- Hardware & Machines
- Computers and Hardware
- Results of latency test, list of computers tested for use with LinuxCNC
27 Sep 2020 16:35 #184003
by txtrone
Replied by txtrone on topic Results of latency test, list of computers tested for use with LinuxCNC
Same Lenovo E430 running Buster.
LinuxCNC pc tests, version 20200922, started 26.09.2020 21:18:32
General info:
LENOVO, 3254CTO
Bios version H0ET98WW (2.58 ), dated 08/18/2016
Chipset: Intel Corporation 7 Series/C216
Harddisk is rotational
The amount of swap currently used is 0
CPU related data:
model name : Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
cpu cores : 1
stepping : 9
cache size : 3072 KB
RAM related data:
Maximum Capacity: 16 GB
Size: No Module Installed
GPU related data:
product: 3rd Gen Core processor Graphics Controller
configuration: driver=i915 latency=0
Parallel port related data:
number of parallel ports is 0
Os related data:
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
Windowmanager =
Kernel related data:
Kernel 4.19.0-10-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: Yes, may cause bigger latency.
can be elimintaed using:
sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf
Check if snd modules are loaded: Yes, may cause bigger latency.
can probably be disabled in bios
Keyboard & Mouse related data:
Number of mice: 2
Mouse 0 : SynPS/2 Synaptics TouchPad
Mouse 1 : TPPS/2 IBM TrackPoint
Mice attached to USB:
Keyboards attached to USB:
LinuxCNC related data:
LinuxCNC version is: 2.8.0
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID 50331651
Command for latency test is:
su oldlt -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1601173111.lat &"
Latency testing loop started Sat 26 Sep 2020 09:18:47 PM CDT,
should end after Sat 26 Sep 2020 11:18:47 PM CDT
Swap useage: prerun: 0, running: 0
CPU core temperatures:
Core 0: Tmin: 49.0°C, Tmax: 61.0°C, (high = +87.0°C, crit = +105.0°C)
last latency data is as follows:.
7199 secs servo min: -90.800 uS max: 98.400 uS sdev: 2.500 uS
7200 secs servo min: -90.800 uS max: 98.400 uS sdev: 2.500 uS
27 Sep 2020 19:59 #184021
by txtrone
Same Lenovo E430, but I replaced the 7200rpm HDD with a SanDisk SSD
LinuxCNC pc tests, version 20200922, started 27.09.2020 12:06:05
General info:
LENOVO, 3254CTO
Harddisk is non-rotational, ie. SSD
CPU related data:
cpu cores : 1
stepping : 9
RAM related data:
GPU related data:
Os related data:
Windowmanager =
Number of mice: 2
Started firefox with 'https://vimeo.com/150574260', WID 46137347
su oldlt -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1601226348.lat &"
Latency testing loop started Sun 27 Sep 2020 12:06:19 PM CDT,
should end after Sun 27 Sep 2020 02:06:19 PM CDT
Core 0: Tmin: 55.0°C, Tmax: 68.0°C, (high = +87.0°C, crit = +105.0°C)
7203 secs servo min:-173.400 uS max: 167.900 uS sdev: 7.700 uS
7204 secs servo min:-173.400 uS max: 167.900 uS sdev: 7.700 uS
- Topic Author
- Thank you received: 5987
27 Sep 2020 20:32 #184031
Replied by tommylight on topic Results of latency test, list of computers tested for use with LinuxCNC
Strange, worse results with an SSD than with a HDD !
The results with HDD look very promising, but that might change with load.
Thank you for all the testing and results.
27 Sep 2020 20:36 #184032
by txtrone
That surprised me too! When it comes to SDD is there a read/write speed that works better? Or maybe a setting in the bios? AHCI vs compatibility mode?? thx
- Topic Author
27 Sep 2020 20:52 #184043
I do not think it is the read/write speed, more likely it is caused by access time.
- Topic Author
27 Sep 2020 20:54 #184045
I always set it to AHCI and whenever possible disable serial-ata power saving.Or maybe a setting in the bios? AHCI vs compatibility mode?? thx
27 Sep 2020 20:54 #184046
by txtrone
Interesting. I am going to try a different SSD and more memory in this laptop over the next week.
27 Sep 2020 20:56 #184048
by txtrone
RPi4 with 4GB memory
LinuxCNC pc tests, version 20200922, started 26.09.2020 22:10:45
General info:
Bios version , dated Chipset: Harddisk is non-rotational, ie. SSD
CPU related data:
model name : ARMv7 Processor rev 3 (v7l)
RAM related data:
GPU related data:
Os related data:
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
Windowmanager =
Kernel 4.19.71-rt24-v7l+
Cpu idle driver: ================================================================================
Check if pcspkr is loaded: No, which is good!
Number of mice: 0
su pi -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1601176201.lat &"
Latency testing loop started Sat 26 Sep 2020 10:11:03 PM CDT,
should end after Sun 27 Sep 2020 12:11:03 AM CDT
7203 secs servo min:-126.900 uS max: 146.900 uS sdev: 2.600 uS
- BeagleBrainz
- User is blocked
- Thank you received: 570
27 Sep 2020 20:59 #184050
by BeagleBrainz
Replied by BeagleBrainz on topic Results of latency test, list of computers tested for use with LinuxCNC
Why is there only a single core being reported for a I5-3210M ?
Have you disabled a core in the BIOS or is there an issue with the script ?
Are you reading all of the report or just the latency ?
27 Sep 2020 21:00 #184051
by txtrone
AHCI was on already, let me check if there is any serial-ata power saving options.
I cannot find anything about snd modules in the bios? Otherwise I would disable them?
I have all the mutli threads per core and hyper threading turned off as well. Is that recommended?
Time to create page: 0.408 seconds
