Forum Header
Home switches wiring / setup
14 Feb 2022 12:46 #234815
by remon_v
Replied by remon_v on topic Home switches wiring / setup
Have you seen my reply a few post above? They solution is in the grounding I think.
The PP cable came with the BOB, so I assume it’s correct.
14 Feb 2022 13:05 - 14 Feb 2022 13:15 #234816
by Clive S
There are plenty of cables that don't have all the wires connected.
I would start from again connect the 24v to the bob connect 5v to the bob (forget the usb)
Re you saying grounding are you talking about earth or the -ve of the ps
I think there is a PPort tester as well. Do you have the PC with a PPort as there are com ports that are DB25 and look like a PPort
wiki.linuxcnc.org/cgi-bin/wiki.pl?Parallel_Port_Tester
Replied by Clive S on topic Home switches wiring / setup
Last edit: 14 Feb 2022 13:15 by Clive S.
14 Feb 2022 13:50 - 14 Feb 2022 14:00 #234823
by remon_v
Oké… I just did something stupid and fried the BOB by connecting the GND to the - from the 24V power supply…
I ordered a new one right away, this time a green version. I’m not happy with the connecting terminals of my blue BOB.
I download the PP tester and I disconnected it… I can push all the outputs, they turn green. I’m not sure how to trigger the inputs.
I also ordered USB A male breakout boards, so I can connect a 5V power supply to it…
Last edit: 14 Feb 2022 14:00 by remon_v.
14 Feb 2022 14:11 #234825
by Clive S
oops can't you get the magic smoke back in ?
I have never had any issues with those China bob's ever
re: I also ordered USB A male breakout boards, so I can connect a 5V power supply to it…
Not sure what you mean by the above.
You can use a buck converter to convert the 24vdc to 5v dc like the one in the pic a posted.
ground and -ve are two different things .
Please check the pp cable
- Thank you received: 1370
14 Feb 2022 14:33 #234828
Replied by Todd Zuercher on topic Home switches wiring / setup
To test inputs using the pp tester use a 470ohm resister to connect an input pin to a ground pin. The input pin should change state when grounded vs no connection. Likewise the input pin (parallel port side) on your BOB should float high (may or may not have it's own pull up voltage) and be pulled low to ground when active. I've seen some wonky cheap BOBs that didn't have sufficient pull ups to work correctly with some parallel ports and I had to add a pull up from a 5v source.
14 Feb 2022 14:41 #234830
by remon_v
From what I see the terminals from the green BOB look better… with blue I had some trouble with the screws.
I mean these break out boards for USB:
a.aliexpress.com/_mOmejyo
I have a 5V power supply and a buck converter, but I think I will use a 5V power supply.
14 Feb 2022 14:46 #234832
by remon_v
When I measured voltage from the inputs from the BOB:
9V when in open state and 0V in closed state, that should be fine right?
Are the GND’s on the BOB connected? I have 3, 1 on the inputs side, 1 on the 12/24V side (which I connected to - of my 24V power supply) and 1 next to the PC5V outputs.
The GND on the inputs side, next to P15, should I connect this to something?
14 Feb 2022 14:48 #234833
by Clive S
If you are using a 5v ps don't use the usb port
look at the pic on my bob and use those screw terminals for -ve and +ve 5v input.
14 Feb 2022 14:52 #234834
by remon_v
Yes I see… and you’ve connected the GND next to the PC5V with the GND next to P15, I think that will resolve my problem?
14 Feb 2022 15:09 #234838
by Clive S
re;
9V when in open state and 0V in closed state, that should be fine right? YES
The GND on the inputs side, next to P15, should I connect this to something? YOU DON'T NEED TO
Please don't use the term GND it very confusing as that could mean earth ground.
Connect the 5V looking at the bob with the relay on RH side the last 3 terminals are -ve 5v 5v
Time to create page: 0.206 seconds
