Hardware latency tests, used PC's
- Topic Author
- Online
- Thank you received: 5983
18 Jun 2020 17:51 #172026
Replied by tommylight on topic Hardware latency tests, used PC's
apt list linuxcnc-uspace | awk '{print $2}'
shows
1:2.9.0~pre0.2228.gcda96a48f
The number behind pre0 is the build version, in my case 2228.
shows
18 Jun 2020 18:04 #172029
by seuchato
Replied by seuchato on topic Hardware latency tests, used PC's
OK, so, if the build No. is included in the package version, I suggest to stick with the package version. Any objections?
- Topic Author
- Online
18 Jun 2020 18:08 #172030
No.
Thank you.
Thank you.
19 Jun 2020 06:40 #172058
by seuchato
New version
Kindly have a look into it and let me know any bugs, amendments, ...
greez
chris
greez
chris
- Topic Author
- Online
19 Jun 2020 08:48 #172066
Sooooo close, but no cigar ..... yet.
- Menu works,
- Number of glxgears works,
- Open firefox with vimeo link works, maximise and play work,
- Base thread does not, does not change period and is active even when choosing not to use it. It sticks to 25000 no matter what.
- Open firefox with a youtube link works, but does not play nor maximise.
Nice work.
Do not worry about the link to much, it seems vimeo causes more load on the pc than youtube does, and that is good.
- Menu works,
Nice work.
- Topic Author
- Online
19 Jun 2020 09:00 #172068
Here are the results of a run, choose no base thread, but it is there and cutting the test short due to latency.
1592556201.hwAnd 1592556201.lat
1592556201.hw
General info:
ASRockLinuxCNC pc tests, version 20200620
, To Be Filled By O.E.M.
Bios version P1.40, dated 07/11/2012
CPU related data:
model name : Intel(R) Celeron(R) CPU G1620 @ 2.70GHz
cpu cores : 2
stepping : 9
cache size : 2048 KB
RAM:
RAM:
Maximum Capacity: 16 GB
GPU related data:
product: Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller
configuration: driver=i915 latency=0
Os related data:
PRETTY_NAME="Linux Mint 19.3"
Desktop: , Session:
Kernel related data:
Kernel 5.4.0-0.bpo.4-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Cpu idle driver: intel_idle
Keyboard & Mouse related data:
Number of mice: 2
Mouse 0 : PixArt USB Optical Mouse
Mouse 1 : ABBAHOME Mouse
Mice attached to USB:
Keyboards attached to USB:
LinuxCNC related data:
LinuxCNC version is: 2.9.0~pre0.2235.g8e7842fa9
Preparing for latency test:
Started glxgears No. 1
Started glxgears No. 2
Started glxgears No. 3
Started firefox with 'https://www.youtube.com/watch?v=Na44iMZUcZk'
Using glxgears, Started No.
Latency testing loop started Fri Jun 19 10:44:01 CEST 2020,
should end after Fri Jun 19 10:54:01 CEST 2020
command for latency test is:
su cnc -c "latency-histogram --sbinsize 1000 --nox 2>&1 | tee 1592556201.lat &"
done command, retval = 0
Note: Using POSIX realtime
0 secs base min: -8.400 uS max: 6.600 uS sdev: 0.500 uS
0 secs servo min: -4.000 uS max: 5.500 uS sdev: 0.800 uS
2 secs base min: -8.400 uS max: 6.600 uS sdev: 0.500 uS
2 secs servo min: -4.000 uS max: 5.500 uS sdev: 0.800 uS
3 secs base min: -8.400 uS max: 6.600 uS sdev: 0.500 uS
3 secs servo min: -4.000 uS max: 5.500 uS sdev: 0.800 uS
4 secs base min: -9.200 uS max: 8.500 uS sdev: 0.500 uS
4 secs servo min: -4.000 uS max: 5.500 uS sdev: 0.800 uS
Unexpected realtime delay on task 0 with period 25000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
[0K
Remaining 0d 0h:9m:55s, press ^C to abort...
6 secs base min: -24.500 uS max: 26.600 uS sdev: 0.700 uS
6 secs servo min: -41.800 uS max: 41.900 uS sdev: 1.500 uS
7 secs base min: -24.500 uS max: 26.600 uS sdev: 0.700 uS
7 secs servo min: -41.800 uS max: 41.900 uS sdev: 1.500 uS
9 secs base min: -24.500 uS max: 26.600 uS sdev: 0.700 uS
9 secs servo min: -41.800 uS max: 41.900 uS sdev: 1.400 uS
10 secs base min: -24.500 uS max: 26.600 uS sdev: 0.700 uS
10 secs servo min: -41.800 uS max: 41.900 uS sdev: 1.500 uS
Useless to proceed, read the relevant part in 1592556201.lat
Cleaning up..| ......Closing browser firefox with WID of
bye.
19 Jun 2020 13:28 #172078
by seuchato
Tom
new version:
- removed option to choose webpage, as I could not get youtube to start
+ basethread can now be disabled
+ basinterval can now be set
+ logged swap usage
+ states now, if HD is rotational or not
+ only last two lines containing latency data are now attached to xx.hw file
+ some cleanup and beautifying of outputs
Again: kindly check and report
greez
chris
new version:
+ logged swap usage
greez
chris
19 Jun 2020 13:58 #172079
by seuchato
That is meant to be a feature, not a bug .
My strong believe is, any realtime delay renders a candidate machine useless unless the cause of the realtime delay can be found and eliminated. Am I wrong? If so, I will add an option to continue latency test despite realtime delays.
greez
chris
1592556201.hw... 4 secs servo min: -4.000 uS max: 5.500 uS sdev: 0.800 uS Unexpected realtime delay on task 0 with period 25000 This Message will only display once per session. Run the Latency Test and resolve before continuing. [0K Remaining 0d 0h:9m:55s, press ^C to abort... 6 secs base min: -24.500 uS max: 26.600 uS sdev: 0.700 uS 6 secs servo min: -41.800 uS max: 41.900 uS sdev: 1.500 uS ... Unexpected realtime delay on task 0 with period 25000 Useless to proceed, read the relevant part in 1592556201.lat Cleaning up..| ......Closing browser firefox with WID of bye.
greez
chris
- Topic Author
- Online
19 Jun 2020 13:59 #172080
- Default run, works, exist on latency over 25000 as it should,
- Run with no base thread exits properly,
- Run with no base thread when pressing ctrl+c doe snot exit, see bellow,
- Run with base thread at 100000 does not exit cleanly,
- Run with base thread at 100000 when pressing ctrl+c does not exit, see below
----This is the bellow part:
After ctrl+c the terminal will continuously show this:It does not exit after several ctrl+c, has to be terminated.
So so close....
X Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 3 (X_GetWindowAttributes)
Resource id in failed request: 0x5c00002
Serial number of failed request: 18
Current serial number in output stream: 19
Resource id in failed request: 0x6600002
Resource id in failed request: 0x6400002
Resource id in failed request: 0x6800002
So so close....
- Topic Author
- Online
19 Jun 2020 14:02 #172081
Now it is working properly as far as this is concerned.
Thank you very much, nice work.
The thing is i did not choose a base thread to run, just the servo thread, but it was still using the base thread.
greez
chris
