Rockpro64 with 7i76e
07 Oct 2019 22:42 #147375
by acondit
Replied by acondit on topic Rockpro64 with 7i76e
acondit@rockpro64:~$ sudo ping 10.10.10.10
[sudo] password for acondit:
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
From 10.10.10.11 icmp_seq=1 Destination Host Unreachable
From 10.10.10.11 icmp_seq=2 Destination Host Unreachable
From 10.10.10.11 icmp_seq=3 Destination Host Unreachable
^C
--- 10.10.10.10 ping statistics ---
6 packets transmitted, 0 received, +3 errors, 100% packet loss, time 96ms
pipe 4
^C
pipe 4
07 Oct 2019 22:48 #147377
Replied by PCW on topic Rockpro64 with 7i76e
Is the 7I76e set for 10.10.10.10? (W2 down W3 up) and has the 7I76E been power cycled since changing the IP address jumpers?
07 Oct 2019 22:57 #147378
by acondit
Yes and yes.
When I power cycle it, I see the yellow led flash followed by the red led and then the three green leds cycle once 1,2,3.
when I put the jumpers w2 up and w3 down the leds cycle like above, wait and then cycle again.
With them back w2 down and w3 up and a power cycle they just go through the cycle once.
07 Oct 2019 23:12 #147383
Do you have a link light on the 7I76E (yellow LED on RJ-45 connector)
also can you run "ip a" again in case there have been any other changes
07 Oct 2019 23:21 #147386
by acondit
No, however I have both the yellow and the green at the RJ45 on the RockPro64 board. I swapped a different cat 5 cable now I have a green LED at the 7i76e RJ45 still no yellow.
acondit@rockpro64:~$ sudo ping -4 -c4 10.10.10.10
4 packets transmitted, 0 received, +3 errors, 100% packet loss, time 82ms
pipe 4
acondit@rockpro64:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 7e:84:f6:98:86:93 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.11/24 brd 10.10.10.255 scope global eth0
inet6 fe80::7c84:f6ff:fe98:8693/64 scope link
3: enx8cae4ce13faf: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 8c:ae:4c:e1:3f:af brd ff:ff:ff:ff:ff:ff
inet 10.0.1.12/24 brd 10.0.1.255 scope global dynamic noprefixroute enx8cae4ce13faf
valid_lft 83963sec preferred_lft 83963sec
inet6 fe80::7a34:68ae:fdbf:8ae5/64 scope link noprefixroute
pipe 4
07 Oct 2019 23:28 #147387
I dont think its the issue but in any case you should disable ipv6 on the realtime link
You might also connect the 7I76E to your router or some other known good 100 BT connection and see if you get both yellow and green lights on the 7I76Es RJ45
07 Oct 2019 23:34 #147389
by acondit
should I set the speed to 100 on the network connection?
07 Oct 2019 23:35 #147390
Yes (that may be why you get no Yellow light)
07 Oct 2019 23:39 #147391
by acondit
The selection was already at 100 and greyed out so you couldn't change it.
07 Oct 2019 23:40 #147392
by acondit
By disable ipv6 you mean check the box that says require ipv4 for this connection?
Time to create page: 0.290 seconds
