process (1186) terminated with status 1
[ 24.974873] init: plymouth-upstart-bridge main process ended, respawning
[ 30.932286] init: plymouth-stop pre-start process (1744) terminated with status 1
**************************************ini files****************************************************
# Generated by PNCconf at Fri Feb 3 09:45:56 2017
# overwritten when you run PNCconf again
[EMC]
MACHINE = 1st_LinuxCNC_Bridgeport
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/emc/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.016670
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = 1st_LinuxCNC_Bridgeport.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.10
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 30.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
ENCODER_SCALE = 8000.0
OUTPUT_SCALE = 10.0
OUTPUT_MIN_LIMIT = -10.0
OUTPUT_MAX_LIMIT = 10.0
BACKLASH = 0.003
MIN_LIMIT = -11.0
MAX_LIMIT = 11.0
HOME_OFFSET = 0.0
# Axis Y
[AXIS_3]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 1.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
OUTPUT_SCALE = 10.0
BACKLASH = 0.003
MIN_LIMIT = -5.5
MAX_LIMIT = 5.5
HOME_OFFSET = 0.0
# Axis Z
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 1.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
ENCODER_SCALE = 4000.0
OUTPUT_SCALE = 10.0
MIN_LIMIT = -6.0
MAX_LIMIT = 0.001
HOME_OFFSET = 0.0
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
*********************************************hal files*********************************************************************
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=3 num_pwmgens=0 num_stepgens=0 sserial_port_0=000000"
setp hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt hal_parport cfg="0 out"
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf parport.0.read servo-thread
addf hm2_5i25.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf parport.0.write servo-thread
addf hm2_5i25.0.write servo-thread
# external output signals
# external input signals
# AXIS X
setp pid.x.Pgain [AXIS_2]P
setp pid.x.Igain [AXIS_2]I
setp pid.x.Dgain [AXIS_2]D
setp pid.x.bias [AXIS_2]BIAS
setp pid.x.FF0 [AXIS_2]FF0
setp pid.x.FF1 [AXIS_2]FF1
setp pid.x.FF2 [AXIS_2]FF2
setp pid.x.deadband [AXIS_2]DEADBAND
setp pid.x.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.x.error-previous-target true
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# ---PWM Generator signals/setup---
setp hm2_5i25.0.7i77.0.1.analogout2-scalemax [AXIS_2]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout2-minlim [AXIS_2]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout2-maxlim [AXIS_2]OUTPUT_MAX_LIMIT
net x-output => hm2_5i25.0.7i77.0.1.analogout0
net x-pos-cmd axis.2.motor-pos-cmd
net x-enable axis.2.amp-enable-out
# enable _all_ sserial pwmgens
net x-enable hm2_5i25.0.7i77.0.1.analogena
setp hm2_5i25.0.encoder.02.counter-mode 0
setp hm2_5i25.0.encoder.02.filter 1
setp hm2_5i25.0.encoder.02.index-invert 0
setp hm2_5i25.0.encoder.02.index-mask 0
setp hm2_5i25.0.encoder.02.index-mask-invert 0
setp hm2_5i25.0.encoder.02.scale [AXIS_2]ENCODER_SCALE
net x-pos-fb <= hm2_5i25.0.encoder.02.position
net x-vel-fb <= hm2_5i25.0.encoder.02.velocity
net x-pos-fb => axis.2.motor-pos-fb
net x-index-enable axis.0.index-enable <=> hm2_5i25.0.encoder.02.index-enable
net x-pos-rawcounts <= hm2_5i25.0.encoder.02.rawcounts
# ---setup home / limit switch signals---
net x-home-sw => axis.2.home-sw-in
net x-neg-limit => axis.2.neg-lim-sw-in
net x-pos-limit => axis.2.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [AXIS_3]P
setp pid.y.Igain [AXIS_3]I
setp pid.y.Dgain [AXIS_3]D
setp pid.y.bias [AXIS_3]BIAS
setp pid.y.FF0 [AXIS_3]FF0
setp pid.y.FF1 [AXIS_3]FF1
setp pid.y.FF2 [AXIS_3]FF2
setp pid.y.deadband [AXIS_3]DEADBAND
setp pid.y.maxoutput [AXIS_3]MAX_OUTPUT
setp pid.y.error-previous-target true
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp hm2_5i25.0.7i77.0.1.analogout3-scalemax [AXIS_3]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout3-minlim [AXIS_3]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout3-maxlim [AXIS_3]OUTPUT_MAX_LIMIT
net y-output => hm2_5i25.0.7i77.0.1.analogout1
net y-pos-cmd axis.1.motor-pos-cmd
net y-enable axis.1.amp-enable-out
setp hm2_5i25.0.encoder.03.counter-mode 0
setp hm2_5i25.0.encoder.03.filter 1
setp hm2_5i25.0.encoder.03.index-invert 0
setp hm2_5i25.0.encoder.03.index-mask 0
setp hm2_5i25.0.encoder.03.index-mask-invert 0
setp hm2_5i25.0.encoder.03.scale [AXIS_3]ENCODER_SCALE
net y-pos-fb <= hm2_5i25.0.encoder.03.position
net y-vel-fb <= hm2_5i25.0.encoder.03.velocity
net y-pos-fb => axis.3.motor-pos-fb
net y-index-enable axis.1.index-enable <=> hm2_5i25.0.encoder.03.index-enable
net y-pos-rawcounts <= hm2_5i25.0.encoder.03.rawcounts
net y-home-sw => axis.3.home-sw-in
net y-neg-limit => axis.3.neg-lim-sw-in
net y-pos-limit => axis.3.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_0]P
setp pid.z.Igain [AXIS_0]I
setp pid.z.Dgain [AXIS_0]D
setp pid.z.bias [AXIS_0]BIAS
setp pid.z.FF0 [AXIS_0]FF0
setp pid.z.FF1 [AXIS_0]FF1
setp pid.z.FF2 [AXIS_0]FF2
setp pid.z.deadband [AXIS_0]DEADBAND
setp pid.z.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.z.error-previous-target true
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [AXIS_0]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout0-minlim [AXIS_0]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [AXIS_0]OUTPUT_MAX_LIMIT
net z-output => hm2_5i25.0.7i77.0.1.analogout2
net z-pos-cmd axis.0.motor-pos-cmd
net z-enable axis.0.amp-enable-out
setp hm2_5i25.0.encoder.00.counter-mode 0
setp hm2_5i25.0.encoder.00.filter 1
setp hm2_5i25.0.encoder.00.index-invert 0
setp hm2_5i25.0.encoder.00.index-mask 0
setp hm2_5i25.0.encoder.00.index-mask-invert 0
setp hm2_5i25.0.encoder.00.scale [AXIS_2]ENCODER_SCALE
net z-pos-fb <= hm2_5i25.0.encoder.00.position
net z-vel-fb <= hm2_5i25.0.encoder.00.velocity
net z-pos-fb => axis.0.motor-pos-fb
net z-index-enable axis.2.index-enable <=> hm2_5i25.0.encoder.00.index-enable
net z-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts
net z-home-sw => axis.0.home-sw-in
net z-neg-limit => axis.0.neg-lim-sw-in
net z-pos-limit => axis.0.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.2.select
net x-is-homed halui.joint.2.is-homed
net jog-x-pos halui.jog.2.plus
net jog-x-neg halui.jog.2.minus
net jog-x-analog halui.jog.2.analog
net joint-select-b halui.joint.3.select
net y-is-homed halui.joint.3.is-homed
net jog-y-pos halui.jog.3.plus
net jog-y-neg halui.jog.3.minus
net jog-y-analog halui.jog.3.analog
net joint-select-c halui.joint.0.select
net z-is-homed halui.joint.0.is-homed
net jog-z-pos halui.jog.0.plus
net jog-z-neg halui.jog.0.minus
net jog-z-analog halui.jog.0.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
Last edit: 09 Feb 2017 23:02 by andypugh.
08 Feb 2017 21:25 #87603
Replied by PCW on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
For initial testing, its best that you do not connect any I/O (encoders etc) to the 7I77
Is 7I77 CR1 illuminated?
What voltage do you measure at 7I77 TB1?
Are 7I77 jumpers W4 and W12 in the left hand position?
Is the 7I77 connected to the 5I25 cards P3 (DB25) connector with a IEEE1284 cable?
08 Feb 2017 21:27 #87604
Replied by andypugh on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Not a problem, but are you actually using the parallel port?
I am still wondering why we are not seeing any active sserial pins showing in the dmesg. But I have never used a 7i77, so don't know what you would expect to see.
- Thank you received: 5927
08 Feb 2017 21:38 #87607
I have installed 2 of them (7i77) and i was wondering the same thing. Conned through all that dmesg but could not find anything wrong. The pinout in the Linuxcnc error report was a bit off.
But knowing PCW is always here, i refrain myself from commecting on things i do not have at least a certain degree of certenty, so i just read and learn.
Replied by tommylight on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
08 Feb 2017 22:27 - 09 Feb 2017 00:22 #87612
by new2linux
Replied by new2linux on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Many many thanks PCW, andypugh and tommylight for your help, thoughts or other.
PCW asked the following: the responce
Is 7I77 CR1 illuminated? yes
What voltage do you measure at 7I77 TB1? 5 v
Are 7I77 jumpers W4 and W12 in the left hand position? yes to the left
Is the 7I77 connected to the 5I25 cards P3 (DB25) connector with a IEEE1284 cable? molded on cable IEEE1284
this is a most current (after reboot hal 121)
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.7-rt-rt (root@buildsrv) (gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04) ) #2 SMP PREEMPT RT Mon Sep 28 21:38:11 CDT 2015
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000008efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000008f000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001e60ffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001e610000-0x000000001e6fbfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000001e6fc000-0x000000001f597fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001f598000-0x000000001f59ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000001f5a0000-0x000000001f62cfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001f62d000-0x000000001f630fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000001f631000-0x000000001f6a9fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001f6aa000-0x000000001f6e7fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000001f6e8000-0x000000001f6ebfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001f6ec000-0x000000001f6fefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000001f6ff000-0x000000001f6fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001f700000-0x000000001fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fff80000-0x00000000ffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: emachines W3623/D945GCCRG1, BIOS CR94510J.15A.1007.2007.0216.1519 02/16/2007
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x1f700 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 base 01F800000 mask FFF800000 uncachable
[ 0.000000] 2 base 01F700000 mask FFFF00000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT configuration [0-7]: WB WC UC- UC WB WC UC- UC
[ 0.000000] original variable MTRRs
[ 0.000000] reg 0, base: 0GB, range: 512MB, type WB
[ 0.000000] reg 1, base: 504MB, range: 8MB, type UC
[ 0.000000] reg 2, base: 503MB, range: 1MB, type UC
[ 0.000000] total RAM covered: 503M
[ 0.000000] Found optimal setting for mtrr clean up
[ 0.000000] gran_size: 64K chunk_size: 16M num_reg: 3 lose cover RAM: 0G
[ 0.000000] New variable MTRRs
[ 0.000000] reg 1, base: 503MB, range: 1MB, type UC
[ 0.000000] reg 2, base: 504MB, range: 8MB, type UC
[ 0.000000] found SMP MP-table at [mem 0x000fe200-0x000fe20f] mapped at [c00fe200]
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] initial memory mapped: [mem 0x00000000-0x111fffff]
[ 0.000000] Base memory trampoline at [c008b000] 8b000 size 16384
[ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[ 0.000000] [mem 0x00000000-0x000fffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x1f200000-0x1f3fffff]
[ 0.000000] [mem 0x1f200000-0x1f3fffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x00100000-0x1e60ffff]
[ 0.000000] [mem 0x00100000-0x001fffff] page 4k
[ 0.000000] [mem 0x00200000-0x1e5fffff] page 2M
[ 0.000000] [mem 0x1e600000-0x1e60ffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x1e6fc000-0x1f1fffff]
[ 0.000000] [mem 0x1e6fc000-0x1e7fffff] page 4k
[ 0.000000] [mem 0x1e800000-0x1f1fffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x1f400000-0x1f597fff]
[ 0.000000] [mem 0x1f400000-0x1f597fff] page 4k
[ 0.000000] BRK [0x10cdb000, 0x10cdbfff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x1f5a0000-0x1f62cfff]
[ 0.000000] [mem 0x1f5a0000-0x1f62cfff] page 4k
[ 0.000000] BRK [0x10cdc000, 0x10cdcfff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x1f631000-0x1f6a9fff]
[ 0.000000] [mem 0x1f631000-0x1f6a9fff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x1f6e8000-0x1f6ebfff]
[ 0.000000] [mem 0x1f6e8000-0x1f6ebfff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x1f6ff000-0x1f6fffff]
[ 0.000000] [mem 0x1f6ff000-0x1f6fffff] page 4k
[ 0.000000] BRK [0x10cdd000, 0x10cddfff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x1ca14000-0x1e60ffff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000FE020 000014 (v00 GATEWA)
[ 0.000000] ACPI: RSDT 0x000000001F6FD038 000054 (v01 GATEWA SYSTEM 000003EF 01000013)
[ 0.000000] ACPI: FACP 0x000000001F6FC000 000074 (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: DSDT 0x000000001F6F7000 004172 (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: FACS 0x000000001F6AA000 000040
[ 0.000000] ACPI: APIC 0x000000001F6F6000 000078 (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: WDDT 0x000000001F6F5000 000040 (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: MCFG 0x000000001F6F4000 00003C (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: ASF! 0x000000001F6F3000 0000A6 (v32 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: HPET 0x000000001F6F2000 000038 (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: SLIC 0x000000001F6F1000 000176 (v01 GATEWA SYSTEM 000003EF MSFT 01000013)
[ 0.000000] ACPI: SSDT 0x000000001F6F0000 0001BC (v01 GATEWA CpuPm 000003EF MSFT 01000013)
[ 0.000000] ACPI: SSDT 0x000000001F6EF000 0001B7 (v01 GATEWA Cpu0Ist 000003EF MSFT 01000013)
[ 0.000000] ACPI: SSDT 0x000000001F6EE000 0001B7 (v01 GATEWA Cpu1Ist 000003EF MSFT 01000013)
[ 0.000000] ACPI: SSDT 0x000000001F6ED000 0001B7 (v01 GATEWA Cpu2Ist 000003EF MSFT 01000013)
[ 0.000000] ACPI: SSDT 0x000000001F6EC000 0001B7 (v01 GATEWA Cpu3Ist 000003EF MSFT 01000013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 503MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1f700000
[ 0.000000] low ram: 0 - 1f700000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] Normal [mem 0x0000000001000000-0x000000001f6fffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000008efff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x000000001e60ffff]
[ 0.000000] node 0: [mem 0x000000001e6fc000-0x000000001f597fff]
[ 0.000000] node 0: [mem 0x000000001f5a0000-0x000000001f62cfff]
[ 0.000000] node 0: [mem 0x000000001f631000-0x000000001f6a9fff]
[ 0.000000] node 0: [mem 0x000000001f6e8000-0x000000001f6ebfff]
[ 0.000000] node 0: [mem 0x000000001f6ff000-0x000000001f6fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000001f6fffff]
[ 0.000000] On node 0 totalpages: 128325
[ 0.000000] DMA zone: 40 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3982 pages, LIFO batch:0
[ 0.000000] Normal zone: 1218 pages used for memmap
[ 0.000000] Normal zone: 124343 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] Reserving Intel graphics stolen memory at 0x1f800000-0x1fffffff
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] smpboot: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] e820: [mem 0x20000000-0xfff7ffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 20 pages/cpu @df5dd000 s50144 r0 d31776 u81920
[ 0.000000] pcpu-alloc: s50144 r0 d31776 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 127067
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.1.7-rt-rt root=UUID=7f5dbdbc-c81e-4d4e-9f8c-40b2959fd243 ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 465028K/513300K available (7055K kernel code, 727K rwdata, 3020K rodata, 924K init, 848K bss, 48272K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff15000 - 0xfffff000 ( 936 kB)
[ 0.000000] pkmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xdff00000 - 0xffbfe000 ( 508 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdf700000 ( 503 MB)
[ 0.000000] .init : 0xd0a90000 - 0xd0b77000 ( 924 kB)
[ 0.000000] .data : 0xd06e42e8 - 0xd0a8ed80 (3754 kB)
[ 0.000000] .text : 0xd0000000 - 0xd06e42e8 (7056 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: HWalign=128, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS:2304 nr_irqs:456 16
[ 0.000000] CPU 0 irqstacks, hard=de836000 soft=de838000
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration failed
[ 0.000000] tsc: PIT calibration matches HPET. 3 loops
[ 0.000000] tsc: Detected 3191.977 MHz processor
[ 0.016018] Calibrating delay loop (skipped), value calculated using timer frequency.. 6383.95 BogoMIPS (lpj=12767908)
[ 0.016020] pid_max: default: 32768 minimum: 301
[ 0.016032] ACPI: Core revision 20150410
[ 0.025004] ACPI: All ACPI Tables successfully acquired
[ 0.025028] Security Framework initialized
[ 0.025052] AppArmor: AppArmor initialized
[ 0.025053] Yama: becoming mindful.
[ 0.025119] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.025122] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.025442] Initializing cgroup subsys blkio
[ 0.025446] Initializing cgroup subsys memory
[ 0.025458] Initializing cgroup subsys devices
[ 0.025461] Initializing cgroup subsys freezer
[ 0.025464] Initializing cgroup subsys net_cls
[ 0.025467] Initializing cgroup subsys perf_event
[ 0.025470] Initializing cgroup subsys net_prio
[ 0.025473] Initializing cgroup subsys hugetlb
[ 0.025513] CPU: Physical Processor ID: 0
[ 0.025514] CPU: Processor Core ID: 0
[ 0.025521] mce: CPU supports 4 MCE banks
[ 0.025533] CPU0: Thermal monitoring enabled (TM2)
[ 0.025537] process: using mwait in idle threads
[ 0.025547] Last level iTLB entries: 4KB 64, 2MB 64, 4MB 64
[ 0.025548] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 64, 1GB 0
[ 0.026288] Freeing SMP alternatives memory: 24K (d0b77000 - d0b7d000)
[ 0.028010] ftrace: allocating 29131 entries in 57 pages
[ 0.040158] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.040587] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.084000] smpboot: CPU0: Intel(R) Pentium(R) 4 CPU 3.20GHz (fam: 0f, model: 06, stepping: 05)
[ 0.084000] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.084000] ... version: 0
[ 0.084000] ... bit width: 40
[ 0.084000] ... generic registers: 18
[ 0.084000] ... value mask: 000000ffffffffff
[ 0.084000] ... max period: 0000007fffffffff
[ 0.084000] ... fixed-purpose events: 0
[ 0.084000] ... event mask: 000000000003ffff
[ 0.120115] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.136130] CPU 1 irqstacks, hard=de978000 soft=de97a000
[ 0.136133] x86: Booting SMP configuration:
[ 0.136136] .... node #0, CPUs: #1
[ 0.020000] Initializing CPU#1
[ 0.148070] x86: Booted up 1 node, 2 CPUs
[ 0.148080] smpboot: Total of 2 processors activated (12767.90 BogoMIPS)
[ 0.149858] devtmpfs: initialized
[ 0.149858] evm: security.selinux
[ 0.149858] evm: security.SMACK64
[ 0.149858] evm: security.SMACK64EXEC
[ 0.149858] evm: security.SMACK64TRANSMUTE
[ 0.149858] evm: security.SMACK64MMAP
[ 0.149858] evm: security.ima
[ 0.149858] evm: security.capability
[ 0.149858] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.152121] pinctrl core: initialized pinctrl subsystem
[ 0.152518] NET: Registered protocol family 16
[ 0.152877] EISA bus registered
[ 0.164027] cpuidle: using governor ladder
[ 0.176036] cpuidle: using governor menu
[ 0.176201] ACPI: bus type PCI registered
[ 0.176206] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.176354] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.176359] PCI: not using MMCONFIG
[ 0.179645] PCI: Using configuration type 1 for base access
[ 0.192507] ACPI: Added _OSI(Module Device)
[ 0.192512] ACPI: Added _OSI(Processor Device)
[ 0.192515] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.192518] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.197214] ACPI: Interpreter enabled
[ 0.197227] ACPI: (supports S0 S5)
[ 0.197230] ACPI: Using IOAPIC for interrupt routing
[ 0.197257] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.197924] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in ACPI motherboard resources
[ 0.197930] PCI: MMCONFIG for 0000 [bus00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000) (size reduced!)
[ 0.197932] PCI: Using MMCONFIG for extended config space
[ 0.197962] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.206615] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.206626] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.206635] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.207740] acpi PNP0A03:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.208037] PCI host bridge to bus 0000:00
[ 0.208043] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.208048] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.208052] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.208056] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.208059] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000effff window]
[ 0.208063] pci_bus 0000:00: root bus resource [mem 0xf8000000-0xfebfffff window]
[ 0.208067] pci_bus 0000:00: root bus resource [mem 0x20000000-0xf0000000 window]
[ 0.208084] pci 0000:00:00.0: [8086:2770] type 00 class 0x060000
[ 0.208266] pci 0000:00:02.0: [8086:2772] type 00 class 0x030000
[ 0.208283] pci 0000:00:02.0: reg 0x10: [mem 0x30100000-0x3017ffff]
[ 0.208293] pci 0000:00:02.0: reg 0x14: [io 0x20e0-0x20e7]
[ 0.208303] pci 0000:00:02.0: reg 0x18: [mem 0x20000000-0x2fffffff pref]
[ 0.208312] pci 0000:00:02.0: reg 0x1c: [mem 0x30180000-0x301bffff]
[ 0.208511] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[ 0.208535] pci 0000:00:1b.0: reg 0x10: [mem 0x301c0000-0x301c3fff 64bit]
[ 0.208625] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.208739] pci 0000:00:1b.0: System wakeup disabled by ACPI
[ 0.208830] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[ 0.208920] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.208999] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.209093] pci 0000:00:1c.2: [8086:27d4] type 01 class 0x060400
[ 0.209182] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.209260] pci 0000:00:1c.2: System wakeup disabled by ACPI
[ 0.209352] pci 0000:00:1c.3: [8086:27d6] type 01 class 0x060400
[ 0.209441] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.209520] pci 0000:00:1c.3: System wakeup disabled by ACPI
[ 0.209610] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[ 0.209662] pci 0000:00:1d.0: reg 0x20: [io 0x2080-0x209f]
[ 0.209791] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.209878] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[ 0.209930] pci 0000:00:1d.1: reg 0x20: [io 0x2060-0x207f]
[ 0.210058] pci 0000:00:1d.1: System wakeup disabled by ACPI
[ 0.210145] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[ 0.210197] pci 0000:00:1d.2: reg 0x20: [io 0x2040-0x205f]
[ 0.210324] pci 0000:00:1d.2: System wakeup disabled by ACPI
[ 0.210412] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[ 0.210463] pci 0000:00:1d.3: reg 0x20: [io 0x2020-0x203f]
[ 0.210591] pci 0000:00:1d.3: System wakeup disabled by ACPI
[ 0.210684] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[ 0.210708] pci 0000:00:1d.7: reg 0x10: [mem 0x301c4000-0x301c43ff]
[ 0.210806] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.210912] pci 0000:00:1d.7: System wakeup disabled by ACPI
[ 0.211005] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.211134] pci 0000:00:1e.0: System wakeup disabled by ACPI
[ 0.211225] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100
[ 0.211324] pci 0000:00:1f.0: can't claim BAR 13 [io 0x0400-0x047f]: address conflict with ACPI CPU throttle [io 0x0410-0x0415]
[ 0.211331] pci 0000:00:1f.0: quirk: [io 0x0500-0x053f] claimed by ICH6 GPIO
[ 0.211337] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0680 (mask 007f)
[ 0.211497] pci 0000:00:1f.1: [8086:27df] type 00 class 0x01018a
[ 0.211516] pci 0000:00:1f.1: reg 0x10: [io 0x0000-0x0007]
[ 0.211528] pci 0000:00:1f.1: reg 0x14: [io 0x0000-0x0003]
[ 0.211541] pci 0000:00:1f.1: reg 0x18: [io 0x0000-0x0007]
[ 0.211553] pci 0000:00:1f.1: reg 0x1c: [io 0x0000-0x0003]
[ 0.211565] pci 0000:00:1f.1: reg 0x20: [io 0x20b0-0x20bf]
[ 0.211590] pci 0000:00:1f.1: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.211593] pci 0000:00:1f.1: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.211597] pci 0000:00:1f.1: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.211600] pci 0000:00:1f.1: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.211746] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f
[ 0.211766] pci 0000:00:1f.2: reg 0x10: [io 0x20c8-0x20cf]
[ 0.211777] pci 0000:00:1f.2: reg 0x14: [io 0x20ec-0x20ef]
[ 0.211789] pci 0000:00:1f.2: reg 0x18: [io 0x20c0-0x20c7]
[ 0.211800] pci 0000:00:1f.2: reg 0x1c: [io 0x20e8-0x20eb]
[ 0.211811] pci 0000:00:1f.2: reg 0x20: [io 0x20a0-0x20af]
[ 0.211857] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.212016] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[ 0.212079] pci 0000:00:1f.3: reg 0x20: [io 0x2000-0x201f]
[ 0.212306] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.212393] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.212476] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.212577] pci 0000:04:04.0: [2718:5125] type 00 class 0x110000
[ 0.212596] pci 0000:04:04.0: reg 0x10: [mem 0x30010000-0x3001ffff]
[ 0.212754] pci 0000:04:05.0: [14f1:2f40] type 00 class 0x078000
[ 0.212776] pci 0000:04:05.0: reg 0x10: [mem 0x30000000-0x3000ffff]
[ 0.212789] pci 0000:04:05.0: reg 0x14: [io 0x1040-0x1047]
[ 0.212870] pci 0000:04:05.0: PME# supported from D3hot D3cold
[ 0.212980] pci 0000:04:08.0: [8086:1094] type 00 class 0x020000
[ 0.213002] pci 0000:04:08.0: reg 0x10: [mem 0x30020000-0x30020fff]
[ 0.213015] pci 0000:04:08.0: reg 0x14: [io 0x1000-0x103f]
[ 0.213096] pci 0000:04:08.0: supports D1 D2
[ 0.213100] pci 0000:04:08.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.213135] pci 0000:04:08.0: System wakeup disabled by ACPI
[ 0.213250] pci 0000:00:1e.0: PCI bridge to [bus 04] (subtractive decode)
[ 0.213257] pci 0000:00:1e.0: bridge window [io 0x1000-0x1fff]
[ 0.213263] pci 0000:00:1e.0: bridge window [mem 0x30000000-0x300fffff]
[ 0.213271] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.213275] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.213279] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.213283] pci 0000:00:1e.0: bridge window [mem 0x000e0000-0x000effff window] (subtractive decode)
[ 0.213287] pci 0000:00:1e.0: bridge window [mem 0xf8000000-0xfebfffff window] (subtractive decode)
[ 0.213290] pci 0000:00:1e.0: bridge window [mem 0x20000000-0xf0000000 window] (subtractive decode)
[ 0.213318] pci_bus 0000:00: on NUMA node 0
[ 0.213446] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.213568] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.213689] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 *9 10 11 12)
[ 0.213809] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.213927] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.214046] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.214168] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 *9 10 11 12)
[ 0.214288] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.215146] ACPI: Enabled 1 GPEs in block 00 to 1F
[ 0.216027] vgaarb: setting as boot device: PCI:0000:00:02.0
[ 0.216027] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.216030] vgaarb: loaded
[ 0.216033] vgaarb: bridge control possible 0000:00:02.0
[ 0.216570] SCSI subsystem initialized
[ 0.216612] libata version 3.00 loaded.
[ 0.216612] ACPI: bus type USB registered
[ 0.216612] usbcore: registered new interface driver usbfs
[ 0.216612] usbcore: registered new interface driver hub
[ 0.216612] usbcore: registered new device driver usb
[ 0.216612] PCI: Using ACPI for IRQ routing
[ 0.217865] PCI: pci_cache_line_size set to 64 bytes
[ 0.217934] e820: reserve RAM buffer [mem 0x0008f000-0x0008ffff]
[ 0.217939] e820: reserve RAM buffer [mem 0x1e610000-0x1fffffff]
[ 0.217943] e820: reserve RAM buffer [mem 0x1f598000-0x1fffffff]
[ 0.217946] e820: reserve RAM buffer [mem 0x1f62d000-0x1fffffff]
[ 0.217950] e820: reserve RAM buffer [mem 0x1f6aa000-0x1fffffff]
[ 0.217953] e820: reserve RAM buffer [mem 0x1f6ec000-0x1fffffff]
[ 0.217956] e820: reserve RAM buffer [mem 0x1f700000-0x1fffffff]
[ 0.218206] NetLabel: Initializing
[ 0.218209] NetLabel: domain hash size = 128
[ 0.218211] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.218231] NetLabel: unlabeled traffic allowed by default
[ 0.220121] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.220128] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.220136] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.222176] Switched to clocksource hpet
[ 0.241279] AppArmor: AppArmor Filesystem Enabled
[ 0.241422] pnp: PnP ACPI init
[ 0.241588] system 00:00: [mem 0xf0000000-0xf3ffffff] could not be reserved
[ 0.241595] system 00:00: [mem 0xfed13000-0xfed13fff] has been reserved
[ 0.241599] system 00:00: [mem 0xfed14000-0xfed17fff] has been reserved
[ 0.241603] system 00:00: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.241608] system 00:00: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.241612] system 00:00: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.241616] system 00:00: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.241620] system 00:00: [mem 0xfed45000-0xfed99fff] has been reserved
[ 0.241625] system 00:00: [mem 0x000c0000-0x000dffff] could not be reserved
[ 0.241629] system 00:00: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.241636] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.241947] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.242052] system 00:02: [io 0x0500-0x053f] has been reserved
[ 0.242058] system 00:02: [io 0x0400-0x047f] could not be reserved
[ 0.242063] system 00:02: [io 0x0680-0x06ff] has been reserved
[ 0.242067] system 00:02: [io 0x0770-0x077f] has been reserved
[ 0.242073] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.242454] pnp 00:03: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.242628] pnp 00:04: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.242917] pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.243081] pnp: PnP ACPI: found 6 devices
[ 0.243090] PnPBIOS: Disabled by ACPI PNP
[ 0.282048] clocksource acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.282075] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
[ 0.282083] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[ 0.282088] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[ 0.282100] pci 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 02] add_size 1000
[ 0.282105] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[ 0.282109] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff] to [bus 02] add_size 200000 add_align 100000
[ 0.282121] pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 03] add_size 1000
[ 0.282126] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[ 0.282130] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff] to [bus 03] add_size 200000 add_align 100000
[ 0.282148] pci 0000:00:1f.0: BAR 13: [io size 0x0080] has bogus alignment
[ 0.282155] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.282159] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.282163] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.282168] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.282171] pci 0000:00:1c.2: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.282175] pci 0000:00:1c.2: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.282180] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.282184] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.282187] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.282191] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.282195] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.282200] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.282204] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.282207] pci 0000:00:1c.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.282211] pci 0000:00:1c.2: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.282215] pci 0000:00:1c.2: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.282219] pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.282223] pci 0000:00:1c.3: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.282233] pci 0000:00:1c.0: BAR 14: assigned [mem 0xf8000000-0xf81fffff]
[ 0.282245] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf8200000-0xf83fffff 64bit pref]
[ 0.282252] pci 0000:00:1c.2: BAR 14: assigned [mem 0xf8400000-0xf85fffff]
[ 0.282261] pci 0000:00:1c.2: BAR 15: assigned [mem 0xf8600000-0xf87fffff 64bit pref]
[ 0.282267] pci 0000:00:1c.3: BAR 14: assigned [mem 0xf8800000-0xf89fffff]
[ 0.282275] pci 0000:00:1c.3: BAR 15: assigned [mem 0xf8a00000-0xf8bfffff 64bit pref]
[ 0.282282] pci 0000:00:1c.0: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.282288] pci 0000:00:1c.2: BAR 13: assigned [io 0x4000-0x4fff]
[ 0.282294] pci 0000:00:1c.3: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.282299] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.282304] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ 0.282311] pci 0000:00:1c.0: bridge window [mem 0xf8000000-0xf81fffff]
[ 0.282317] pci 0000:00:1c.0: bridge window [mem 0xf8200000-0xf83fffff 64bit pref]
[ 0.282325] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.282329] pci 0000:00:1c.2: bridge window [io 0x4000-0x4fff]
[ 0.282336] pci 0000:00:1c.2: bridge window [mem 0xf8400000-0xf85fffff]
[ 0.282342] pci 0000:00:1c.2: bridge window [mem 0xf8600000-0xf87fffff 64bit pref]
[ 0.282349] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.282354] pci 0000:00:1c.3: bridge window [io 0x5000-0x5fff]
[ 0.282360] pci 0000:00:1c.3: bridge window [mem 0xf8800000-0xf89fffff]
[ 0.282366] pci 0000:00:1c.3: bridge window [mem 0xf8a00000-0xf8bfffff 64bit pref]
[ 0.282374] pci 0000:00:1e.0: PCI bridge to [bus 04]
[ 0.282378] pci 0000:00:1e.0: bridge window [io 0x1000-0x1fff]
[ 0.282385] pci 0000:00:1e.0: bridge window [mem 0x30000000-0x300fffff]
[ 0.282397] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.282400] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.282404] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.282407] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000effff window]
[ 0.282411] pci_bus 0000:00: resource 8 [mem 0xf8000000-0xfebfffff window]
[ 0.282415] pci_bus 0000:00: resource 9 [mem 0x20000000-0xf0000000 window]
[ 0.282418] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.282422] pci_bus 0000:01: resource 1 [mem 0xf8000000-0xf81fffff]
[ 0.282425] pci_bus 0000:01: resource 2 [mem 0xf8200000-0xf83fffff 64bit pref]
[ 0.282429] pci_bus 0000:02: resource 0 [io 0x4000-0x4fff]
[ 0.282432] pci_bus 0000:02: resource 1 [mem 0xf8400000-0xf85fffff]
[ 0.282436] pci_bus 0000:02: resource 2 [mem 0xf8600000-0xf87fffff 64bit pref]
[ 0.282439] pci_bus 0000:03: resource 0 [io 0x5000-0x5fff]
[ 0.282443] pci_bus 0000:03: resource 1 [mem 0xf8800000-0xf89fffff]
[ 0.282446] pci_bus 0000:03: resource 2 [mem 0xf8a00000-0xf8bfffff 64bit pref]
[ 0.282450] pci_bus 0000:04: resource 0 [io 0x1000-0x1fff]
[ 0.282453] pci_bus 0000:04: resource 1 [mem 0x30000000-0x300fffff]
[ 0.282457] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7 window]
[ 0.282460] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff window]
[ 0.282464] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.282467] pci_bus 0000:04: resource 7 [mem 0x000e0000-0x000effff window]
[ 0.282471] pci_bus 0000:04: resource 8 [mem 0xf8000000-0xfebfffff window]
[ 0.282474] pci_bus 0000:04: resource 9 [mem 0x20000000-0xf0000000 window]
[ 0.282533] NET: Registered protocol family 2
[ 0.282850] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.282875] TCP bind hash table entries: 4096 (order: 4, 114688 bytes)
[ 0.282944] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.282975] UDP hash table entries: 256 (order: 2, 16384 bytes)
[ 0.282987] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[ 0.283079] NET: Registered protocol family 1
[ 0.283106] pci 0000:00:02.0: Video device with shadowed ROM
[ 0.285029] pci 0000:04:08.0: Firmware left e100 interrupts enabled; disabling
[ 0.285039] PCI: CLS 64 bytes, default 64
[ 0.285148] Trying to unpack rootfs image as initramfs...
[ 1.101573] Freeing initrd memory: 28656K (dca14000 - de610000)
[ 1.101874] microcode: CPU0 sig=0xf65, pf=0x4, revision=0x7
[ 1.101886] microcode: CPU1 sig=0xf65, pf=0x4, revision=0x7
[ 1.102011] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.102067] Scanning for low memory corruption every 60 seconds
[ 1.102608] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 1.102669] Initialise system trusted keyring
[ 1.102709] audit: initializing netlink subsys (disabled)
[ 1.102744] audit: type=2000 audit(1486585858.100:1): initialized
[ 1.103261] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.107488] zpool: loaded
[ 1.107494] zbud: loaded
[ 1.107638] VFS: Disk quotas dquot_6.6.0
[ 1.107735] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.108843] fuse init (API version 7.23)
[ 1.109182] Key type big_key registered
[ 1.109835] Key type asymmetric registered
[ 1.109843] Asymmetric key parser 'x509' registered
[ 1.109880] bounce: pool size: 64 pages
[ 1.109965] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 1.110043] io scheduler noop registered
[ 1.110050] io scheduler deadline registered
[ 1.110069] io scheduler cfq registered (default)
[ 1.111250] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.111290] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.111365] vesafb: mode is 640x480x32, linelength=2560, pages=0
[ 1.111368] vesafb: scrolling: redraw
[ 1.111372] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.111399] vesafb: framebuffer at 0x20000000, mapped to 0xe0000000, using 1216k, total 1216k
[ 1.130444] Console: switching to colour frame buffer device 80x30
[ 1.149356] fb0: VESA VGA frame buffer device
[ 1.149534] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 1.149542] ACPI: Sleep Button [SLPB]
[ 1.149647] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 1.149652] ACPI: Power Button [PWRF]
[ 1.150006] GHES: HEST is not enabled!
[ 1.150058] isapnp: Scanning for PnP cards...
[ 1.460041] isapnp: No Plug & Play device found
[ 1.460232] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.480706] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.484326] Linux agpgart interface v0.103
[ 1.484491] agpgart-intel 0000:00:00.0: Intel 945G Chipset
[ 1.484516] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[ 1.485228] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 1.485409] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0x20000000
[ 1.490759] brd: module loaded
[ 1.493196] loop: module loaded
[ 1.493544] ata_piix 0000:00:1f.1: version 2.13
[ 1.494864] scsi host0: ata_piix
[ 1.495063] scsi host1: ata_piix
[ 1.495156] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x20b0 irq 14
[ 1.495161] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x20b8 irq 15
[ 1.495438] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.495579] ata2: port disabled--ignoring
[ 1.496826] scsi host2: ata_piix
[ 1.497006] scsi host3: ata_piix
[ 1.497100] ata3: SATA max UDMA/133 cmd 0x20c8 ctl 0x20ec bmdma 0x20a0 irq 19
[ 1.497104] ata4: SATA max UDMA/133 cmd 0x20c0 ctl 0x20e8 bmdma 0x20a8 irq 19
[ 1.497305] libphy: Fixed MDIO Bus: probed
[ 1.497312] tun: Universal TUN/TAP device driver, 1.6
[ 1.497314] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 1.497439] PPP generic driver version 2.4.2
[ 1.497664] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.497677] ehci-pci: EHCI PCI platform driver
[ 1.497934] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.497946] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.497963] ehci-pci 0000:00:1d.7: debug port 1
[ 1.501877] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 1.501951] ehci-pci 0000:00:1d.7: irq 23, io mem 0x301c4000
[ 1.512055] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.512179] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.512183] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.512187] usb usb1: Product: EHCI Host Controller
[ 1.512190] usb usb1: Manufacturer: Linux 4.1.7-rt-rt ehci_hcd
[ 1.512193] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.512450] hub 1-0:1.0: USB hub found
[ 1.512464] hub 1-0:1.0: 8 ports detected
[ 1.512853] ehci-platform: EHCI generic platform driver
[ 1.512878] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.512887] ohci-pci: OHCI PCI platform driver
[ 1.512917] ohci-platform: OHCI generic platform driver
[ 1.512938] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.513153] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.513163] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.513172] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 1.513248] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00002080
[ 1.513343] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.513348] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.513351] usb usb2: Product: UHCI Host Controller
[ 1.513355] usb usb2: Manufacturer: Linux 4.1.7-rt-rt uhci_hcd
[ 1.513358] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.513601] hub 2-0:1.0: USB hub found
[ 1.513614] hub 2-0:1.0: 2 ports detected
[ 1.513993] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.514003] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.514012] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 1.514088] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00002060
[ 1.514178] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.514182] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.514186] usb usb3: Product: UHCI Host Controller
[ 1.514189] usb usb3: Manufacturer: Linux 4.1.7-rt-rt uhci_hcd
[ 1.514192] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.514424] hub 3-0:1.0: USB hub found
[ 1.514440] hub 3-0:1.0: 2 ports detected
[ 1.514853] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.514863] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.514872] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 1.514959] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00002040
[ 1.515051] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.515055] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.515059] usb usb4: Product: UHCI Host Controller
[ 1.515062] usb usb4: Manufacturer: Linux 4.1.7-rt-rt uhci_hcd
[ 1.515065] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.515293] hub 4-0:1.0: USB hub found
[ 1.515307] hub 4-0:1.0: 2 ports detected
[ 1.515713] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.515724] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.515733] uhci_hcd 0000:00:1d.3: detected 2 ports
[ 1.515819] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00002020
[ 1.515909] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.515914] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.515917] usb usb5: Product: UHCI Host Controller
[ 1.515920] usb usb5: Manufacturer: Linux 4.1.7-rt-rt uhci_hcd
[ 1.515923] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.516198] hub 5-0:1.0: USB hub found
[ 1.516211] hub 5-0:1.0: 2 ports detected
[ 1.516516] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.516519] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.517240] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.517487] mousedev: PS/2 mouse device common for all mice
[ 1.517775] rtc_cmos 00:01: RTC can wake from S4
[ 1.517954] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.518031] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
[ 1.518052] i2c /dev entries driver
[ 1.518182] device-mapper: uevent: version 1.0.3
[ 1.518341] device-mapper: ioctl: 4.31.0-ioctl (2015-3-12) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 1.518388] platform eisa.0: Probing EISA bus 0
[ 1.518393] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 1.518397] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 1.518400] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 1.518404] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 1.518407] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 1.518410] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 1.518414] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 1.518417] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 1.518420] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 1.518424] platform eisa.0: EISA: Detected 0 cards
[ 1.518436] PCCT header not found.
[ 1.518871] NET: Registered protocol family 10
[ 1.519328] NET: Registered protocol family 17
[ 1.519352] Key type dns_resolver registered
[ 1.519681] Using IPI No-Shortcut mode
[ 1.519976] Loading compiled-in X.509 certificates
[ 1.524273] Loaded X.509 cert 'Build time autogenerated kernel key: 3f0383536490bf33c1a9ed2b39cf1527a2028259'
[ 1.524304] registered taskstats version 1
[ 1.528333] Key type trusted registered
[ 1.535216] Key type encrypted registered
[ 1.535232] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.535240] ima: No TPM chip found, activating TPM-bypass!
[ 1.535280] evm: HMAC attrs: 0x1
[ 1.535745] rtc_cmos 00:01: setting system clock to 2017-02-08 20:30:59 UTC (1486585859)
[ 1.535837] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.535841] EDD information not available.
[ 1.545331] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 1.663054] ata3.00: ATA-8: WDC WD800AAJS-60M0A0, 02.03E02, max UDMA/100
[ 1.663060] ata3.00: 156301488 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.668179] ata3.00: configured for UDMA/100
[ 1.668335] scsi 2:0:0:0: Direct-Access ATA WDC WD800AAJS-60 3E02 PQ: 0 ANSI: 5
[ 1.668650] sd 2:0:0:0: [sda] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 1.668743] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 1.668759] sd 2:0:0:0: [sda] Write Protect is off
[ 1.668763] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.668808] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.710025] sda: sda1 sda2 < sda5 >
[ 1.710589] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.711286] Freeing unused kernel memory: 924K (d0a90000 - d0b77000)
[ 1.711391] Write protecting the kernel text: 7060k
[ 1.711592] Write protecting the kernel read-only data: 3024k
[ 1.711595] NX-protecting the kernel data: 5228k
[ 1.736879] systemd-udevd[129]: starting version 204
[ 1.821528] [drm] Initialized drm 1.1.0 20060810
[ 1.880107] usb 1-7: new high-speed USB device number 3 using ehci-pci
[ 1.899346] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 1.899353] e100: Copyright(c) 1999-2006 Intel Corporation
[ 1.937974] e100 0000:04:08.0 eth0: addr 0x30020000, irq 20, MAC addr 00:19:d1:53:ab:81
[ 1.992075] usb 2-1: new low-speed USB device number 2 using uhci_hcd
[ 2.100100] tsc: Refined TSC clocksource calibration: 3191.999 MHz
[ 2.100108] clocksource tsc: mask: 0xffffffffffffffff max_cycles: 0x2e02c398820, max_idle_ns: 440795273435 ns
[ 2.100324] [drm] Memory usable by graphics device = 256M
[ 2.100334] checking generic (20000000 130000) vs hw (20000000 10000000)
[ 2.100340] fb: switching to inteldrmfb from VESA VGA
[ 2.100388] Console: switching to colour dummy device 80x25
[ 2.101070] [drm] Replacing VGA console driver
[ 2.104498] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.104505] [drm] Driver supports precise vblank timestamp query.
[ 2.106036] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 2.123028] [drm] initialized overlay support
[ 2.123121] [drm] Initialized i915 1.6.0 20150327 for 0000:00:02.0 on minor 0
[ 2.126294] usb 1-7: New USB device found, idVendor=058f, idProduct=6377
[ 2.126303] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.126309] usb 1-7: Product: Mass Storage Device
[ 2.126315] usb 1-7: Manufacturer: Generic
[ 2.126321] usb 1-7: SerialNumber: 920321111113
[ 2.199358] fbcon: inteldrmfb (fb0) is primary device
[ 2.257540] Console: switching to colour frame buffer device 160x45
[ 2.265872] usb-storage 1-7:1.0: USB Mass Storage device detected
[ 2.266058] scsi host4: usb-storage 1-7:1.0
[ 2.266518] usbcore: registered new interface driver usb-storage
[ 2.272770] usbcore: registered new interface driver uas
[ 2.274147] usb 2-1: New USB device found, idVendor=1894, idProduct=5101
[ 2.274151] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.274154] usb 2-1: Product: JPC USB Mouse
[ 2.274156] usb 2-1: Manufacturer: JPC
[ 2.309204] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.330520] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 2.330524] i915 0000:00:02.0: registered panic notifier
[ 2.331779] usbcore: registered new interface driver usbhid
[ 2.331786] usbhid: USB HID core driver
[ 2.337926] input: JPC JPC USB Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/0003:1894:5101.0001/input/input3
[ 2.338264] hid-generic 0003:1894:5101.0001: input,hidraw0: USB HID v1.00 Mouse [JPC JPC USB Mouse] on usb-0000:00:1d.0-1/input0
[ 3.100166] Switched to clocksource tsc
[ 3.264866] scsi 4:0:0:0: Direct-Access Generic USB SD Reader 1.00 PQ: 0 ANSI: 0
[ 3.265485] scsi 4:0:0:1: Direct-Access Generic USB CF Reader 1.01 PQ: 0 ANSI: 0
[ 3.266108] scsi 4:0:0:2: Direct-Access Generic USB SM Reader 1.02 PQ: 0 ANSI: 0
[ 3.266732] scsi 4:0:0:3: Direct-Access Generic USB MS Reader 1.03 PQ: 0 ANSI: 0
[ 3.267337] sd 4:0:0:0: Attached scsi generic sg1 type 0
[ 3.268726] sd 4:0:0:1: Attached scsi generic sg2 type 0
[ 3.269381] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 3.274740] sd 4:0:0:2: Attached scsi generic sg3 type 0
[ 3.280094] sd 4:0:0:1: [sdc] Attached SCSI removable disk
[ 3.281716] sd 4:0:0:2: [sdd] Attached SCSI removable disk
[ 3.287484] sd 4:0:0:3: Attached scsi generic sg4 type 0
[ 3.297869] sd 4:0:0:3: [sde] Attached SCSI removable disk
[ 4.904074] floppy0: no floppy controllers found
[ 5.356833] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.212845] random: nonblocking pool is initialized
[ 6.925325] init: ureadahead main process (280) terminated with status 5
[ 8.010570] Adding 1682428k swap on /dev/sda5. Priority:-1 extents:1 across:1682428k FS
[ 8.220924] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 8.783781] systemd-udevd[406]: starting version 204
[ 9.946140] lp: driver loaded but no devices found
[ 10.015846] ppdev: user-space parallel port driver
[ 10.113900] parport_pc 00:03: reported by Plug and Play ACPI
[ 10.113934] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
[ 10.200342] lp0: using parport0 (interrupt-driven).
[ 11.184504] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 11.349980] intel_rng: FWH not detected
[ 12.123942] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000428-0x0000000000000429 (\GPE0) (20150410/utaddress-254)
[ 12.123964] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 12.124180] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 12.217951] e100 0000:04:08.0 eth3: renamed from eth0
[ 12.232236] systemd-udevd[480]: renamed network interface eth0 to eth3
[ 12.368362] leds_ss4200: no LED devices found
[ 13.054847] Bluetooth: Core ver 2.20
[ 13.054946] NET: Registered protocol family 31
[ 13.054952] Bluetooth: HCI device and connection manager initialized
[ 13.054963] Bluetooth: HCI socket layer initialized
[ 13.054972] Bluetooth: L2CAP socket layer initialized
[ 13.054994] Bluetooth: SCO socket layer initialized
[ 13.124072] Bluetooth: RFCOMM TTY layer initialized
[ 13.124089] Bluetooth: RFCOMM socket layer initialized
[ 13.124104] Bluetooth: RFCOMM ver 1.11
[ 13.232915] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.232922] Bluetooth: BNEP filters: protocol multicast
[ 13.232931] Bluetooth: BNEP socket layer initialized
[ 13.337508] init: cups main process (516) killed by HUP signal
[ 13.337543] init: cups main process ended, respawning
[ 13.586993] device-mapper: multipath: version 1.9.0 loaded
[ 13.799919] snd_hda_codec_realtek hdaudioC0D2: ALC883: SKU not ready 0x411111f0
[ 13.800600] snd_hda_codec_realtek hdaudioC0D2: autoconfig for ALC883: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 13.800611] snd_hda_codec_realtek hdaudioC0D2: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 13.800621] snd_hda_codec_realtek hdaudioC0D2: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 13.800626] snd_hda_codec_realtek hdaudioC0D2: mono: mono_out=0x0
[ 13.800630] snd_hda_codec_realtek hdaudioC0D2: inputs:
[ 13.800638] snd_hda_codec_realtek hdaudioC0D2: Front Mic=0x19
[ 13.800646] snd_hda_codec_realtek hdaudioC0D2: Rear Mic=0x18
[ 13.800653] snd_hda_codec_realtek hdaudioC0D2: Line=0x1a
[ 13.855268] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4
[ 13.868625] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 13.887703] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 13.897784] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 13.898096] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 14.200130] floppy0: no floppy controllers found
[ 14.529566] gpio_ich: GPIO from 462 to 511 on gpio_ich
[ 14.953913] init: failsafe main process (700) killed by TERM signal
[ 22.353880] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
[ 23.575405] init: samba-ad-dc main process (975) terminated with status 1
[ 24.956961] init: plymouth-upstart-bridge main process ended, respawning
[ 24.974840] init: plymouth-upstart-bridge main process (1186) terminated with status 1
[ 24.974873] init: plymouth-upstart-bridge main process ended, respawning
[ 30.932286] init: plymouth-stop pre-start process (1744) terminated with status 1
[ 112.764042] usb 1-6: new high-speed USB device number 4 using ehci-pci
[ 112.897779] usb 1-6: New USB device found, idVendor=154b, idProduct=00c4
[ 112.897786] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 112.897791] usb 1-6: Product: USB 2.0 FD
[ 112.897796] usb 1-6: Manufacturer: PNY Technologies
[ 112.897800] usb 1-6: SerialNumber: A0304H03YD78350219
[ 112.898230] usb-storage 1-6:1.0: USB Mass Storage device detected
[ 112.898375] scsi host5: usb-storage 1-6:1.0
[ 114.168748] scsi 5:0:0:0: Direct-Access PNY USB 2.0 FD 1100 PQ: 0 ANSI: 4
[ 114.169939] sd 5:0:0:0: Attached scsi generic sg5 type 0
[ 114.170356] sd 5:0:0:0: [sdf] 62391296 512-byte logical blocks: (31.9 GB/29.7 GiB)
[ 114.171097] sd 5:0:0:0: [sdf] Write Protect is off
[ 114.171104] sd 5:0:0:0: [sdf] Mode Sense: 43 00 00 00
[ 114.171843] sd 5:0:0:0: [sdf] No Caching mode page found
[ 114.171847] sd 5:0:0:0: [sdf] Assuming drive cache: write through
[ 114.178912] sdf: sdf1
[ 114.182610] sd 5:0:0:0: [sdf] Attached SCSI removable disk
[ 114.683166] FAT-fs (sdf1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 302.893317] usb 1-6: USB disconnect, device number 4
many thanks for any of your thoughts, point me in the best direction, if i need more preferred reading!
Warning: Spoiler!
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.8
Machine configuration directory is '/home/emc/linuxcnc/configs/1st_LinuxCNC_Bridgeport'
Machine configuration file is '1st_LinuxCNC_Bridgeport.ini'
INIFILE=/home/emc/linuxcnc/configs/1st_LinuxCNC_Bridgeport/1st_LinuxCNC_Bridgeport.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./1st_LinuxCNC_Bridgeport.hal
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:04:04.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:04:04.0
config string '0 out'
Running HAL shutdown script
Killing task linuxcncsvr, PID=2857
hm2_5i25.0: dropping AnyIO board at 0000:04:04.0
hm2/hm2_5i25.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.8
TASK=milltask
HALUI=halui
DISPLAY=axis
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./1st_LinuxCNC_Bridgeport.hal:121: parameter or pin 'hm2_5i25.0.encoder.03.counter-mode' not found
2857
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0xb6fba000
Warning: Spoiler!
Last edit: 09 Feb 2017 00:22 by andypugh. Reason: Added spoiler tags (code tags don't work any more)
08 Feb 2017 23:30 #87618
Now we're coockin !!!
Now you are on the right track, as it is communicating with 7i77 and finding the analog outs. It just looks like you do not have any encoder connected to encoder port 4. You can just ommit that line and move on, until you connect the encoder to that line.
Try that and report back.
08 Feb 2017 23:32 - 08 Feb 2017 23:33 #87619
shows that it should be all working now
your configuration has an error:
possibly a leftover from a a parallel port configuration
also rather than dump of all of dmesg here
Just start linuxcnc from a terminal window and post the error messages in the terminal here
Last edit: 08 Feb 2017 23:33 by PCW.
09 Feb 2017 15:45 #87667
by new2linux
PCW Many thanks! The linux is on a computer that is not connected to the internet, so a memory stick is the way it works. I have used the copy and past to get a file (in a text editor) saved on the linux machine usb stick and go to win 10 machine for internet. Now at this point I can attach if I add the .txt to the file name (as seen below) or it appears to be copy and paste, like what I was doing here. So maybe try attachment for change, please comment.
tommylight many thanks to you as well for your thought and encouragement!
If I do not have 110 v power on the error code will be 56.
IF power up the 121 code is displayed as the files show.
09 Feb 2017 15:53 #87669
What is your "num_encoders" set to?
Moderators: piasdom
Time to create page: 0.358 seconds
