Rockpro64 with 7i76e
Thanks.
I crashed my uSD and I am now trying to rebuild a new version on Buster. I really like the Desktop version. I had a version of linux-5.0 running on stretch but they have changed some things. I can boot it via ssh from my mac but the rt version won't display on my HDMI monitor.
Alan
I built linuxcnc (userspace) using John Thornton's instruction for the raspberry pi4b. I was able to start linuxcnc via ssh from my mac and got the config selector window. I didn't have my 7i76e plugged in because I haven't bought a USB3 to ethernet converter. Now that I have rt_preempt and linuxcnc both apparently running I will have to do that.
"sudo dpkg -i linuxcnc-uspace_2.8.0~pre1_arm64.deb"
(Reading database ... 185225 files and directories currently installed.)
Preparing to unpack linuxcnc-uspace_2.8.0~pre1_arm64.deb ...
Unpacking linuxcnc-uspace (1:2.8.0~pre1) over (1:2.8.0~pre1) ...
dpkg: dependency problems prevent configuration of linuxcnc-uspace:
linuxcnc-uspace depends on python-gtksourceview2; however:
Package python-gtksourceview2 is not installed.
linuxcnc-uspace depends on python-vte; however:
Package python-vte is not installed.
linuxcnc-uspace depends on gstreamer1.0-plugins-base; however:
Package gstreamer1.0-plugins-base is not installed.
linuxcnc-uspace depends on python-xlib; however:
Package python-xlib is not installed.
The instructions say:
but the lines are not in debian/configure so I can't delete them.Now edit debian/control.bottom.in and remove the following lines
python-vte,,
So does anybody have any suggestions???
I just ordered the usb3 to ethernet adapter. I should have it by the end of the week. I made sure to order one that people say works with linux. It is made by a company called "Plugable".
I thought I had set up userspace but I notice in the error messages "Using posix realtime". Is this correct? Any help on what I have done wrong?
Below is my /etc/network/interfaces file and the error messages from linuxcnc and the /home/acondit/linuxcnc_print.txt.
#FROM file etc/network/interfaces:
source /etc/network/interfaces.d/*
# Network is managed by Network manager
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
address 10.10.10.20
netmask 255.255.255.0
broadcast 10.10.10.255
# gateway 192.168.1.1
# dns-nameservers 8.8.8.8 8.8.4.4
LINUXCNC errors:
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/acondit/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
Starting LinuxCNC...
Found file(REL): ./my_LinuxCNC_machine.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
iptables v1.8.2 (nf_tables): CHAIN_ADD failed (No such file or directory): chain INPUT
hm2_eth: ERROR: Failed to create iptables chain hm2-eth-rules-outputhm2_eth: WARNING: Unable to restrict other access to the hm2-eth device.
This means that other software using the same network interface can violate
realtime guarantees. See hm2_eth(9) for more information.
hm2_eth: ERROR: 10.10.10.10: Could not retrieve mac address
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./my_LinuxCNC_machine.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./my_LinuxCNC_machine.hal:9: /usr/bin/rtapi_app exited without becoming ready
./my_LinuxCNC_machine.hal:9: insmod for hm2_eth failed, returned -1
Running HAL shutdown script
hm2: unloading
LinuxCNC terminated with an error. You can find more information in the log:
/home/acondit/linuxcnc_debug.txt
and
as well as in the output of the shell command 'dmesg' and in the terminal
acondit@rockpro64:~$ cat /home/acondit/linuxcnc_print.txt
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
INIFILE=/home/acondit/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
- Thank you received: 5933
There seems to be something wrong with the network configuration. It looks you have the same IP on the computer as on the Mesa card.
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
Follow that to configure network.
- left click on the network manager on the bottom right side or upper right side where the clock and volume is.
- choose "edit connections"
- double click on the network you want to edit ( usually "wired connection X")
- click on the "IPv4 settings" tab
- choose "manual" on the "method" drop down menu
- click on "add"
- write the address as 10.10.10.11
- never use 10.10.10.1 or 10.10.10.10 for the above
- netmask should be left as is ( usualy 8 )
- gateway should always be 10.10.10.1
- additional DNS servers should be 10.10.10.1
when I get to :
Save, close
The save button is disabled
Did you manualy edit any of the network files before ?
ip a
report?
and what does
ping 10.10.10.10
report?
