Hardware latency tests, used PC's
19 Jun 2020 14:07 #172082
by seuchato
I'll look into this. Works here. Must have to do with closing the browser window and the xdotools.
greez
chris
Replied by seuchato on topic Hardware latency tests, used PC's
- Default run, works, exist on latency over 25000 as it should,
- Run with no base thread exits properly,
- Run with no base thread when pressing ctrl+c doe snot exit, see bellow,
- Run with base thread at 100000 does not exit cleanly,
- Run with base thread at 100000 when pressing ctrl+c does not exit, see below
----This is the bellow part:
After ctrl+c the terminal will continuously show this:It does not exit after several ctrl+c, has to be terminated.X Error of failed request: BadWindow (invalid Window parameter) Major opcode of failed request: 3 (X_GetWindowAttributes) Resource id in failed request: 0x5c00002 Serial number of failed request: 18 Current serial number in output stream: 19
So so close....
greez
chris
- Topic Author
- Online
- Thank you received: 5983
19 Jun 2020 14:22 #172083
Replied by tommylight on topic Hardware latency tests, used PC's
Leme reboot, maybe something left from previous tests
19 Jun 2020 14:26 #172084
by seuchato
kill -SIGINT $(ps -A | awk '/latency/{print $1}')
should terminate latency still running in bg
19 Jun 2020 15:21 #172086
by seuchato
I can reproduce the errormessages. It seems to be a race condition in xdotool, see
here
lcnc-hw closes the browserwindow in my case, but I >think< xdotool "thinks" it is not.
You can do the following:
ps -ef | grep lcnc
root 24118 1241 0 16:37 pts/4 00:00:00 /bin/bash ./lcnc-hw
root 26991 5011 0 16:54 pts/5 00:00:00 grep lcnc
kill -9 24118
19 Jun 2020 15:22 - 19 Jun 2020 15:24 #172087
by seuchato
Hope I got it sorted out now. Kindly let me know.
Edit: could be that sometimes the browser window is not closed automacilly. But now the odd error messages should be gone for good
Last edit: 19 Jun 2020 15:24 by seuchato.
- Topic Author
- Online
19 Jun 2020 15:34 #172090
Looking good, still does not exit but pressing ctrl+c exits cleanly, so we are good.
Will do some more tests on some other equipment, start a new topic and edit the existing one with updated info as i test them.
- Topic Author
- Online
19 Jun 2020 15:45 #172091
It works !
Exits as it should, even with ctrl+c.
No more excuses, now on to testing !
19 Jun 2020 15:46 #172092
by seuchato
Kindly be more specific on where it is not cleanly exiting. I have it stopping everyting nicely here, only the browser window sometimes does not close. This is the behaviour that is described in the race condition problem of xdotool. I cannot fix that. Useers will have to live with than and bite sour apple by closing the eventually still running vimeo by hand.
greez chris
PS: be sure to post a link on the new thread here
greez chris
- Topic Author
- Online
19 Jun 2020 15:51 #172093
That reply was before i saw the new version in your edit, now all is good.
Of course i will post the link here.
Thank you.
Thank you.
19 Jun 2020 15:57 #172094
by seuchato
Welcome. About the new thread: is it on my script or the intention of it gathering comparable hw and latency data? Two threads probably.
greez
chris
greez
chris
Time to create page: 0.093 seconds
