Forum Header
X-carve linux cnc upgrade tuning
16 May 2016 18:07 #74763
by mrbishop
i will try this tonight as well. do you have a suggested micro step setting? (currently at 8)
Replied by mrbishop on topic X-carve linux cnc upgrade tuning
Seems to me that you don't have enough steps per inch. As it is right now if you are moving at 0.5 ipm (slow move) then linuxcnc will send a step pulse about once a second so you would definitely see start stop operation. It would move about 0.01" each second with an abrupt 0.01" step each second. This would get even worse at slower speeds.
I prefer to have my machines set up so that I get about 0.001" per step even if that means I need higher microstepping. In your case I would increase the gear ratio from the motors or the microstepping or both as required/applicable. I know that I don't actually get 0.001" resolution by increasing the microstepping but it does help with start stop jumps as you are describing.
- LearningLinuxCNC
- Thank you received: 61
16 May 2016 18:28 #74766
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic X-carve linux cnc upgrade tuning
If you are just going to adjust microstepping then to get to approximately 0.001" steps you would need 1/64 microstepping. This would give 1040 steps per inch. If the torque is too low with 1/64 then try 1/32 microstepping. Keep in mind that your actual true resolution is going to be approximately 1/16" as you have with your current setup because 130 steps per inch/ 8 microsteps means 16.25 full steps per inch. Actual resolution is equal to one full step of the stepper motor. Microsteps will only help with smoothing out the motion at low speeds.
- Online
- Thank you received: 1369
16 May 2016 18:39 #74768
Replied by Todd Zuercher on topic X-carve linux cnc upgrade tuning
The stepper machines I am useing are all set up for 1/2 stepping with steps/inch of 1000-2000 (2.5-5 revolutions/inch). (I would recommend trying to increase your gear ratios to something similar .)
So right now one full revolution of your step motor moves your axis more than 12 inches?
(126.352steps/inch)/8X microstepping=15.794whole steps/inch, (200step/rev)/(15.794steps/inch)=12.663inches/rev
If this is in fact the case, it is no wonder you don't have smooth movement. (a 10 or 20:1 gear box would be money well spent)
16 May 2016 18:57 #74769
by mrbishop
my machine is set to 1/8 (if i'm not mistaken) on GT2 pulleys and belts. one revolution shouldn't be much more than an inch of movement but i can get exact measurements.
- Online
16 May 2016 19:28 #74772
What size are your sprockets? Is it one belt directly driven by the motor, or multiple belts/sprockets/shafts?
16 May 2016 19:36 - 16 May 2016 19:36 #74773
by mrbishop
direct drive. 2mm pitch on the belts GT2 pulleys are 20 tooth
this may help clear some things up grab cad repo
Last edit: 16 May 2016 19:36 by mrbishop.
- Online
16 May 2016 19:54 #74774
In that case shouldn't one revolution move 40mm (or 1.5748inches) and with 1/8 stepping your scale should be about 1016steps/inch. (not the 126.352step/inch in your ini above.)
- LearningLinuxCNC
16 May 2016 20:00 #74775
by LearningLinuxCNC
I agree entirely with Todd. Higher than 1/8 micro stepping with this belt drive configuration will not improve the performance. Please disregard my previous posts as they were based on incorrect information.
16 May 2016 21:21 - 16 May 2016 21:28 #74780
by mrbishop
the more i adjust the settings the more i'm thinking that this may just be how the machine moves
the only setting on the drivers i haven't messed with is something refereed to as decay. i'm going to try it and see if it makes any difference.
update: no difference to be seen
could this be caused by my stepper drivers?
Last edit: 16 May 2016 21:28 by mrbishop.
16 May 2016 21:31 - 17 May 2016 00:22 #74781
by mrbishop
also if anyone wants to schedule a google hangouts video call perhaps that may help shed light. i appreciate all the help everyone!
hangouts email
hangouts email
Warning: Spoiler!
This email address is being protected from spambots. You need JavaScript enabled to view it.
Last edit: 17 May 2016 00:22 by mrbishop.
