Rockpro64 with 7i76e
02 Sep 2019 23:01 #143966
by acondit
Rockpro64 with 7i76e was created by acondit
I have a Rockpro64 4gb and a mesa 7i76e. I currently have linux-stable-rt-4.19.31-rt18 plus linuxcnc installed.
The rockpro64 has a gigabit ethernet port. I assume (dangerous thing I know) that I should use the gigabit port to hook up the 7i76e. Does that sound correct?
The next problem is, if I want to run headless (ssh) should I buy the wifi module for the rockpro64 or would it work to buy a USB3 to ethernet adapter to hook to my network?
Alan
Alan
03 Sep 2019 05:42 #144044
by pl7i92
Replied by pl7i92 on topic Rockpro64 with 7i76e
i use ETH mesa alot and the 3USD usb-> Eth workes perfect to get things from WWW
the Gigabit ETH is not a problem so you can move on
did you get a SIm mashine started so you know the Board is good on rt kernel
yopu shoudt follow the gnipsel.com setup to get the master 2.9 uspace on it
03 Sep 2019 20:11 #144082
USB to WiFi is another option. Those are pretty cheap:
thepihut.com/products/official-raspberry...riant=20063145197630
Replied by andypugh on topic Rockpro64 with 7i76e
04 Sep 2019 06:35 #144131
by pl7i92
the wifi makes itr very flex to position the mashine like Plasmas to a save place and no real connect to the main shop needed
05 Sep 2019 23:37 #144292
by acondit
Replied by acondit on topic Rockpro64 with 7i76e
I just tried to start linuxcnc. I set jumper w3 up instead of down and the ini file is set for ip address 10.10.10.10. However, I got an error network unreachable.
Any suggestions appreciated.
05 Sep 2019 23:42 #144296
Can you ping the card?
I tend to test without LinuxCNC when setting up.
With less in the system it is easier to see what isn't working.
halrun
loadrt hostmot2
loadrt hm2_eth {experimental parameters}
06 Sep 2019 00:04 #144298
by acondit
Ping reports network unreachable.
When I tried the
halrun
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" CONFIG="num_encoders=1 num_stepgens=5 sserial_port_0=20xxxxxx"
It reports unknown parameter 'CONFIG="num_encoders=1 num_stepgens=5 sserial_port_0=20xxxxxx"'
wait_pid failed /usr/bin/rtapi_app/hm2_eth
rtapi_app exited without becoming ready.
When I tried the
halrun
loadrt hostmot2
06 Sep 2019 00:22 - 06 Sep 2019 00:23 #144300
Replied by PCW on topic Rockpro64 with 7i76e
If ping doesn't work, it means your network is not setup to access 10.10.10.10
That's not really related to LinuxCNC but a basic network setup issue
Did you read the hm2_eth manual page? it has a bit about network setup
Also if your computer has a network setup GUI, set the host Ethernet port
to a fixed (static) IPV4 address of say 10.10.10.20
Last edit: 06 Sep 2019 00:23 by PCW.
06 Sep 2019 06:32 #144325
by pl7i92
To find the ethernet adapter name
ip link show
or
ip a
sudo gedit /etc/network/interfaces
auto enp0s25 << change to match your interface name
iface enp0s25 inet static
address 192.168.1.100 << if you use the mesa card 192.168.1.121 ip
netmask 255.255.255.0
broadcast 192.168.1.255
# gateway 192.168.1.1
# dns-nameservers 8.8.8.8 8.8.4.4
ip link show
or
ip a
11 Sep 2019 00:27 #144760
lower case.
lower case.
Time to create page: 0.092 seconds
