Hardware latency tests, used PC's
- Topic Author
- Thank you received: 5983
17 Jun 2020 18:44 #171917
You mean:
-chose base or no base,
-enter time,
etc ???
Since it would be easier to use, use the dialog with the choice of pressing enter for any of the answers and using default values for them, or entering values. Two hours are OK, nobase should be default, so it removes the base period time question.
Replied by tommylight on topic Hardware latency tests, used PC's
That would be soooo undemocratic!any arguments against using dialog?
You mean:
-enter time,
etc ???
17 Jun 2020 18:57 #171918
by seuchato
Yes, I intend to give dafault values or options, that users could alter or select.
So I interpret your statement as "Yes, use dialog"
Got some time tomorrow...
greez
chris
Replied by seuchato on topic Hardware latency tests, used PC's
Ain't that the way we life since a few years? :-]That would be soooo undemocratic!
greez
chris
- Topic Author
17 Jun 2020 19:22 #171919
Correct.So I interpret your statement as "Yes, use dialog"
18 Jun 2020 12:46 #172006
by seuchato
How can I get the version of latency-histogram?
- Topic Author
18 Jun 2020 12:50 #172007
No idea, since --help does not show anything about it.
18 Jun 2020 13:26 #172008
by seuchato
Got it:
LCNCData() {
echo "LinuxCNC related data:"
LCNCVersion=$(apt list linuxcnc-uspace | awk '{print $2}'
echo "LinuxCNC version is: $LCNCVersion"
printf '=%.0s' {1..80}
echo ""
- Topic Author
18 Jun 2020 13:39 #172009
You asked for the histogram ???How can I get the version of latency-histogram?
18 Jun 2020 13:55 #172010
by seuchato
Yes, but I assume, that is tied to the version of linuxcnc, Am I wrong?
- Topic Author
18 Jun 2020 14:11 - 18 Jun 2020 14:12 #172011
Nope, you are not, although i can not recall any changes to latency histogram, so not sure if it has a version.
But tying it to the LinuxCNC version is a good idea.
Thank you.
Edit:
LinuxCNC has also a build number besides the general version.
Thank you.
Edit:
Last edit: 18 Jun 2020 14:12 by tommylight. Reason: More info
18 Jun 2020 17:37 #172022
by seuchato
+ might be easier to depict
question: what is more "unique": Build No. or general version? What would users relate to?
- I have no Idea, how to extract that build No. from a bash script, help appreciated
Greez
chris
Greez
chris
