HP Compaq Elite 8300 vs Dell Optiplex 7010
03 Nov 2020 00:18 - 03 Nov 2020 09:05 #188165
by seuchato
Replied by seuchato on topic HP Compaq Elite 8300 vs Dell Optiplex 7010
my1987toyota:
could you kindly post the output of
here
Should be on your Lenovo Idea Centre with the AMD X2 250 CPU.
Tia
chris
Edit Nov. 3rd 202:
Kindly also add output of
sudo sensors-detect
cat /etc/modules
Tia
chris
Edit Nov. 3rd 202:
sensors-detect
Last edit: 03 Nov 2020 09:05 by seuchato. Reason: sensors detect
- my1987toyota
- Topic Author
- Thank you received: 271
06 Nov 2020 21:01 #188540
by my1987toyota
Replied by my1987toyota on topic HP Compaq Elite 8300 vs Dell Optiplex 7010
I will be away from the computers through the weekend. ( taking some time to unwind ) I have additional ram coming for the Lenovo.
and I will run the tests and what you have described when the new ram is in.
07 Nov 2020 03:41 #188565
by seuchato
Hey, no hurry.
The following user(s) said Thank You: my1987toyota
- my1987toyota
- Topic Author
07 Nov 2020 15:34 - 07 Nov 2020 15:35 #188591
by my1987toyota
PSST, the ram came in , yes it made a difference when I get another chance I will
run those scripts.
Hey, no hurry.
run those scripts.
Last edit: 07 Nov 2020 15:35 by my1987toyota.
The following user(s) said Thank You: seuchato, tommylight
- my1987toyota
- Topic Author
11 Nov 2020 02:42 #188950
by my1987toyota
well so much for being away for just the weekend . I have a tropical storm ( ETA Gulf coast of Florida ) that I am prepping for .
Never a dull moment. I will get back to testing this coming weekend.
- my1987toyota
- Topic Author
17 Nov 2020 01:06 #189569
by my1987toyota
Fortunately my area didn't get hit very hard by Eta , now I have to unpack everything ugh.
I did manage to get a short test in before packing the computer away
the extra 2 gigs ram made a difference
LinuxCNC pc tests, version 20200930, started 06.11.2020 20:19:25
General info:
LENOVO, H215
Bios version D2KT25BUS, dated 08/18/2010
Chipset: Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name : AMD Athlon(tm) II X2 250 Processor
cpu cores : 2
stepping : 3
cache size : 1024 KB
RAM related data:
Maximum Capacity: 8 GB
GPU related data:
product: RS780L [Radeon 3000]
configuration: driver=radeon latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : xfce4
Windowmanager : Xfwm4
Displaymanager : lightdm
Kernel related data:
Kernel 4.19.0-11-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
Cpu idle driver: none
Kernel modules data:
Check if pcspkr is loaded: [0;31mYes, may cause bigger latency.[0m
can be eliminated using:
sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf
Check if snd modules are loaded: [0;31mYes, may cause bigger latency.[0m
can probably be disabled in bios, alternatively, you can run
"./block-snd-modules"
which has just now been created for your convenience.
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : PixArt USB Optical Mouse
Mice attached to USB:
Keyboards attached to USB:
Dell Computer Corp. Keyboard
LinuxCNC related data:
LinuxCNC version is: 2.8.0
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID 48234499
Command for latency test is:
su cnc001 -c "latency-histogram --nobase --base 100000 --sbinsize 1000 --nox 2>&1 | tee -a 1604711937.lat &"
Latency testing loop started Fri 06 Nov 2020 08:19:39 PM EST,
should end after Fri 06 Nov 2020 08:24:39 PM EST
Swap useage: prerun: 0, running: 0
CPU core temperatures:
cnc001@debian:~$ sensors
k10temp-pci-00c3
Adapter: PCI adapter
temp1: +41.0°C (high = +70.0°C)
Note: Using POSIX realtime
0 secs servo min: -41.300 uS max: 45.900 uS sdev: 10.400 uS
1 secs servo min: -43.600 uS max: 49.400 uS sdev: 10.300 uS
2 secs servo min: -49.800 uS max: 49.400 uS sdev: 10.000 uS
3 secs servo min: -49.800 uS max: 51.300 uS sdev: 10.600 uS
3 secs servo min: -49.800 uS max: 51.300 uS sdev: 10.100 uS
4 secs servo min: -49.800 uS max: 51.300 uS sdev: 9.900 uS
5 secs servo min: -49.800 uS max: 51.300 uS sdev: 9.800 uS
5 secs servo min: -49.800 uS max: 51.300 uS sdev: 9.500 uS
6 secs servo min: -49.800 uS max: 51.300 uS sdev: 9.600 uS
7 secs servo min: -50.500 uS max: 51.300 uS sdev: 9.500 uS
8 secs servo min: -50.500 uS max: 53.300 uS sdev: 9.500 uS
8 secs servo min: -51.200 uS max: 53.300 uS sdev: 9.500 uS
9 secs servo min: -64.000 uS max: 57.500 uS sdev: 9.500 uS
10 secs servo min: -64.000 uS max: 57.500 uS sdev: 9.500 uS
11 secs servo min: -64.000 uS max: 58.900 uS sdev: 9.600 uS
12 secs servo min: -64.000 uS max: 58.900 uS sdev: 9.700 uS
13 secs servo min: -64.000 uS max: 58.900 uS sdev: 9.900 uS
14 secs servo min: -64.000 uS max: 58.900 uS sdev: 10.100 uS
14 secs servo min: -64.000 uS max: 58.900 uS sdev: 10.300 uS
15 secs servo min: -64.000 uS max: 58.900 uS sdev: 10.500 uS
16 secs servo min: -64.000 uS max: 58.900 uS sdev: 10.700 uS
17 secs servo min: -64.000 uS max: 58.900 uS sdev: 10.800 uS
17 secs servo min: -64.000 uS max: 58.900 uS sdev: 11.000 uS
18 secs servo min: -64.000 uS max: 58.900 uS sdev: 11.100 uS
19 secs servo min: -64.000 uS max: 58.900 uS sdev: 11.200 uS
20 secs servo min: -64.000 uS max: 58.900 uS sdev: 11.200 uS
20 secs servo min: -64.000 uS max: 58.900 uS sdev: 11.300 uS
21 secs servo min: -64.000 uS max: 58.900 uS sdev: 11.300 uS
22 secs servo min: -64.000 uS max: 58.900 uS sdev: 11.500 uS
23 secs servo min: -64.000 uS max: 58.900 uS sdev: 11.700 uS
24 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.000 uS
24 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.200 uS
25 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.400 uS
26 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.600 uS
27 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.700 uS
28 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.600 uS
28 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.500 uS
29 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.500 uS
30 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.400 uS
31 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.300 uS
32 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.200 uS
33 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.300 uS
34 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.300 uS
35 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.300 uS
36 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.400 uS
37 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.400 uS
38 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.500 uS
39 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.600 uS
40 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.800 uS
41 secs servo min: -64.000 uS max: 58.900 uS sdev: 12.900 uS
41 secs servo min: -64.000 uS max: 58.900 uS sdev: 13.000 uS
42 secs servo min: -64.000 uS max: 58.900 uS sdev: 13.100 uS
43 secs servo min: -64.000 uS max: 58.900 uS sdev: 13.200 uS
44 secs servo min: -64.000 uS max: 65.100 uS sdev: 13.200 uS
45 secs servo min: -64.000 uS max: 65.100 uS sdev: 13.300 uS
45 secs servo min: -64.000 uS max: 65.100 uS sdev: 13.400 uS
46 secs servo min: -64.000 uS max: 65.100 uS sdev: 13.500 uS
47 secs servo min: -64.000 uS max: 65.100 uS sdev: 13.500 uS
48 secs servo min: -64.000 uS max: 65.100 uS sdev: 13.600 uS
49 secs servo min: -64.000 uS max: 65.100 uS sdev: 13.500 uS
49 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.500 uS
50 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
51 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
51 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
52 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
53 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
54 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
55 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
56 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
57 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
58 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
59 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
60 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
61 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
62 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.500 uS
63 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.500 uS
64 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.500 uS
65 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
66 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
67 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
68 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
69 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
70 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
71 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
72 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
73 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
74 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
75 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
76 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
77 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
78 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
79 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
80 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
81 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
82 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
83 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
83 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.500 uS
84 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.500 uS
85 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
86 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
87 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
88 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
89 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
90 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
91 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
91 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
92 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
93 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
94 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
95 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
96 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
97 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
98 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
99 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
100 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
101 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.400 uS
102 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
103 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
104 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
105 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
106 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
107 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.300 uS
108 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
109 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
110 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
111 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
112 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
113 secs servo min: -64.000 uS max: 65.700 uS sdev: 13.200 uS
114 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.200 uS
115 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.200 uS
116 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.300 uS
117 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.300 uS
118 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.300 uS
119 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.400 uS
120 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.400 uS
121 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.400 uS
122 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.400 uS
122 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.300 uS
123 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.300 uS
124 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.300 uS
125 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.300 uS
126 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.300 uS
127 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.300 uS
128 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.300 uS
128 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.200 uS
129 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.200 uS
130 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.200 uS
131 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.200 uS
131 secs servo min: -64.000 uS max: 67.000 uS sdev: 13.300 uS
132 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.300 uS
133 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.300 uS
134 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.300 uS
134 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.400 uS
135 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.400 uS
136 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.400 uS
137 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.300 uS
138 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.300 uS
139 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.300 uS
140 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.300 uS
141 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
142 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
143 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
144 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
145 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
146 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
147 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
148 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
149 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
150 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
151 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
152 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
152 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
153 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
154 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
155 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
156 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.300 uS
157 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
158 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
159 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
160 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
161 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
162 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
163 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
164 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
165 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
166 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
167 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
168 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
169 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
170 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
171 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.300 uS
172 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.300 uS
173 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.300 uS
174 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
175 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
176 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
177 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
178 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
179 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
180 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
181 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
182 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
183 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
184 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
185 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
186 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
187 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
188 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
189 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
190 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
191 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
191 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
192 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
193 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
194 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
195 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
196 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
197 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
198 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
199 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
200 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
201 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
202 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
203 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
204 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
205 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
206 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
207 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
208 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
209 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
210 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
211 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
212 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
213 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
214 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
215 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
216 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
217 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
218 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
219 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
220 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
221 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
222 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
223 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
224 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
225 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
226 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
227 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
228 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
229 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
230 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
231 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
232 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
233 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
234 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
235 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
236 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
237 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
238 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
239 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.000 uS
239 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
240 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
241 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
242 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
243 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
244 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
245 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
246 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
247 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
248 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
249 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
250 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
251 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
252 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
253 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
254 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
255 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
256 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
257 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
258 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
258 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
259 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
260 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
261 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
262 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
263 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
264 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
265 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
266 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
267 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
268 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
269 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
270 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
271 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
272 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
273 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
274 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
275 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
276 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
277 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
278 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
279 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
280 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.100 uS
280 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
281 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
282 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
283 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
284 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
285 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
286 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
287 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
288 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
289 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
290 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
291 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
292 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
293 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
294 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
295 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
296 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
297 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
298 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
299 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
300 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
301 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
302 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
303 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
304 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
305 secs servo min: -66.100 uS max: 67.000 uS sdev: 13.200 uS
19 Oct 2022 22:11 #254563
by An
Replied by An on topic HP Compaq Elite 8300 vs Dell Optiplex 7010
Hi everyone, I’m looking at using a hp 8300 ‘all in one’ for my upgrade to mesa Ethernet card and latest linuxcnc - it is touch screen and uses the same chipset as the sff. Where I am it is cheaper than the sff. Does anyone see any problem with using this machine? The one I have my eye on is i5 with 4gb ram. Thankyou
support.hp.com/us-en/product/hp-compaq-e...7/document/c03454218
- Thank you received: 5946
19 Oct 2022 22:36 #254570
Replied by tommylight on topic HP Compaq Elite 8300 vs Dell Optiplex 7010
Some of us use SFF HP 8300 and 8200 to run machines on daily basis, i have some in very "metal dust" environments for over two years, still working.
BTW, the one you linked to uses a TN LCD screen, so not very good when looking at it sideways, but quite good when looking directly.
And i can not find any more of the SFF variety...
Time to create page: 0.189 seconds
