Arduino based USB Pendant for Linuxcnc
28 Oct 2012 17:21 - 28 Oct 2012 17:22 #25924 by ArcEye
You can get laser-printable plastic film (sold as waterproof paper) which might work well.
I bought a few sheets from eBay a while ago (it's rather expensive by the ream)
That sounds ideal, I don't have access to a colour laser printer unfortunately.
I am going to print mine on some of that glossy printer paper made for photos.
That is essentially what I used, it just had a self adhesive backing to it
ArcEye do you still have the keypad graphic you made and if so can you post it?
Yes, it is in OpenOffice .odt format, zip attached
File Name: keypad.zip
File Size:14 KB
Last edit: 28 Oct 2012 17:22 by ArcEye.
28 Oct 2012 17:54 #25928 by BigJohnT
Can you plastic laminate it after printing with one of those cheap thermal laminators?
28 Oct 2012 18:02 #25929 by ArcEye
That was my idea, trouble is that laminating makes it very stiff, don't know if you can get different grades of sleeve and use one which protects but leaves it fairly flexible.
28 Oct 2012 18:08 #25930 by BigJohnT
I wonder what would happen if you only laminated the top and not the bottom? Just looking at McMaster Carr for no logical reason and they have single sided 0.006" lamination up to 0.020" double sided so yes there is different grades.
28 Oct 2012 18:28 #25932 by ArcEye
I have not seen single sided laminating sleeve, presumably the back does not adhere and can be peeled off afterwards?
I'll have a look at what is available over here
28 Oct 2012 18:52 #25934 by andypugh
Self-adhesive library film?
www.staples.co.uk/bts-offers/bts-office-...cover-film-45cm-x-1m
Or perhaps print on to the back of some OHP film (reversed) and put a white layer underneath?
28 Oct 2012 19:06 #25937 by ArcEye
That looks like the best bet so far, you could actually wrap it under the keypad before sticking it down to the box lid and it should protect the whole thing.
Then it won't matter what paper and printing method you use, within reason
31 Oct 2012 23:00 #26143 by Miselph
I did create many more pins and try to display much more system data originally, but found that the poor little arduino just could not cope.
Hi ArcEye,
I have to say that I am surprised by the limitations you have encountered. I have always found the arduino to be surprisingly powerful for what it is but sometimes the software libraries leave quite a bit to be desired.
What speed are you running the i2c bus at? The default is (or used to be) 100khz which is quite slow when you are trying to transfer any amount of data to the screen and could well account for much of the lag you have encountered. You can increase the bus speed to 400khz by changing a line in the Wire class (see this post )
The other thing I was wondering; I see that you are running the serial at 9600. Is there any reason this cannot be increased?
The following user(s) said Thank You: ArcEye
01 Nov 2012 17:11 #26178 by ArcEye
Hi
Thats interesting, thanks I will try that when I get the chance.
In theory yes, but I had read a lot of reports of problems using the SoftwareSerial libraries above 9600.
I have not tried increasing the BAUD rate, because it wasn't the delivery of the packets that caused problems rather the display of the info therein.
If the i2c bus speed change has a dramatic effect, that could be worth doing
01 Nov 2012 18:38 #26181 by andypugh
I am running serial at 1Mb out of my Arduino into a Mesa soft-UART,
Time to create page: 0.163 seconds
