× Forum Header
Home switches wiring / setup
09 Feb 2022 10:30 - 09 Feb 2022 12:28 #234382 by Clive S
Replied by Clive S on topic Home switches wiring / setup
HOME_OFFSET = 0.0 (this is for adjusting the gantry square ie 0.5mm)
HOME_SEARCH_VEL = 30 (this is the velocity it will travel to home switch, changing the sign will reverse the direction of travel)
HOME_LATCH_VEL = 5 ( this is to back of the switch ie the switch should then be open, (changing the sign will reverse the direction of travel)
HOME_SEQUENCE = -0 (this has to be a -ve number and must be the same for both joints and is the sequence of the homing process) I would use -1 for this as zero is generally for the Z ie to lift it out of the way)
I hope this helps. You can see that the home switch is activated then reverses and then reopens the switch again.
When testing bring down the speed to a low value to see what is going on.
On another note in the ini file
[AXIS_X]
MAX_VELOCITY = 50.0
MAX_ACCELERATION = 180.0
[JOINT_0]
HOME = 0.0 (this is the final home position)
MAX_VELOCITY = 50.0 (I think this should be 25% higher than AXIS_X MAX_VELOCITY)
MAX_ACCELERATION = 180.0 (Same here)
STEPGEN_MAXACCEL = 225.0
Last edit: 09 Feb 2022 12:28 by Clive S.
09 Feb 2022 12:17 #234390 by remon_v
Replied by remon_v on topic Home switches wiring / setup
I think I'm going to use different endstops, which has a NO or NC possible connection... Then I will wire them up parallel, so NO.
09 Feb 2022 12:34 - 09 Feb 2022 12:39 #234391 by remon_v
Thanks! So to confirm, I've changed the following (for all the joints):
AXIS_X]
MAX_VELOCITY = 50.0
MIN_LIMIT = -0.001
MAX_LIMIT = 300.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 300.0
MAX_VELOCITY = 75.0 (25% higher)
MAX_ACCELERATION = 225.0 (25% higher)
SCALE = 50.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_LATCH_VEL = 5
HOME_SEQUENCE = -1 (from -0 to -1 and for Y from -1 to -2)
Last edit: 09 Feb 2022 12:39 by remon_v.
09 Feb 2022 13:04 #234392 by Clive S
That looks about correct .
Re:
HOME_SEARCH_VEL = 30 ( I would make this a lot smaller for testing so as to see what is going on)
HOME_LATCH_VEL = 5 ( this might need a -ve sign if you have to reverse direction to back off switch)
I have used 2 PPorts just for the extra inputs in the past.
I would suggest just getting one axis working first.
10 Feb 2022 08:15 - 10 Feb 2022 08:20 #234475 by remon_v
Thanks Clive!
I'll wire X1 and Y1 on 1 input and X2, Y2 and Z on another input. How do I need to set it up in the HAL file?
This is what I have now:
net home-x1 <= parport.0.pin-10-in
net home-x2 <= parport.0.pin-11-in
net home-y1 <= parport.0.pin-12-in
net home-y2 <= parport.0.pin-13-in
Last edit: 10 Feb 2022 08:20 by remon_v.
10 Feb 2022 09:41 #234478 by Clive S
Thanks Clive!
I have never done it as you suggest. I think it was Todd that mentioned that.
For a start I would just get one axis working so that you can get the correct search and latch direction sorted in the ini file.
net home-x1 <= parport.0.pin-10-in (Just for info the <= are not used or required in the hal file they are there just for an indication of the signal flow)
At this stage you need to hand edit the files.
12 Feb 2022 14:05 - 12 Feb 2022 17:28 #234640 by remon_v
Oke, so I'm at the stage I can start testing.
I've hooked up 2 NO switches to P10 and P11, as Todd said if I wire it up parallel when the switches are NO.
So I thought, hook up 2 switches to act for all the switches.
When I start-up LinuxCNC and press the 'home all'  button, Z starts moving as expected, so I hand press the P11 switch to close the circuit but nothing happens...
I've checked the switches with my multimeter, they work fine.
What am I doing wrong?
I've attaches the INI and HAL file.
Thanks in advance
Last edit: 12 Feb 2022 17:28 by remon_v.
12 Feb 2022 19:23 #234656 by Clive S
might be sticking my neck out but try this:- inverting the pin
net home-x1-y1 <= parport.0.pin-10-in-not
net home-x2-y2-z <= parport.0.pin-11-in-not
12 Feb 2022 19:47 - 12 Feb 2022 20:04 #234657 by remon_v
I tried that already, but no luck... if I understood correctly, you have to invert the pin when the switches are NC.
The steppers are moving correctly :D
Last edit: 12 Feb 2022 20:04 by remon_v.
12 Feb 2022 21:55 #234662 by Clive S
Are you aware of hal and hal watch
Time to create page: 0.487 seconds
