Configuring LinuxCNC
StepConf Wizard
X-carve linux cnc upgrade tuning
Thank you received: 0
16 May 2016 22:43 - 17 May 2016 01:47 #74784
by mrbishop
ive been tinkering with the stepconf stuff and its almost like there aren't enough steps per inch. when the SPI is over 2000 it moves slow but the scale is way off. no matter how i adjust that it pulsates at low speeds when the movement is spaced properly.
UPDATE: i changed the stepper driver from 16 to 1 i'm assuming thats the scale and its moving much better now. i think i have an issue with Y racking now. -_-
updated config with proper movement distances (machine is moving the right distance now X Y Z)
Last edit: 17 May 2016 01:47 by
mrbishop.
StepConf Wizard
Time to create page: 0.354 seconds
