HP Compaq Elite 8300 vs Dell Optiplex 7010
- my1987toyota
- Topic Author
- Thank you received: 271
16 Oct 2020 21:26 #186316
by my1987toyota
HP Compaq Elite 8300 vs Dell Optiplex 7010 was created by my1987toyota
So I have been weighing my options for control computers.
Using some information from Wikipedia ( probably a bad idea )
it looks like the HP Compaq Elite 8300 and the Dell Optiplex 7010
use the same basic chip set the Intel Q77. So this begs the question
will they both yield basically the same performance? If so then if one
is more available then the other you wont miss much if you use either.
at least that would be my theory.
I currently don't have either to compare .so the question I guess to the
Linuxcnc veterans is " Has anyone tested both "? If so was their a clear winner
for durability, stability, lower jitter numbers. ect.
- Thank you received: 5946
16 Oct 2020 21:36 - 16 Oct 2020 21:38 #186317
Replied by tommylight on topic HP Compaq Elite 8300 vs Dell Optiplex 7010
IIRC, the Dell 7010 should be a generation or two older than HP8300, not important...
Important:
I do have 2 of the HP 8300 and they are very nice, one is driving a machine for the last 3 weeks, the other is my daily driver in the shop for nearly 5 months and most of the tests on the machines are done on it. Get one with a 4 core cpu and 8GB and you are good.
Never had a 7010 although i can find plenty of them, but i did have a 9020 or similar and that was a beast, well it still is driving a wood router daily.
Edit:
Again IIRC 7010 does not have USB 3 ports.
Important:
Edit:
Last edit: 16 Oct 2020 21:38 by tommylight. Reason: More info
The following user(s) said Thank You: my1987toyota
- my1987toyota
- Topic Author
16 Oct 2020 21:52 #186319
by my1987toyota
Replied by my1987toyota on topic HP Compaq Elite 8300 vs Dell Optiplex 7010
the 7010's I have seen on ebay show the usb symbol and some with the ss next to the symbol but I haven't seen them
with the tell tale blue usb socket either . I am just not sure if the usb ss was a precursor to gen 3 or early gen 3 usb.
I am not historically very savy when it comes to that stuff hence the aforementioned Wikipedia search.
- my1987toyota
- Topic Author
16 Oct 2020 22:13 #186321
by my1987toyota
I just checked out a few different web site's . If the usb port has the USB symbol preceded by an SS ( Super Speed )
then it is USB 3.0. I guess some manufacturers decided they didn't want to bother with the blue color
for the inside of the socket.
- my1987toyota
- Topic Author
16 Oct 2020 22:18 #186323
by my1987toyota
Thanks tommylight . it definitely looks like I have my 2 finalists . I guess now it comes down to price and availability.
Important:
- my1987toyota
- Topic Author
16 Oct 2020 22:50 #186330
by my1987toyota
I just looked up the specs for the 9020's and yeah they look like they were.
- my1987toyota
- Topic Author
20 Oct 2020 12:21 #186676
by my1987toyota
Well as luck would have it were I work has a spare SFF Dell OptiPlex 7010.
it has the intel core i7 3.4 ghz and 4 gigs of ram
I already have a Samsung 860 EVO SSD ready for install and
since This will be a CNC control only it will have Debian Buster 10.6.0 for the O.S.
I cant wait to try the test script to see were it falls. If all goes well it will
either end up being my Lathe control or replacing the computer to control
the PnP.
the PnP.
20 Oct 2020 14:57 #186697
by seuchato
Replied by seuchato on topic HP Compaq Elite 8300 vs Dell Optiplex 7010
looking forward to see the results. These machines can be obtained for no money at the time being.
- my1987toyota
- Topic Author
22 Oct 2020 00:12 #186857
by my1987toyota
well this is embarrassing. It looks like the Dell OptiPlex 7010 has a few programs on it that the boss needs to keep.
Unfortunately I cant just give him the hard drive ( stupid Windows 10 ) so plan B I have another 7010 coming it has
the core i5-3570 instead ( a little faster then the standard 3470. It also has 8 gigs of ram
( hopefully 2 4gig sticks so I can test the difference )
. Oh well it's always something. The plan B computer will be in next week. Figure test results about a week after.
28 Oct 2020 20:27 - 28 Oct 2020 20:28 #187619
by seuchato
OT: on:
Do you drive the Toyota in your avatar in the pictured environments? [If: my envy guaranteed. No way in my country]
OT: off.
If you can, get a SSD, good and fast USB stick, install LCNC on it (you will love to have that, always, at least I do!), attach it to thePC in question. Fire it up, go to bios, disable everything suspicious, boot into LCNC and do some thorough testing. You might need to pay the owner a beer. If it fails, undo your settings and have the owner sip the beer, go home and look fo another PC. If it is successful, I'd pay some more beers to bring the price down :-]
Greez
chris
OT: off.
Greez
chris
Last edit: 28 Oct 2020 20:28 by seuchato. Reason: typos
Time to create page: 0.438 seconds
