Forum Header
X-carve linux cnc upgrade tuning
14 May 2016 06:22 #74639
by Rick G
Replied by Rick G on topic X-carve linux cnc upgrade tuning
You might start here...
forum.linuxcnc.org/forum/18-computer
The first few post should help a lot with latency.
And as posted above dramatically reduce your acceleration.
Rick G
Rick G
14 May 2016 21:55 #74658
by mrbishop
Replied by mrbishop on topic X-carve linux cnc upgrade tuning
Replaced the nvidia you with an ati one and I'm under 50k max latency. Going to try to dedicate a core or 2 . Well I'm going to try anyway.
15 May 2016 01:14 - 15 May 2016 01:19 #74669
by mrbishop
made some progress. played with isolating cores. switched back to my older pc (onboard GPU) which i built for my cnc but was getting over 200k latency. isolated a core and was around 13k..... added the parallel port PCI card in.... 200k
looks like the parallel port PCI card is my bottleneck.
can someone suggest a PCI or PCI express parallel port card? links?
pc picture tax
pc picture tax
Last edit: 15 May 2016 01:19 by mrbishop.
15 May 2016 04:41 - 15 May 2016 04:53 #74673
by Rick G
Take a look here...
forum.linuxcnc.org/forum/18-computer/189...-parallel-port-cards
You could also look at a Mesa 5i25...
mesaus.com/index.php?route=product/produ...ath=62&product_id=51
What version of linuxcnc are you using?
How did you install the parallel port card?
Have you tried reducing the acceleration yet?
Rick G
Rick G
Last edit: 15 May 2016 04:53 by Rick G.
15 May 2016 21:51 #74695
by mrbishop
movement acceleration wise is better now that i reduced my accel to 4. however at really slow speeds i moves with a pulse as in the videos. no smooth motion. move stop move stop move stop. so its not that its slow its that its pulsing.
version of linux cnc is that latest on the web site. i think it was the February release.
as for installing the card i just physically installed it in to the PCI slot on the motherboard.
15 May 2016 22:11 #74697
Which videos?
If you put a halmeter on stepgen.N.counts, do the counts increase between pulses, or is it a pulse every time the count increments?
Replied by andypugh on topic X-carve linux cnc upgrade tuning
movement acceleration wise is better now that i reduced my accel to 4. however at really slow speeds i moves with a pulse as in the videos..
Which videos?
15 May 2016 22:39 #74698
by mrbishop
15 May 2016 23:13 #74699
Yes. It allows you to watch the values of individual HAL pins (and signals and params).
In the Axis GUI it is available from the "Machine" menu. In other GUIs it might be in a menu, to it might not.
You can start it in any GUI from the command-line with "halcmd loadusr halmeter"
There is also Halscope that lets you plot pin values against time, (HAL - Osciloscope) which can be a useful tuning tool.
forgive my ignorance but is the halmeter part of the linux cnc software.
15 May 2016 23:39 #74702
by mrbishop
ok i'll have a look for it in abit.
trying not to be so lost in all of this.
15 May 2016 23:52 #74703
by mrbishop
so the pulse is every time the count increments.
Which videos?
Time to create page: 0.265 seconds
