Home switches wiring / setup
For my MPCNC (Mostly Printed CNC) machine, I'm setting up LinuxCNC for the first time.
I'm pretty far with the basic HAL file and INI file.
The machine has 5 motors and 5 drivers (2 for X, 2 for Y and 1 for Z).
I have 4 cheap switches on my machine (2 for X and 2 for Y), also used for auto squaring the Axis:
Now I can use up 4 inputs on my 5 Axis BOB, but it's also possible to use 1 input for all the switches right?
Which one is preferred and does one has advantages over the other?
And is this possible with the switches I got and how to wire it?
Thanks in advance!
You will need at least two (1 each for one side of the X and the same for Y) You might be able to do it with 3 inputs.
It's hard enough as it is. Personally I would go with separate switches for each one.
So if you are using a PPort you could use two of them. Or use a Mesa card.
Others brighter than me might be able to guide you better.
- Thank you received: 1370
Thanks for the reply. I wouldn't mind if simultaneously homing is not possible, but I think I will use 4 inputs for the 4 switches. I can always change it later, if I need another input.
As I said before and you were not convinced if you want gantry squaring you will need a switch on either side (they can also be used as limit switches) so in your case you will need 4 for two lots of gantry squaring\ plus one for the Z.
It would be helpful if you posted the hal and ini files.
For squaring a gantry he would need a minimum of two inputs (4 is not required). If the gantry is the Y axis, X and Z could share inputs with them selves and or the Y joints. So Z and Y1 and X1 could share a home input and X2 and Y2 could share. Limits are not nessisary or can also share the home inputs. The two gantry joints in a pair are the only ones that must have home inputs separate from each other, but not necessarily separate from other switches.
Todd
I am under the impression that he has two gantries ie. X and y are both gantries.
From his first post:-
If the switches are wired using normally open contacts then they would need to be wired in parallel instead of in series.
Clive S is right, it is a machine with 2 gantries:
I'm not sure if the switch are NO or NC, it has a S, V and G input.
So should I wire X1 + Y1 and X2 + Y2 in series or parallel?
I have no Z homing switch (yet).
I have attached my INI and HAL file
