Forum Header
Home switches wiring / setup
07 Mar 2022 21:43 #236604
by remon_v
Replied by remon_v on topic Home switches wiring / setup
After I got the new BOB I tried all modes. Good to know SPP is best... not sure what you mean with X-mode?
Tomorrow my PC arrives, hope it was a PC problem and I can finally get my machine to work
Oke I thought the BOB protects the PC via the octocouplers....It is possible that the parallel port was damaged when you ruined the other BOB.
- Thank you received: 5949
07 Mar 2022 21:59 #236605
Replied by tommylight on topic Home switches wiring / setup
Most cheap BOB's do not have optocouplers at all, just some buffering or transceivers.Oke I thought the BOB protects the PC via the octocouplers....
The following user(s) said Thank You: remon_v
- Thank you received: 1370
08 Mar 2022 13:43 #236672
Replied by Todd Zuercher on topic Home switches wiring / setup
Linuxcnc's parallel port driver has 3 possible modes of operation out, in and X. Out has 12 outputs and 5 inputs. In has 4 outputs and 13 inputs. And X has 8 outputs and 9 inputs. X-mode may not work with all parallel ports, and it must be configured for SPP,. I've set up a few machines that used it. The biggest downside to X-mode, is that there are no breakout boards on the market that support it. So you either have to roll your own or run without.
The following user(s) said Thank You: tommylight, remon_v
08 Mar 2022 20:01 - 08 Mar 2022 20:16 #236705
by remon_v
YESSSSSS! It works!
I just recieved my 'new/old' PC, attatched everything like normal.... and it works... finally!
This PC (Core2duo E8500) is older than my other one (JQ1900B-ITX) but it seems to be faster... and I just plugged in my SSD and that works too right out of the box (thanks to Linux)
Everyone thanks for the help!
Last edit: 08 Mar 2022 20:16 by remon_v.
The following user(s) said Thank You: tommylight, Clive S
08 Mar 2022 22:14 #236718
by Clive S
Replied by Clive S on topic Home switches wiring / setup
10 Apr 2022 09:30 #239806
by remon_v
I finally got my machine working, but now I need to tweak settings like max velocity and acceleration. How can I best tweak them?
10 Apr 2022 21:35 #239861
Replied by andypugh on topic Home switches wiring / setup
Increase them until you get scared, then back off a bit
11 Apr 2022 12:51 - 11 Apr 2022 12:52 #239918
Best to hand edit where they are set in the ini file.
But for testing and tweaking there is a way to temporarily change their values without restarting Linuxcnc after every change using the "ini.x" halpins and the setp command. Use halshow to look up the exact pin name, then you can type the setp command, pin name and value in the halcommand line at the bottom.
Last edit: 11 Apr 2022 12:52 by Todd Zuercher.
Time to create page: 0.281 seconds
