Forum Header
Mach3 XML and Stepconfig issues.
- Thank you received: 1369
26 Apr 2017 14:09 - 26 Apr 2017 14:10 #92146
Replied by Todd Zuercher on topic Mach3 XML and Stepconfig issues.
to get into the setup menu on Gmoccapy the code is 123 (or 1234). I don't think it will do you much good though, the min resolution on gmoccapy is 979 x 750, To change it, it must be rewritten using the glade editor. (there is a tutorial here
Gmoccapy 800x480 in Spanish.)
Last edit: 26 Apr 2017 14:10 by Todd Zuercher.
26 Apr 2017 14:10 #92147
by tecno
Replied by tecno on topic Mach3 XML and Stepconfig issues.
Hmmmm.
Looks like I have to bite the bullet and exchange display.
26 Apr 2017 14:11 #92148
Did you try the Mini or TKlinuxcnc UIs?
26 Apr 2017 14:13 #92149
by tecno
Dont know what that is and what to do.
26 Apr 2017 15:02 #92151
You might find this manual-page handy:
linuxcnc.org/docs/2.7/html/config/ini-config.html
Replied by andypugh on topic Mach3 XML and Stepconfig issues.
26 Apr 2017 20:57 #92170
by tecno
Will let display issues rest and trying to solve other problems.
My lathe is homing in wrong direction, want it to have X/Z on my right-hand against me and set machine 0 there as I am used to do so.
Sorry to say but I can not wrap my head around this, so can you guys help me out.
Jogging with arrow keys on keyboard *tool* is moving as arrows, DRO's show correct 'direction'.
Puzzled Mach user trying to get this working, step by step I will get to my goal and be running LCNC on my lathe.
Cheers
Bengt
Cheers
Bengt
27 Apr 2017 00:29 #92176
Configure the Z axis so that 0 is tailstock end and chuck end is - (however many units of your choice)
Then set the home_search velocity positive.
Though: my previous lathe homed X first to max diameter then homed towards the chuck. That meant I didn't have to worry about moving the tailstock out of the way (the current lathe can home without moving)
27 Apr 2017 08:22 #92186
by tecno
That is what I am trying to do, but where to set these numbers?
There must some place to tell the system to home X towards me and Z to tailstock.
Is it in INI or in HAL? Can not find any documentation specifying how to do this.
27 Apr 2017 09:33 - 27 Apr 2017 09:33 #92190
I think that you should be able to put in the required numbers in stepconf, or you can edit the INI.
Have you found this page, where all the docs are listed?
The stepconf documentation mentions making the home search velocity negative to change the homing direction:
linuxcnc.org/docs/2.7/html/config/stepco...#_axis_configuration
There is rather more detail on the subject here:
linuxcnc.org/docs/2.7/html/config/ini-homing.html
Last edit: 27 Apr 2017 09:33 by andypugh.
27 Apr 2017 10:08 #92191
by tecno
Yes I have found all those pages, but as a bloody foreigner with other native language it is very hard to read these documents that are so --- how should I put it, do not get me wrong here --- complex thus not easy to read and understand.
"home search velocity negative to change the homing direction" this is what I was looking for and hopefully I can get this working now.
Will test this right away now.
Time to create page: 0.101 seconds
