linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
09 Jun 2021 15:24 #211626 by tjtr33
I have the ports correct now
and I can see the packets using tcpdump
sudo tcpdump -i any -n udp port 5000
...snip...
22:00:41.020871 IP 192.168.2.178.40206 > 192.168.2.177.5000: UDP, length 40
22:00:41.021237 IP 192.168.2.177.5000 > 192.168.2.178.40206: UDP, length 32
22:00:41.021882 IP 192.168.2.178.59440 > 192.168.2.177.5000: UDP, length 40
22:00:41.022238 IP 192.168.2.177.5000 > 192.168.2.178.59440: UDP, length 32
22:00:41.022888 IP 192.168.2.178.57804 > 192.168.2.177.5000: UDP, length 40
22:00:41.023241 IP 192.168.2.177.5000 > 192.168.2.178.57804: UDP, length 32
^C
3272 packets captured
3290 packets received by filter
0 packets dropped by kernel
It looks like there are xyz positions passed from eth1 to the esp32/w5500 40 bytes
and 4 encoder data passed back 32 bytes
There are no real motors or encoders on my system, no hardware at all for these early tests.
Does it require encoders connected to motors?
I go thru my router with no problems, this may be an advantage for long distance users.
( my network is 192.168.1.X and i use 192.168.2.177 for W5500 and 192.168.2.178 for my new eth1 card)
I see pulses on the step pins
but not what i expect
My step size is .0075mm ( 1.5pitch and 200 steps/rev nema17s)
For 1mm jog , i expect to see 133 pulses.( 133.333333 to be exact )
I do not see that,
I do not get repeatable traces on the scope.
I have not understood how the pulses are calculated,
but i think i should see the same trace for each 1mm jog .
Is that correct?
thanks TomP
09 Jun 2021 22:23 #211644 by BeagleBrainz
The scale scale is hardcoded in udp.comp.
Spend some time reading the code to work out how it works and your development will go ahead faster.
As this is experimental code some of the features that would be set when loading the linuxcnc component are hardcoded.
char *ipaddress;
RTAPI_MP_STRING(ipaddress,"ESP IP Address");
// Driver code
FUNCTION(update)
    motor_pos.pos0=posx*xscale;
    motor_pos.pos1=posy*yscale;
    motor_pos.pos2=posz*zscale;
    motor_pos.pos3=posu*uscale;
Ignore the RTAPI line as this is an experimental piece of code to set the IP address when loading the module.There are a few lines of code that needed modifying to use the current socket functions rather than some of the deprecated functions as used in the code. I've also been working on setting the scale as a parameter.
10 Jun 2021 04:09 #211663 by tjtr33
Thanks I missed the hardcoded scale in udp.comp.
I adjusted for my system, and used ok.
I get perfect 2uS pulses
but the burst is random in response to a 0.01mm jog step.
Yes, I will look further into the code.
TomP
10 Jun 2021 05:01 #211664 by BeagleBrainz
Is that measured on the scope or real world movement.
What do you mean "the burst is random in response to a 0.01mm jog step" ?
Have you sorted out the pins for step & direction in the esp32 code ?
Are you still getting realtime delays ?
10 Jun 2021 05:48 - 10 Jun 2021 05:50 #211665 by tjtr33
for scale as a param...
i added
param rw float scale=0.0 """scale: number of step pulses per unit of measure""";
to udp.cpm
and then was able to write
setp udp2.0.scale 133.3333333
in the .hal file
it worked
Later, I will look at other values to be passed (like dotted quad url )
HTH tomp
Last edit: 10 Jun 2021 05:50 by tjtr33. Reason: wrong tag
10 Jun 2021 06:00 #211666 by BeagleBrainz
I've already half coded that part
component udp "Compute the derivative of the input function";
pin in float posx;
pin in float posy;
pin in float posz;
pin in float posu;
// Scale as parameter, default is 100
param rw float xscale=100;
param rw float yscale=100;
param rw float zscale=100;
param rw float uscale=100;
pin out float test;
pin out float fdbx;
pin out float fdby;
pin out float fdbz;
pin out float fdbu;
pin out float enc0;
///variable double old;
pin out bit in_00;
pin out bit in_01;
pin out bit in_02;
pin out bit in_03;
pin out bit in_04;
pin out bit in_05;
pin out bit in_06;
pin out bit in_07;
pin out bit in_08;
pin out bit in_09;
pin out bit in_10;
pin out bit in_11;
pin out bit in_12;
pin out bit in_13;
pin out bit in_14;
pin out bit in_15;
pin out bit in_16;
pin out bit in_17;
pin out bit in_18;
pin out bit in_19;
pin out bit in_20;
pin out bit in_21;
pin out bit in_22;
pin out bit in_23;
pin out bit in_24;
pin out bit in_25;
pin out bit in_26;
pin out bit in_27;
pin out bit in_28;
pin out bit in_29;
pin out bit in_30;
pin out bit in_31;
pin in bit out_00;
pin in bit out_01;
pin in bit out_02;
pin in bit out_03;
pin in bit out_04;
pin in bit out_05;
pin in bit out_06;
pin in bit out_07;
pin in bit out_08;
pin in bit out_09;
pin in bit out_10;
pin in bit out_11;
pin in bit out_12;
pin in bit out_13;
pin in bit out_14;
pin in bit out_15;
pin in bit out_16;
pin in bit out_17;
pin in bit out_18;
pin in bit out_19;
pin in bit out_20;
pin in bit out_21;
pin in bit out_22;
pin in bit out_23;
pin in bit out_24;
pin in bit out_25;
pin in bit out_26;
pin in bit out_27;
pin in bit out_28;
pin in bit out_29;
pin in bit out_30;
pin in bit out_31;
option extra_setup yes;
function update;
license "GPL"; // indicates GPL v2 or later
// Server side implementation of UDP client-server model
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <netdb.h>
#include <linux/kernel.h>
#include <unistd.h>
struct axes  {
 hal_s32_t fb0;
 hal_s32_t fb1;
 hal_s32_t fb2;
 hal_s32_t fb3;
 hal_u32_t  io;
 int64_t enc0v;
}fb;
struct pos  {
 hal_s32_t pos0;
 hal_s32_t pos1;
 hal_s32_t pos2;
 hal_s32_t pos3;
 hal_u32_t   io;
 int64_t   analog;
}motor_pos;
#define BUFSIZE 512
//#define UDP_PORT 27181
#define SEND_TIMEOUT_US 100
#define RECV_TIMEOUT_US 100
#define READ_PCK_DELAY_NS 1000
int sockfd, portno, n;
int serverlen;
struct sockaddr_in serveraddr;
struct hostent *server;
char *hostname;
char buf[BUFSIZE];
char buf1[512];
float axes[9];
char buffer[512] ;
float scale=100.0;
char *ipaddress;
// Driver code
FUNCTION(update)
    hostname = "192.168.1.222";
    portno = 5000;
    /* socket: create the socket */
    sockfd = socket(AF_INET, SOCK_DGRAM, 0);
    /* gethostbyname: get the server's DNS entry */
    server = gethostbyname(hostname);
    /* build the server's Internet address */
    bzero((char *) &serveraddr, sizeof(serveraddr));
    serveraddr.sin_family = AF_INET;
    bcopy((char *)server->h_addr,
	  (char *)&serveraddr.sin_addr.s_addr, server->h_length);
    serveraddr.sin_port = htons(portno);
memcpy(&buf,&motor_pos,sizeof(motor_pos));
    /* send the message to the server */
    serverlen = sizeof(serveraddr);
    int ret;
    struct timeval timeout;
    timeout.tv_sec = 0;
    timeout.tv_usec = RECV_TIMEOUT_US;
    ret = setsockopt(sockfd, SOL_SOCKET, SO_RCVTIMEO, (char *)&timeout, sizeof(timeout));
    timeout.tv_usec = SEND_TIMEOUT_US;
    setsockopt(sockfd, SOL_SOCKET, SO_SNDTIMEO, (char *)&timeout, sizeof(timeout));
    sendto(sockfd, buf,sizeof(motor_pos), 0, &serveraddr, serverlen);
    //if (n < 0) {writes=writes+1;}
    recv(sockfd, buf1 ,sizeof(motor_pos), 0);
    //if(n < 0) {
    //reads=reads+1;
    //rtapi_delay(READ_PCK_DELAY_NS);
    close(sockfd);
//memcpy(buffer, buf, 1024);
memcpy(&fb, buf1, sizeof(fb));
fdbx=(float)fb.fb0/xscale;
fdby=(float)fb.fb1/yscale;
fdbz=(float)fb.fb2/zscale;
fdbu=(float)fb.fb3/uscale;
enc0=(float)fb.enc0v;
in_00=(fb.io >> 0) & 1;
in_01=(fb.io >> 1) & 1;
in_02=(fb.io >> 2) & 1;
in_03=(fb.io >> 3) & 1;
in_04=(fb.io >> 4) & 1;
in_05=(fb.io >> 5) & 1;
in_06=(fb.io >> 6) & 1;
in_07=(fb.io >> 7) & 1;
in_08=(fb.io >> 8) & 1;
in_09=(fb.io >> 9) & 1;
in_10=(fb.io >> 10) & 1;
in_11=(fb.io >> 11) & 1;
in_12=(fb.io >> 12) & 1;
in_13=(fb.io >> 13) & 1;
in_14=(fb.io >> 14) & 1;
in_15=(fb.io >> 15) & 1;
in_16=(fb.io >> 16) & 1;
in_17=(fb.io >> 17) & 1;
in_18=(fb.io >> 18) & 1;
in_19=(fb.io >> 19) & 1;
EXTRA_SETUP(){
//We test that we have an address on the command line
if (ipaddress == 0) {
	        rtapi_print_msg(RTAPI_MSG_ERR,"Message string for ESP32 IP Address missing\n");
        return -EINVAL;
    rtapi_print_msg(RTAPI_MSG_ERR,"Message string for ESP32 IP Address %s\n",ipaddress);
	return(0);
//Should socket be created here so that it is not recreated on every invocation
Snippet from halrun session
halcmd: loadrt udp "ipaddress=192.168.1.10"
Note: Using POSIX realtime
Message string for ESP32 IP Address 192.168.1.10
halcmd:
10 Jun 2021 06:08 #211667 by tjtr33
Hello
This is measured on scope without motor or driver
I would not connect a motor to what i see on the scope
I seect jog 0.1mm and press the UP arrow while scope is on Z step pin.
The result on the TDS720A is captured and does not look like any previous response.
I do the same thing and get differing results.
the pins he used... from header in my .ino...
/*  tjp 9jun2021
 *   what pins does he use?
 *    for step                          [b]actually the orig code used X gpio2 Y gpio16 Z gpio16, i tried to untangle b4[/b]
 *     axis 0 X gpio16
 *     axis 1 Y gpio2
 *     axis 3 Z gpio16     [b]!!! WTF  try use 13  9jun2021[/b]     OK got ols litany to work and can scope Z steps on gpio13
 *    for dir
 *     axis 0 X gpio4
 *     axis 1 Y gpio12
 *     axis 2 Z gpio14 ( NB he uses old school arduino pin out statements for these BUT
 *                          i don tthink it maters ( untested )
 *    for ENC
 *     gpio15
 *     gpio17          I dont know which he wanted for phase a or b   doesnt matter right now
 *    for CS
 *     d5 gpio5
 *    for SPI
 *     SCK     d18 gpio18
 *     MISO    d19 gpio19
 *     MOSI    d23 gpio23
 *  ... snip....
No, i run w/o Unxpected Real Time delay errors .
( hahaha while i write, you write I will spend more time reading on the calls used to generate pulses )
Thanks TomP
10 Jun 2021 06:12 - 10 Jun 2021 06:15 #211668 by BeagleBrainz
ESP32 Code
 UDPSendReceiveString:
 This sketch receives UDP message strings, prints them to the serial port
 and sends an "acknowledge" string back to the sender
 A Processing sketch is included at the end of file that can be used to send
 and received messages for testing with a computer.
 created 21 Aug 2010
 by Michael Margolis
 This code is in the public domain.
#include <stdlib.h>
#include <driver/gpio.h>
#include <Arduino.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
///#include <mcpwm.h>
///#include <ledc.h>
#include <esp_timer.h>
#include <driver/rmt.h>
#include <string.h>
#include <ESP32Encoder.h>
ESP32Encoder encoder;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
/*###########################Ethernet definitions ######################################*/
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
unsigned int localPort = 5000;      // local port to listen on
// buffers for receiving and sending data
char packetBuffer[1024];  // buffer to hold incoming packet,
EthernetUDP Udp;
char bufferin[1024] ;
char bufferout[1024] ;
/*##################################i nterupt function ################################*/
unsigned long timeus;
volatile int interrupts;
int totalInterrupts;//char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
hw_timer_t * timer = NULL;
portMUX_TYPE timerMux = portMUX_INITIALIZER_UNLOCKED;
/*######################### STEPPER variables ################################*/
int16_t steps_0_dir;
int16_t steps_0;
int16_t steps_1_dir;
int16_t steps_1;
int16_t steps_2_dir;
int16_t steps_2;
int16_t steps_3_dir;
int16_t steps_3;
int16_t steps_4_dir;
int16_t steps_4;
int8_t steps_0_executed;
int8_t steps_1_executed;
int8_t steps_2_executed;
int8_t steps_3_executed;
int8_t steps_4_executed;
int8_t steps_5_executed;
static int fdb0;
static int fdb1;
static int fdb2;
static int fdb3;
static int fdb4;
static int fdb5;
struct old {
int old_pos_0;
int old_pos_1;
int old_pos_2;
int old_pos_3;
int old_pos_4;
int old_pos_5;
}olds;
int8_t dir0=1;
int8_t dir1=1;
int8_t dir2=1;
int8_t dir3=1;
int8_t dir4=1;
int8_t dir5=1;
struct axes  {
 int fb0;
 int fb1;
 int fb2;
 int fb3;
 unsigned int io;
int64_t enc0;
axes fdbrt;
//struct axes mayaxes ;
struct pos  {
 int pos0;
 int pos1;
 int pos2;
 int pos3;
 uint32_t io;
int32_t analog;
}cmd;
axes fdb={0, 0, 0, 0, 0, 0};
/*######################### RMT configuration function  ################################*/
void initRMT() {
    rmt_item32_t rmtItem[2];
    rmt_config_t rmtConfig;
    rmtConfig.rmt_mode = RMT_MODE_TX;
    rmtConfig.clk_div = 20;
    rmtConfig.mem_block_num = 2;
    rmtConfig.tx_config.loop_en = false;
    rmtConfig.tx_config.carrier_en = 0;
    rmtConfig.tx_config.carrier_freq_hz = 0;
    rmtConfig.tx_config.carrier_duty_percent = 50;
    rmtConfig.tx_config.carrier_level = RMT_CARRIER_LEVEL_LOW;
    rmtConfig.tx_config.idle_output_en = true;
//#ifdef STEP_PULSE_DELAY
  // rmtItem[0].duration0 = 4 * 2;
//#else
    rmtItem[0].duration0 = 2;
//#endif
    rmtItem[0].duration1 = 4 * 2;
    rmtItem[1].duration0 = 0;
    rmtItem[1].duration1 = 0;
//AXIS 0 Config
    rmt_set_source_clk(RMT_CHANNEL_0, RMT_BASECLK_MAX);
    rmtConfig.channel = RMT_CHANNEL_0;
    rmtConfig.tx_config.idle_level =  RMT_IDLE_LEVEL_LOW;
    rmtConfig.gpio_num = GPIO_NUM_2;						//Step pin AXIS 0
    rmtItem[0].level0 = rmtConfig.tx_config.idle_level;
    rmtItem[0].level1 = !rmtConfig.tx_config.idle_level;
    rmt_config(&rmtConfig);
    rmt_fill_tx_items(rmtConfig.channel, &rmtItem[0], rmtConfig.mem_block_num, 0);
//AXIS 1 Config
    rmt_set_source_clk(RMT_CHANNEL_1, RMT_BASECLK_MAX);
    rmtConfig.channel = RMT_CHANNEL_1;
    rmtConfig.gpio_num = GPIO_NUM_16;						//Step pin AXIS 1
//AXIS 2 Config
    rmt_set_source_clk(RMT_CHANNEL_2, RMT_BASECLK_MAX);
    rmtConfig.channel = RMT_CHANNEL_2;
    rmtConfig.gpio_num = GPIO_NUM_16;						//Step pin AXIS 2
//AXIS 3 Config
    rmt_set_source_clk(RMT_CHANNEL_3, RMT_BASECLK_MAX);
    rmtConfig.channel = RMT_CHANNEL_3;
    rmtConfig.gpio_num = GPIO_NUM_16;						//Step pin AXIS 3
//AXIS 4 Config
    rmt_set_source_clk(RMT_CHANNEL_4, RMT_BASECLK_MAX);
    rmtConfig.channel = RMT_CHANNEL_4;
    rmtConfig.gpio_num = GPIO_NUM_16;						//Step pin AXIS 4
//AXIS 5 Config
    rmt_set_source_clk(RMT_CHANNEL_5, RMT_BASECLK_MAX);
    rmtConfig.channel = RMT_CHANNEL_5;
    rmtConfig.gpio_num = GPIO_NUM_16;						//Step pin AXIS 5
//IRAM_ATTR static void onTime()(){
static void IRAM_ATTR onTime() {
 //portENTER_CRITICAL_ISR(&timerMux);
if (steps_0_executed < steps_0) {
 RMT.conf_ch[RMT_CHANNEL_0].conf1.mem_rd_rst = 1;
 RMT.conf_ch[RMT_CHANNEL_0].conf1.tx_start = 1;
steps_0_executed++;
fdbrt.fb0=fdbrt.fb0+dir0;
if (steps_1_executed < steps_1) {
 RMT.conf_ch[RMT_CHANNEL_1].conf1.mem_rd_rst = 1;
 RMT.conf_ch[RMT_CHANNEL_1].conf1.tx_start = 1;
steps_1_executed++;
fdbrt.fb1=fdbrt.fb1+dir1;
if (steps_2_executed < steps_2) {
 RMT.conf_ch[RMT_CHANNEL_2].conf1.mem_rd_rst = 1;
 RMT.conf_ch[RMT_CHANNEL_2].conf1.tx_start = 1;
steps_2_executed++;
fdbrt.fb2=fdbrt.fb2+dir2;
if (steps_3_executed < steps_3) {
 RMT.conf_ch[RMT_CHANNEL_3].conf1.mem_rd_rst = 1;
 RMT.conf_ch[RMT_CHANNEL_3].conf1.tx_start = 1;
steps_3_executed++;
fdbrt.fb3=fdbrt.fb3+dir3;
if (steps_0_executed==steps_0 && steps_1_executed==steps_1
    && steps_2_executed==steps_2 && steps_3_executed==steps_3)
     //fdbrt.fb0=fdbrt.fb0+steps_0_dir;
     // timerAlarmDisable(timer);
      //timerEnd(timer);
    //timer = NULL;
//portEXIT_CRITICAL_ISR(&timerMux);
void setup() {
 // AXIS DIR PINS
 pinMode(4,OUTPUT);
 pinMode(12,OUTPUT);
 pinMode(14,OUTPUT);
 //REG_WRITE(GPIO_ENABLE_REG, BIT4);//Define o GPIO2 como saída
 //REG_WRITE(GPIO_ENABLE_REG, BIT15);//Define o GPIO2 como saída
 //REG_WRITE(GPIO_ENABLE_REG, BIT17);//Define o GPIO2 como saída
///////////////////////   encoder ///////////////////////////////
// Enable the weak pull up resistors
  ESP32Encoder::useInternalWeakPullResistors=UP;
  // Attache pins for use as encoder pins
  encoder.attachHalfQuad(15, 17);
 initRMT();
 /***************************************** Main timer stepper *****************/
//portMUX_TYPE timerMux = portMUX_INITIALIZER_UNLOCKED;
  // Configure Prescaler to 80, as our timer runs @ 80Mhz
  // Giving an output of 80,000,000 / 80 = 1,000,000 ticks / second
  timer = timerBegin(0, 10, true);
  timerAttachInterrupt(timer, &onTime, true);
  // Fire Interrupt every 1m ticks, so 1s
  timerAlarmWrite(timer, 45, true);
  timerAlarmEnable(timer);
// You can use Ethernet.init(pin) to configure the CS pin
  Ethernet.init(5);   // MKR ETH shield
//pinMode(15, OUTPUT);
//pinMode(2, OUTPUT);
  // start the Ethernet
  Ethernet.begin(mac, ip);
  // Open serial communications and wait for port to open:
 Serial.begin(230400);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // Check for Ethernet hardware present
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
    while (true) {
      delay(1); // do nothing, no point running without Ethernet hardware
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Ethernet cable is not connected.");
  // start UDP
  Udp.begin(localPort);
IPAddress remote = Udp.remoteIP();
int packetSize;
//////////////// LOOP////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
long enc0=0;
long enc1;
long enc2;
long enc3;
void loop() {
// if there's data available, read a packet
packetSize = Udp.parsePacket();
if (packetSize) {
    // send a reply to the IP address and port that sent us the packet we received
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    Udp.write(bufferin,sizeof(fdb));
    Udp.endPacket();
    //Udp.read(packetBuffer,50);
    Udp.read(packetBuffer,sizeof(cmd));
    memcpy(&cmd,packetBuffer,sizeof(cmd));
//Serial.println (cmd.pos5);
fdb={fdbrt.fb0,fdbrt.fb1,fdbrt.fb2,fdbrt.fb3,100,enc0};
//fdb={cmd.pos0,cmd.pos1,cmd.pos2,cmd.pos3,3};
memcpy(&bufferin, &fdb, sizeof(fdb));
//Serial.println (fdbrt.fb2);
//Serial.println (testch1);
steps_0_executed=0;
steps_0_dir=cmd.pos0 - fdbrt.fb0;
if(steps_0_dir > 0 && dir0 == -1 ){
   REG_WRITE(GPIO_OUT_W1TC_REG, BIT4);	//GPIO4 LOW (clear) Dir Axis 0;
   dir0=1;
   steps_0_dir=0;
 if(steps_0_dir < 0 && dir0 == 1 ){
   REG_WRITE(GPIO_OUT_W1TS_REG, BIT4);//GPIO4 HIGH (clear) Dir Axis 0;
   dir0=-1;
   steps_0_dir=0;
steps_0=abs(steps_0_dir);
steps_1_executed=0;
steps_1_dir=cmd.pos1 - fdbrt.fb1;
if(steps_1_dir > 0 && dir1 != 1 ){
   REG_WRITE(GPIO_OUT_W1TC_REG, BIT12);//GPIO4 LOW (clear)  Dir Axis 1;
    steps_1_dir=0;
   dir1=1;
 if(steps_1_dir < 0 && dir1 != -1 ){
   REG_WRITE(GPIO_OUT_W1TS_REG, BIT12);//GPIO4 HIGH (clear)  Dir Axis 1;
    steps_1_dir=0;
   dir1=-1;
steps_1=abs(steps_1_dir);
steps_2_executed=0;
steps_2_dir=cmd.pos2 - fdbrt.fb2;
if(steps_2_dir > 0 && dir2 != 1 ){
    steps_2_dir=0;
   REG_WRITE(GPIO_OUT_W1TC_REG, BIT14);//GPIO2 LOW (clear)  Dir Axis 2;
  dir2=1;
 if(steps_2_dir < 0 && dir2 != -1 ){
   steps_2_dir=0;
   REG_WRITE(GPIO_OUT_W1TS_REG, BIT14);//GPIO2 LOW (clear)  Dir Axis 2;
  dir2=-1;
steps_2=abs(steps_2_dir);
steps_3_executed=0;
steps_3_dir=cmd.pos3 - fdbrt.fb3;
if(steps_3_dir > 0 && dir3 != 1 ){
   REG_WRITE(GPIO_OUT_W1TC_REG, BIT14);//GPIO4 LOW (clear)  Dir Axis 3;
    steps_3_dir=0;
   dir3=1;
 if(steps_3_dir < 0 && dir3 != -1 ){
   REG_WRITE(GPIO_OUT_W1TS_REG, BIT14);//GPIO4 HIGH (clear)  Dir Axis 3;
    steps_3_dir=0;
   dir3=-1;
steps_3=abs(steps_3_dir);
//Serial.println(enc0);
//Serial.println(steps_0);
 //timerAlarmWrite(timer, 1000, true);
 // timerAlarmEnable(timer);
memcpy(&olds,&cmd, sizeof(cmd));
//fdb={888.8,444.4,111.1,0.555,3};
//delayMicroseconds(20);
enc0=encoder.getCount();
enc1=encoder.getCount();
enc2=encoder.getCount();
enc3=encoder.getCount();
The pulses are generated by the RMT module, which is setup via the init_RMT function.
The actual Pulses are generate here static void IRAM_ATTR onTime()
docs.espressif.com/projects/esp-idf/en/l...peripherals/rmt.html
Last edit: 10 Jun 2021 06:15 by BeagleBrainz.
The following user(s) said Thank You: tjtr33
13 Jul 2021 15:42 #214602 by tjtr33
Thanks BeagleBrainz,
I suspect this for me,
I have read thru it and it looks like code to test UDP comms.
and maybe confirm pulse generation is as expected.
I will test soon 13jul2021 22:36
tomp
24 Jul 2021 01:40 #215725 by taylorcmq
Hello my friend!
A friend here in Brazil and I came across this topic and found it very interesting, as there is great difficulty in purchasing a table card in our country, not to mention the high value that it reaches us!
Do I ask the friend if he has made any progress? and if it is already possible to put into operation!
Thank's for your time.
Time to create page: 0.250 seconds
