LinuxCNC + Orange Pi (allwincnc)
02 Oct 2020 07:23 #184537
by MX_Master
There's no funding for this project.
There's no any help from other people to keep this project up-to-date.
Too many problems to use build-in RISC core with new kernels and u-boot.
Sorry
Replied by MX_Master on topic LinuxCNC + Orange Pi
There's no time to do that.Is there any progress on the skipping step issue? Is it suggested to not run my machine with an Orange Pi until it is resolved?
Sorry
- twoflowers
- User is blocked
- Thank you received: 32
02 Oct 2020 08:15 #184542
by twoflowers
Replied by twoflowers on topic LinuxCNC + Orange Pi
That's a pitty. I tried to compile a newer version of the kernel with RT, but failed miserably. Looks like the ARM ecosystem apart from RPi 4 is not a save bet for developers. I remember Xenomai on RPi2 was quite impressive compared to RT on Rpi3. but the project did not get any traction and the images are not to be found any more.
Anyway, thank you for carrying that project so far as you did. Your build works quite good on the OrangePi Zero (LTS), which is amazing for that small unit.
The following user(s) said Thank You: pinder
02 Oct 2020 08:50 #184544
by pinder
You have worked so hard for that.
Replied by pinder on topic LinuxCNC + Orange Pi
I feel that.
Sorry
03 Oct 2020 18:26 #184714
by Bari
Replied by Bari on topic LinuxCNC + Orange Pi
We will see what we can do over here. The Orange Pi can software step at much higher speeds than the Rpi4 since it has the integrated microcontroller. I've been working with the Rpi4 a bit and it really requires an external FPGA to do anything quickly.
07 Oct 2020 03:27 #185201
by Bari
Just found our old Orange Pi from years ago with an H3 on it. Already has LCNC on the SD-card.
12 Oct 2020 04:27 - 12 Oct 2020 04:29 #185786
by Bari
Tried both of these images on Orange Pi One, 512MB, H3:
Armbian_20.02.1_Orangepione_buster_current_5.4.20_desktop.7z
Armbian_20.05.1_Orangepione_buster_current_5.4.43_desktop.img
Apt update and all installs worked (git clone gitlab.com/orangecnc/installer) with no errors. After reboot there are no USB devices working. :(
USB PHY regulator and IRQ issues in the dmesg
Last edit: 12 Oct 2020 04:29 by Bari.
29 Oct 2020 16:53 #187700
by tjtr33
Replied by tjtr33 on topic LinuxCNC + Orange Pi
I ran ok with opi+2e, using axis and arisc stepgens. I had no hdwr to test with but 12meter/min ran Chips3d in 84secs. I made a image that i can burn to sd and repeat those numbers. Its on google drive. I sent invite to Bari. Remember it requires opi+2e. This link should be good for anyone
drive.google.com/file/d/1_kWK-XucBtHYVOe...zc-/view?usp=sharing
I _really_would like to have the lost step issue fixed.
Thanks TomP
I built adapter board for Opi+2e to plug into GeckoG540 and to breakout i/o
so the wiring paths were pcb and very very short. I was able to send one donation buut 50$ doesnt go far in the supermarket these days.
Thanks TomP
29 Oct 2020 21:02 #187724
by Bari
Thanks Tom! I'll have to order an opi+2e.
MX_Master has done a lot of work to get it this far. Thank you again.
It takes a lot of work to get these arm boards working properly.
29 Oct 2020 21:14 - 30 Oct 2020 20:01 #187726
by Bari
Can you please post which sources you used and how you built the ISO so that it is not a magic ISO?
Last edit: 30 Oct 2020 20:01 by Bari. Reason: grammar
08 Nov 2020 03:27 #188644
by rollfree
If an older version Armbian_20.05.2_Orangepipc_buster_current_5.4.43 is used as the basis (without subsequent update), then the system goes OK.
archive.armbian.com/orangepipc/archive/A....4.43_desktop.img.xz
Replied by rollfree on topic LinuxCNC + Orange Pi
I had the same problem with actual version of Armbian.Tried both of these images on Orange Pi One, 512MB, H3:
Time to create page: 0.477 seconds
