- Hardware & Machines
- Computers and Hardware
- Results of latency test, list of computers tested for use with LinuxCNC
- Topic Author
- Thank you received: 5986
27 Sep 2020 21:02 #184052
Replied by tommylight on topic Results of latency test, list of computers tested for use with LinuxCNC
Multi core support can be left on, at least i always do.
Multithreading is always off.
27 Sep 2020 21:13 #184056
by txtrone
Replied by txtrone on topic Results of latency test, list of computers tested for use with LinuxCNC
Ok, I will adjust that as well and run the script again.
28 Sep 2020 01:27 #184089
by JohnnyCNC
Replied by JohnnyCNC on topic Results of latency test, list of computers tested for use with LinuxCNC
isolcpus=0 gave the worst results, no isolcpus was next, and isolcpus=1 was best.
LinuxCNC pc tests, version 20200922, started 27.09.2020 19:01:43
General info:
ECS, BAT-I
Bios version 5.6.5, dated 01/18/2016
Chipset: Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name : Intel(R) Celeron(R) CPU J1800 @ 2.41GHz
cpu cores : 2
stepping : 8
cache size : 1024 KB
RAM related data:
Maximum Capacity: 8 GB
Maximum Voltage: 1.5 V
GPU related data:
product: Atom Processor Z36xxx/Z37xxx Series Graphics & Display
configuration: driver=i915 latency=0
Parallel port related data:
number of parallel ports is 1
parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
Os related data:
PRETTY_NAME="Linux Mint 20"
Windowmanager =
Kernel related data:
Kernel 4.9.0-13-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=1 splash"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: No, which is good!
Check if snd modules are loaded: No, which is good!
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : Logitech M215 2nd Gen
Mice attached to USB:
Keyboards attached to USB:
LinuxCNC related data:
LinuxCNC version is: 2.8.0.45.g6319aa042
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID 73400323
Command for latency test is:
su john -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1601247687.lat &"
Latency testing loop started Sun 27 Sep 2020 07:02:07 PM EDT,
should end after Sun 27 Sep 2020 09:02:07 PM EDT
Swap useage: prerun: 0, running: 0
CPU core temperatures:
Core 0: Tmin: 31.0°C, Tmax: 44.0°C, (high = +105.0°C, crit = +105.0°C)
Core 1: Tmin: 31.0°C, Tmax: 44.0°C, (high = +105.0°C, crit = +105.0°C)
last latency data is as follows:.
7203 secs servo min: -64.200 uS max: 82.800 uS sdev: 4.300 uS
7204 secs servo min: -64.200 uS max: 82.800 uS sdev: 4.300 uS
28 Sep 2020 06:23 #184113
by seuchato
Yep, I saw more or less no effect in turning off multicores, however turing off multithreading impaired latencies.
Later this week, i'll put together my "best" bios settings for two or three pc's I tend to use. Maybe this can help others or at least serve as a source of inspiration.
greez
chris
Replied by seuchato on topic Results of latency test, list of computers tested for use with LinuxCNC
greez
chris
28 Sep 2020 06:24 #184114
by seuchato
Will play with that on my T500.
28 Sep 2020 06:49 #184115
by seuchato
BeagleBrainz:
This is from my "reference", a Dell 980 ( see here , but with Xfce4 and install off stock iso, this machine has bios A18, while then it was A04). I have audio disabled in bios, however with both of your kernels I get this:
When running the script, I even got some garbled audio output on the internal speaker! These very modules where also loaded using the
If running a stock buster kernel (ie.: 4.19.0-11-rt-amd64) and nothing else changed, there are no snd modules!
comparison of latencies of the various kernels I have:
I'll try your kernels on my mint ssd later today and report the results afterwards.
So: How come, these modules get loaded?
Greez
chris
Have 2 kernels you might want to give a go. These are the ones used on the Mint ISOs. The header & libc-dev packages are in the same dirs as linux-image-xxx.
The -rt46 has efi=runtime embedded in the kernel image but should not affect non UEFI systems.
cnc.beaglebrainz.net/mintcnc/pool/2.8-rt...t44-lcnc-1_amd64.deb
cnc.beaglebrainz.net/mintcnc/pool/2.8-rt...t46-lcnc-1_amd64.deb
BeagleBrainz:
uname -a
Linux cnc0 4.19.106-rt44-lcnc #1 SMP PREEMPT RT Thu Mar 5 00:02:34 AEDT 2020 x86_64 GNU/Linux
root@cnc0:~# lsmod | grep snd
snd_pcsp 16384 2
snd_pcm 98304 1 snd_pcsp
snd_timer 32768 1 snd_pcm
snd 81920 7 snd_timer,snd_pcsp,snd_pcm
soundcore 16384 1 snd
cat *.hw | grep -E "4\.19\.|secs"
Kernel 4.19.0-9-rt-amd64
7200 secs base min: -34.600 uS max: 33.300 uS sdev: 0.800 uS
7200 secs servo min: -17.500 uS max: 18.300 uS sdev: 1.100 uS
Kernel 4.19.0-10-rt-amd64
7203 secs base min: -32.800 uS max: 33.100 uS sdev: 1.000 uS
7203 secs servo min: -29.300 uS max: 30.100 uS sdev: 2.500 uS
Kernel 4.19.0-11-rt-amd64
7199 secs servo min: -27.500 uS max: 31.100 uS sdev: 1.200 uS
7201 secs base min: -29.200 uS max: 29.200 uS sdev: 0.800 uS
Kernel 4.19.106-rt44-lcnc
245 secs base min: -40.100 uS max: 52.800 uS sdev: 0.900 uS
245 secs servo min: -39.100 uS max: 37.900 uS sdev: 1.500 uS
(script repetitively stopped early due to real time delay)
Kernel 4.19.106-rt46-lcnc
15 secs base min: -44.400 uS max: 43.300 uS sdev: 1.500 uS
15 secs servo min: -7.300 uS max: 7.200 uS sdev: 1.100 uS
Greez
chris
- BeagleBrainz
- User is blocked
- Thank you received: 570
28 Sep 2020 07:45 - 28 Sep 2020 08:14 #184117
by BeagleBrainz
Replied by BeagleBrainz on topic Results of latency test, list of computers tested for use with LinuxCNC
I did a search trying to find an answer to sound modules being loaded when disabled in the BIOS, every answer pointed at checking the BIOS. I really can't explain it.
Did 4 tests
1: VBox with sound device diasbled, Mint 19.3 my kernel no sound modules loaded, Host has sound modules loaded
2: Odroid H2+ sound disabled no sound modules loaded
3: Asrock J3355B sound disabled no sound modules loaded
4: Lenovo ThinkStation S20 sound disabled in BIOS but with Quadro 2000, sound modules loaded due to GPU having HDMI.
No option to disable sound on my T530, so was unable to test.
dmesg | grep sound for the S20 I really don't think there would be much difference between 19.2 & 19.3 in latency.
All other examples have have no output from grep, even when using the -i switch for grep.
I use my kernel on the machine controlling my mill and even after a full days usage never had an issues relating to latency. Still to hook up the Odroid as I don't want to mess around with things too much until I have the DYN4 & AC sevo dialled in for the spindle.
Actually I haven't had any feedback due to latency issues from other users, the first Mint ISO's with the 4.19.106-rt44-lcnc kernel came out around April.
Quick run of the test on the S20. I really don't think there would be much difference between 19.2 & 19.3 in latency. Along with the T530 is my daily driver. Yeah I use the RT kernels daily (99% exclusively), both machines are on 24/7.
Did 4 tests
rmurphy@ThinkStation-S20:~$ dmesg | grep sound
[ 7.710692] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/0000:02:00.1/sound/card0/input8
[ 7.719026] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/0000:02:00.1/sound/card0/input9
[ 7.727323] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/0000:02:00.1/sound/card0/input10
[ 7.735811] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.0/0000:02:00.1/sound/card0/input11
LinuxCNC pc tests, version 20200922, started 28.09.2020 17:41:52
General info:
LENOVO, 4157CTO
Bios version 60KT45AUS, dated 03/30/2012
Chipset: Intel Corporation 5520/5500/X58
CPU related data:
model name : Intel(R) Xeon(R) CPU W3550 @ 3.07GHz
cpu cores : 4
stepping : 5
cache size : 8192 KB
RAM related data:
Maximum Capacity: 192 GB
GPU related data:
product: GF106GL [Quadro 2000]
configuration: driver=nouveau latency=0
number of parallel ports is 0
Os related data:
PRETTY_NAME="Linux Mint 19.2"
Windowmanager =
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Check if snd modules are loaded: Yes, may cause bigger latency.
can probably be disabled in bios
Number of mice: 1
Mouse 0 : Logitech USB Receiver Mouse
LinuxCNC version is: 2.8.0.44.gad1491d89
Started firefox with 'https://vimeo.com/150574260', WID 60818346
su rmurphy -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1601278900.lat &"
Latency testing loop started Mon 28 Sep 17:42:07 AEST 2020,
should end after Mon 28 Sep 19:42:07 AEST 2020
Manual termination requested at 28.09.2020 17:42:34
Core 0: Tmin: 43.0°C, Tmax: 46.0°C, (high = +80.0°C, crit = +100.0°C)
Core 1: Tmin: 35.0°C, Tmax: 40.0°C, (high = +80.0°C, crit = +100.0°C)
Core 2: Tmin: 41.0°C, Tmax: 45.0°C, (high = +80.0°C, crit = +100.0°C)
Core 3: Tmin: 37.0°C, Tmax: 41.0°C, (high = +80.0°C, crit = +100.0°C)
27 secs servo min: -11.900 uS max: 13.600 uS sdev: 1.600 uS
28 secs servo min: -11.900 uS max: 13.600 uS sdev: 1.600 uS
Last edit: 28 Sep 2020 08:14 by BeagleBrainz.
28 Sep 2020 08:36 #184121
by seuchato
Beagle,
I'll try circumvent the loading of said snd modules using a fake install (evrything fake nowadays, even installs :-])
greez
chris
greez
chris
- BeagleBrainz
- User is blocked
28 Sep 2020 09:03 #184126
by BeagleBrainz
You could also add the modules to a blacklist, which is the usual way.
The thing is the kernel is detecting the sound card and the loading of the modules is not an error.
what doesoutput ?
what does
dmesg | grep -i sound
28 Sep 2020 10:20 #184128
by seuchato
Will do that when the current test is finished.
Here is a scriptlet to prevent loading of sound modules at boot time:
save ie. as "block-snd-modules" and run "sudo ./block-snd-modules", then reboot.
hope this will be useful for others too.
greez
chris
what doesoutput ?dmesg | grep -i sound
#! /bin/bash
if [ "-$(lsmod | grep snd)-" != "--" ] ; then
echo currently these \"snd\" modules are loaded: $(lsmod | grep snd | awk '{print $1}')
for i in $(lsmod | grep snd | awk '{print $1}' | tr '\n' ' ')
do
echo "install $i /bin/false" >> /etc/modprobe.d/snd.conf
done
echo " reboot now and check usung \"lsmod | grep snd\""
else
echo " There are no \"snd\" modules loaded."
fi
greez
chris
Time to create page: 0.197 seconds
