HP Compaq Elite 8300 vs Dell Optiplex 7010
- my1987toyota
- Topic Author
- Thank you received: 271
30 Oct 2020 01:20 #187744
by my1987toyota
Maybe this will answer the question of do I drive my Toy in that kind of environment
this one of my sister driving my truck in water for the first time
this is an early one with a friend of mine riding with me
these video's have been taken in a gated multi owner property (15,000 acre's total 12,000 driveable)
unfortunately I haven't had the truck on the road for a few years.
I am trying to get my dad set up with a reliable truck so we can both go out and Offroad.
as far as the Dell OptiPlex 7010 . I have the replacement on the table with an SSD and I am
running tests as I type this post (on a different computer) .
Haven't made any changes in the Bios yet ( other then boot order ) I want to know the absolute worst case scenario.
first up is Linux Mint XFCE 19.3 . Then Debian Buster 10.6 XFCE
I will report my findings when I am done . Figure about a week.
Replied by my1987toyota on topic HP Compaq Elite 8300 vs Dell Optiplex 7010
OT: on:
Do you drive the Toyota in your avatar in the pictured environments? [If: my envy guaranteed. No way in my country]
OT: off.
If you can, get a SSD, good and fast USB stick, install LCNC on it (you will love to have that, always, at least I do!), attach it to thePC in question. Fire it up, go to bios, disable everything suspicious, boot into LCNC and do some thorough testing. You might need to pay the owner a beer. If it fails, undo your settings and have the owner sip the beer, go home and look fo another PC. If it is successful, I'd pay some more beers to bring the price down :-]
Greez
chris
- my1987toyota
- Topic Author
30 Oct 2020 02:56 - 30 Oct 2020 03:06 #187748
by my1987toyota
well I am sure I have done something wrong but here are the test results any way
as you can see I did something wrong I don't have latency readings
Last edit: 30 Oct 2020 03:06 by my1987toyota.
- my1987toyota
- Topic Author
30 Oct 2020 03:52 - 30 Oct 2020 03:53 #187750
by my1987toyota
A short test I still don't fully understand the numbers.
LinuxCNC pc tests, version 20200930, started 29.10.2020 23:34:41
General info:
Dell Inc., OptiPlex 7010
Bios version A29, dated 06/28/2018
Chipset: Intel Corporation 7 Series/C216
Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name : Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
cpu cores : 4
stepping : 9
cache size : 6144 KB
RAM related data:
Maximum Capacity: 32 GB
Size: No Module Installed
GPU related data:
product: Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller
configuration: driver=i915 latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Linux Mint 19.3"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
forum.linuxcnc.org/18-computer/39370-scr...-of-computer-latency
Desktop environment : lightdm
Windowmanager : Xfwm4
Displaymanager : lightdm
Kernel related data:
Kernel 5.0.0-32-generic
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: No, which is good!
Check if snd modules are loaded: Yes, may cause bigger latency.
can probably be disabled in bios, alternatively, you can run
"./block-snd-modules"
which has just now been created for your convenience.
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 :
Mice attached to USB:
Keyboards attached to USB:
Dell Computer Corp. Keyboard
LinuxCNC related data:
LinuxCNC version is: 2.8.0.96.g589db060d
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'vimeo.com/150574260', WID
Command for latency test is:
su cnc -c "latency-histogram --nobase --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a 1604028827.lat &"
Latency testing loop started Thu Oct 29 23:34:55 EDT 2020,
should end after Thu Oct 29 23:39:55 EDT 2020
Swap useage: prerun: 0, running: 0
CPU core temperatures:
Core 0: Tmin: 36.0°C, Tmax: 41.0°C, (high = +85.0°C, crit = +105.0°C)
Core 1: Tmin: 40.0°C, Tmax: 45.0°C, (high = +85.0°C, crit = +105.0°C)
Core 2: Tmin: 37.0°C, Tmax: 43.0°C, (high = +85.0°C, crit = +105.0°C)
Core 3: Tmin: 37.0°C, Tmax: 44.0°C, (high = +85.0°C, crit = +105.0°C)
last latency data is as follows:.
299 secs servo min:-999.900 uS max:8653.700 uS sdev: 7.400 uS
300 secs servo min:-999.900 uS max:8653.700 uS sdev: 7.400 uS
General info:
CPU related data:
cpu cores : 4
stepping : 9
RAM related data:
GPU related data:
Number of mice: 1
Mouse 0 :
Last edit: 30 Oct 2020 03:53 by my1987toyota.
- my1987toyota
- Topic Author
30 Oct 2020 18:36 - 30 Oct 2020 21:04 #187814
by my1987toyota
Dear God Debian Buster 10.6 is way better in latency then Mint was on the 7010 .
Jitter on base thread is around 11000 to 15000 ns. I am having some issues getting
the test script to unzip so I can use it . As soon as I get that sorted I will post the results.
with what I was getting with Mint ( base thread of around 10000000ns ) I was beginning
to dought the opti 7010 was going to work.
Last edit: 30 Oct 2020 21:04 by my1987toyota.
The following user(s) said Thank You: makermark
- my1987toyota
- Topic Author
30 Oct 2020 21:01 #187834
by my1987toyota
I was finally able to get the test script unzipped. Here are the test results
if I am reading this right , it will do just fine for my 7i76E board that I intend to use
LinuxCNC pc tests, version 20200930, started 30.10.2020 16:44:01
General info:
CPU related data:
cpu cores : 4
stepping : 9
RAM related data:
GPU related data:
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
Desktop environment : xfce4
Kernel 4.19.0-11-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
Check if pcspkr is loaded: Yes, may cause bigger latency.
can be eliminated using:
sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf
Number of mice: 1
Mouse 0 : PixArt USB Optical Mouse
Started firefox with 'vimeo.com/150574260', WID 50331651
su cnc -c "latency-histogram --nobase --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a 1604090598.lat &"
Latency testing loop started Fri 30 Oct 2020 04:44:14 PM EDT,
should end after Fri 30 Oct 2020 04:49:14 PM EDT
Core 0: Tmin: 45.0°C, Tmax: 62.0°C, (high = +85.0°C, crit = +105.0°C)
Core 1: Tmin: 48.0°C, Tmax: 68.0°C, (high = +85.0°C, crit = +105.0°C)
Core 2: Tmin: 48.0°C, Tmax: 66.0°C, (high = +85.0°C, crit = +105.0°C)
Core 3: Tmin: 45.0°C, Tmax: 65.0°C, (high = +85.0°C, crit = +105.0°C)
304 secs servo min: -58.500 uS max: 54.000 uS sdev: 3.100 uS
305 secs servo min: -58.500 uS max: 54.000 uS sdev: 3.100 uS
General info:
CPU related data:
cpu cores : 4
stepping : 9
RAM related data:
GPU related data:
Number of mice: 1
- my1987toyota
- Topic Author
31 Oct 2020 00:09 #187852
by my1987toyota
and the 2 hour test
LinuxCNC pc tests, version 20200930, started 30.10.2020 17:59:09
General info:
CPU related data:
cpu cores : 4
stepping : 9
RAM related data:
GPU related data:
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Number of mice: 1
Started firefox with 'https://vimeo.com/150574260', WID 50331651
su cnc -c "latency-histogram --nobase --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a 1604095133.lat &"
Latency testing loop started Fri 30 Oct 2020 05:59:23 PM EDT,
should end after Fri 30 Oct 2020 07:59:23 PM EDT
Core 0: Tmin: 50.0°C, Tmax: 68.0°C, (high = +85.0°C, crit = +105.0°C)
Core 1: Tmin: 56.0°C, Tmax: 74.0°C, (high = +85.0°C, crit = +105.0°C)
Core 2: Tmin: 54.0°C, Tmax: 72.0°C, (high = +85.0°C, crit = +105.0°C)
Core 3: Tmin: 52.0°C, Tmax: 71.0°C, (high = +85.0°C, crit = +105.0°C)
7201 secs servo min: -82.900 uS max: 69.600 uS sdev: 3.200 uS
7202 secs servo min: -82.900 uS max: 69.600 uS sdev: 3.200 uS
31 Oct 2020 07:18 - 31 Oct 2020 07:27 #187864
by seuchato
Replied by seuchato on topic HP Compaq Elite 8300 vs Dell Optiplex 7010
Hey, thanks for the vids. Guess hat chassis is now really dustfree! Impossible in my country. Guess you guys have tons of fun in your plot.
Regarding the script: Glad you got it sorted out. If you do not have any latency numbers, it is because of permissions. If you start the script in a directory created by root, normally only root has write rights. I'll have to address this in the next version of the script. For now, you can change the owner of the directory to the user the script runs the latency test.
Example below:
The directory "W510" is owned by root. User cnc will have read permissions only. So if you cd into "W510" and invoke the script there, you will not have any latency data written, as the very latency test is run under user cnc. To correct that, I would have to do the following:
hth
chris
Example below:
ls -l
insgesamt 32
drwxr-xr-x 2 cnc cnc 4096 Okt 24 21:59 'dh87RL i5 4570s'
drwxr-xr-x 2 cnc cnc 4096 Okt 24 21:59 Diverse2
drwxr-xr-x 2 cnc cnc 4096 Okt 25 22:40 'hp 8300 sff'
drwxr-xr-x 2 cnc cnc 4096 Okt 24 21:59 'Optiplex 980 DT #3'
drwxr-xr-x 2 cnc cnc 4096 Okt 24 21:59 'Optiplex 980 SFF #0'
drwxr-xr-x 2 cnc cnc 4096 Okt 24 21:59 'Optiplex 980 SFF #1'
drwxr-xr-x 2 cnc cnc 4096 Okt 29 14:29 T3500
drwxr-xr-x 2 root root 4096 Okt 31 08:16 W510
cd ..
chown cnc.cnc W510
cd W510
hth
chris
Last edit: 31 Oct 2020 07:27 by seuchato. Reason: added example
The following user(s) said Thank You: my1987toyota
- my1987toyota
- Topic Author
01 Nov 2020 02:55 #187964
by my1987toyota
Thanks seuchato I will eventually know what I am doing instead of fumbling around like a noob.
01 Nov 2020 04:39 #187984
by seuchato
I fumble around like a noob too, but doing so, I try concentrate on my new GF
- Thank you received: 5946
01 Nov 2020 22:50 #188062
Replied by tommylight on topic HP Compaq Elite 8300 vs Dell Optiplex 7010
You lucky .....I try concentrate on my new GF
Time to create page: 0.225 seconds
