- Hardware & Machines
- Computers and Hardware
- Results of latency test, list of computers tested for use with LinuxCNC
02 Sep 2020 03:04 #180390
by aparecido
Updating some information, the motherboard is a little old, I managed to contact the manufacturer, he sent me the latest version of the BIOS, I updated and the Jitter dropped to a maximum of 25500ns.
However I spent a lot of time to update the BIOS, there had been no problem when I updated using AFUDOS, however it corrupted something during the update and did not save any more updates within the BIOS.
I tried to rewrite the BIOS (EEPROM MX25L4005) using Arduino UNO and nothing done, I tried using the USBASP and nothing done too, I only managed using a recorder mounted for parallel port, booting from a USB stick with Hiren's ISO, using the DOS prompt for make the recording.
With the BIOS recorded correctly, I turned off everything that was not necessary and did the latency test again, from approx 50000ns dropped to 25500ns.
Replied by aparecido on topic Results of latency test, list of computers tested for use with LinuxCNC
1598626490.hw
LinuxCNC pc tests, version 20200624, started 28.08.2020 11:54:51
General info:
Itautec S.A., Infoway
Bios version 0110, dated 03/02/2009
Chipset: Harddisk is rotational
The amount of swap currently used is 0
CPU related data:
model name : Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz
cpu cores : 1
stepping : 10
cache size : 3072 KB
RAM related data:
Maximum Memory Module Size: 4096 MB
Maximum Total Memory Size: 8192 MB
Maximum Capacity: 16 GB
Installed Size: 2048 MB (Double-bank Connection)
Enabled Size: 2048 MB (Double-bank Connection)
GPU related data:
Os related data:
PRETTY_NAME="Linux Mint 19.3"
Desktop: , Session:
Kernel related data:
Kernel 5.4.0-0.bpo.4-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Cpu idle driver: none
Kernel modules data:
Check if pcspkr is loaded: No, good!
Yes, may cause bigger latency.
Check if snd modules are loaded: No, good!
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : ImPS/2 Generic Wheel Mouse
Mice attached to USB:
Keyboards attached to USB:
LinuxCNC related data:
LinuxCNC version is: 2.8.0~pre3.31.gb7c7ab5aa
Preparing for latency test:
Started glxgears No. 1
Started glxgears No. 2
Started glxgears No. 3
Started glxgears No. 4
Started glxgears No. 5
Started firefox with 'vimeo.com/150574260'
Command for latency test is:
su aparecido -c "latency-histogram --bbinsize 1000 --base 25000 --sbinsize 1000 --nox 2>&1 | tee 1598626490.lat &"
Latency testing loop started sex ago 28 11:55:06 -03 2020,
should end after sex ago 28 13:55:06 -03 2020
Unexpected realtime delay on task 0 with period 25000
Swap useage: prerun: 0, running: 0
last latency data is as follows:.
12 secs base min: -24.800 uS max: 51.700 uS sdev: 2.000 uS
12 secs servo min: -22.300 uS max: 22.800 uS sdev: 7.500 uS
1598626490.lat
Note: Using POSIX realtime
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
0 secs base min: -24.700 uS max: 21.300 uS sdev: 2.200 uS
0 secs servo min: -15.500 uS max: 15.900 uS sdev: 7.600 uS
2 secs base min: -24.700 uS max: 23.000 uS sdev: 2.000 uS
2 secs servo min: -21.700 uS max: 18.600 uS sdev: 7.200 uS
3 secs base min: -24.700 uS max: 23.000 uS sdev: 2.000 uS
3 secs servo min: -21.700 uS max: 22.800 uS sdev: 7.200 uS
5 secs base min: -24.700 uS max: 23.000 uS sdev: 2.000 uS
5 secs servo min: -21.700 uS max: 22.800 uS sdev: 7.300 uS
6 secs base min: -24.700 uS max: 23.000 uS sdev: 2.000 uS
6 secs servo min: -22.300 uS max: 22.800 uS sdev: 7.400 uS
7 secs base min: -24.700 uS max: 23.000 uS sdev: 2.000 uS
7 secs servo min: -22.300 uS max: 22.800 uS sdev: 7.500 uS
9 secs base min: -24.800 uS max: 23.000 uS sdev: 2.000 uS
9 secs servo min: -22.300 uS max: 22.800 uS sdev: 7.400 uS
10 secs base min: -24.800 uS max: 23.000 uS sdev: 2.000 uS
10 secs servo min: -22.300 uS max: 22.800 uS sdev: 7.500 uS
02 Sep 2020 11:29 #180417
by seuchato
Replied by seuchato on topic Results of latency test, list of computers tested for use with LinuxCNC
aparecido
Did you let the script run for just 12 seconds? I feel this is very much too short. If you get the infamous sporadic hickups, you will probably not see them at all. There is a reason, why I set the default running time to 2h.
No need to post the *.lat file. All relevant data is in the *.hw file.
Greez
chris
Greez
chris
The following user(s) said Thank You: aparecido
02 Sep 2020 23:14 #180474
by aparecido
The script itself closed all windows and showed a message on the terminal saying it was finished.
I didn't just leave it for 12 seconds, it was a few minutes, a few, but it was a few minutes.
How should I proceed, since the script itself closes everything and displays a message that has been completed?
I did the test in the old way of opening several things at the same time, transferring the file from the pendrive to internal hd, for several minutes and the jitter was stabilized at almost the same value as the script test ...
aparecido
Greez
chris
03 Sep 2020 12:15 #180536
by JKAVS
Replied by JKAVS on topic Results of latency test, list of computers tested for use with LinuxCNC
Here is my result. I think it looks good but a confirmation from somebody with more expertise than me would be appreciated.
LinuxCNC pc tests, version 20200624, started 03.09.2020 13:09:17
General info:
Dell Inc., Precision WorkStation T3500
Bios version A17, dated 05/28/2013
CPU related data:
model name : Intel(R) Xeon(R) CPU W3565 @ 3.20GHz
cpu cores : 4
stepping : 5
cache size : 8192 KB
RAM related data:
Maximum Capacity: 24 GB
Size: No Module Installed
GPU related data:
product: GF106GL [Quadro 2000]
configuration: driver=nouveau latency=0
Os related data:
PRETTY_NAME="Linux Mint 20"
Desktop: , Session:
Kernel 4.9.0-13-rt-amd64
Cpu idle driver: intel_idle
Check if snd modules are loaded: snd_hda_codec_hdmi 49152 4
snd_hda_intel 40960 1
snd_hda_codec 135168 2 snd_hda_intel,snd_hda_codec_hdmi
snd_hda_core 90112 3 snd_hda_intel,snd_hda_codec,snd_hda_codec_hdmi
snd_hwdep 16384 1 snd_hda_codec
snd_pcm 114688 4 snd_hda_intel,snd_hda_codec,snd_hda_core,snd_hda_codec_hdmi
snd_seq_midi 16384 0
snd_seq_midi_event 16384 1 snd_seq_midi
snd_rawmidi 32768 1 snd_seq_midi
snd_seq 65536 2 snd_seq_midi_event,snd_seq_midi
snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer 32768 2 snd_seq,snd_pcm
snd 81920 11 snd_hda_intel,snd_hwdep,snd_seq,snd_hda_codec,snd_timer,snd_rawmidi,snd_hda_codec_hdmi,snd_seq_device,snd_pcm
soundcore 16384 1 snd
Number of mice: 1
Mouse 0 : MOSART Semi. 2.4G Keyboard Mouse
MosArt Semiconductor Corp. Wireless Keyboard/Mouse
LinuxCNC version is: 2.8.0.4.g4dc48a252
Started firefox with 'https://vimeo.com/150574260'
su cnc -c "latency-histogram --bbinsize 1000 --base 25000 --sbinsize 1000 --nox 2>&1 | tee 1599127755.lat &"
Latency testing loop started Thu 03 Sep 2020 01:09:33 PM EEST,
should end after Thu 03 Sep 2020 03:09:33 PM EEST
7200 secs base min: -20.000 uS max: 20.300 uS sdev: 0.500 uS
7200 secs servo min: -21.100 uS max: 20.700 uS sdev: 0.800 uS
- Topic Author
- Thank you received: 5987
03 Sep 2020 12:55 #180540
Replied by tommylight on topic Results of latency test, list of computers tested for use with LinuxCNC
That is really good for parallel and Mesa.
04 Sep 2020 14:06 #180681
by seuchato
[quote="aparecido" post=180474The script itself closed all windows and showed a message on the terminal saying it was finished.
I did the test in the old way of opening several things at the same time, transferring the file from the pendrive to internal hd, for several minutes and the jitter was stabilized at almost the same value as the script test ...[/quote]
aparecido
I missed this exerpt of your output:
You can/should increase from 25000 to at least 50000 or even 100000 and run the test again. you can also consider not using the parallel port and run without a basethread. "realtime delay" should not occur. if it happens while making some chips, the result could be difficult to predict and potentially dangerous. I guess tommylight would agree?
greez
chris
aparecido
greez
chris
04 Sep 2020 14:12 #180684
by seuchato
Hi all
here is a result of a Fujitsu Esprimo D956/E85+
I think this one needs further tweaking to get latency down. The bios is rich and I disabled everything I thought being useful. Need to play with the kernel parameters too.
Greez
chris
-b LinuxCNC pc tests, version 20200903pre,
started 04.09.2020 13:18:26
General info:
FUJITSU, ESPRIMO_D956
Bios version V5.0.0.11 R1.4.0 for D3432-A1x, dated 10/08/2015
Chipset: Harddisk is non-rotational, ie. SSD
CPU related data:
model name : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
cpu cores : 1
stepping : 3
RAM related data:
Maximum Capacity: 64 GB
Maximum Voltage: Unknown
GPU related data:
product: HD Graphics 530
configuration: driver=i915 latency=0
Parallel port related data:
number of parallel ports is 1
parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE,EPP]
Os related data:
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
Desktop: KDE, Session:
Kernel 4.9.0-12-rt-amd64
Number of mice: 2
Mouse 0 : USB-compliant keyboard
Mouse 1 : Logitech USB Receiver
Logitech, Inc. Cordless Mouse Receiver
MosArt Semiconductor Corp. Defender Office Keyboard (K7310) S Zodiak KM-9010
LinuxCNC version is: 2.9.0~pre0.2740.gcb1425e5d
su ck -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1599218291.lat &"
Latency testing loop started Fr Sep 4 13:18:40 CEST 2020,
should end after Fr Sep 4 15:18:40 CEST 2020
CPU core temperatures:
Core 0: Tmin: 36.0°C, TMax: 70.0°C, (high = +84.0°C, crit = +100.0°C)
7202 secs servo min:-450.800 uS max: 448.600 uS sdev: 7.300 uS
Greez
chris
- Topic Author
04 Sep 2020 16:11 #180699
I had two older Fujitsu Esprimo's that had much, much better latency with new kernels !
05 Sep 2020 10:40 #180798
by seuchato
Hi all, Results for an IBM Thinkpad Z61p: not useable. Plus: the BIOS has been password locked. Can't change anything
The lapy will be used in my workshop for browsing and music playing. It will not drive any cnc!
greez
chris
LinuxCNC pc tests, version 20200905, started 05.09.2020 12:31:59
General info:
LENOVO, 0674GEG
Bios version 7FETA9WW (2.27 ), dated 08/26/2009
CPU related data:
model name : Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz
cpu cores : 2
stepping : 6
cache size : 4096 KB
RAM related data:
Maximum Memory Module Size: 2048 MB
Maximum Total Memory Size: 4096 MB
Maximum Capacity: 2 GB
GPU related data:
number of parallel ports is 0
Os related data:
Desktop: MATE, Session: mate
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_idle.max_cstate=0 processor.max_cstate=1 idle=poll isolcpus=1"
Check if snd modules are loaded: Yes, may cause bigger latency.
Number of mice: 2
Mouse 0 : Logitech USB Receiver
Mouse 1 : TPPS/2 IBM TrackPoint
LinuxCNC version is: 2.9.0~pre0.2747.gb86438619
su ck -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1599301911.lat &"
Latency testing loop started Sa Sep 5 12:32:17 CEST 2020,
should end after Sa Sep 5 14:32:17 CEST 2020
Useless to proceed, read the relevant part in 1599301911.lat
>>>Unexpected realtime delay on task 0 with period 1000000<<<
Core 0: Tmin: 77.0°C, TMax: 88.0°C, (high = +100.0°C, crit = +100.0°C)
Core 1: Tmin: 77.0°C, TMax: 88.0°C, (high = +100.0°C, crit = +100.0°C)
128 secs servo min:-878.500 uS max: 878.800 uS sdev: 3.700 uS
129 secs servo min:-878.500 uS max: 878.800 uS sdev: 3.700 uS
greez
chris
07 Sep 2020 13:12 - 07 Sep 2020 13:14 #181151
by Himarc3D
Replied by Himarc3D on topic Results of latency test, list of computers tested for use with LinuxCNC
Hi, guys.
Fanless Mini PCModel K4-I5-4200U from Aliexpress i received 4/9/2020, i tested Mint 19.2 and 20, Debian gave me better result.
LinuxCNC pc tests, version 20200624, started 07.09.2020 18:50:32
General info:
Intel, H81U
Bios version 5.011, dated 07/31/2019
CPU related data:
model name : Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
cpu cores : 2
stepping : 1
RAM related data:
GPU related data:
product: Haswell-ULT Integrated Graphics Controller
Os related data:
Desktop: , Session:
Kernel 4.19.0-10-rt-amd64
Number of mice: 1
Mouse 0 : SteelSeries Sensei Raw Gaming Mouse
Dell Computer Corp. Model L100 Keyboard
su gd100 -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee 1599472222.lat &"
Latency testing loop started Mon 07 Sep 2020 06:50:46 PM JST,
should end after Mon 07 Sep 2020 08:50:46 PM JST
7204 secs servo min: -60.300 uS max: 68.400 uS sdev: 7.900 uS
7205 secs servo min: -60.300 uS max: 68.400 uS sdev: 7.900 uS
Last edit: 07 Sep 2020 13:14 by Himarc3D.
The following user(s) said Thank You: seuchato, tommylight
Time to create page: 0.301 seconds
