- Hardware & Machines
- Computers and Hardware
- linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
06 Dec 2021 09:18 #228428
by epineh
Replied by epineh on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Hi jzolee, thanks for the quick reply.
With 3 axis what would be the maximum step pulse rate ?
07 Dec 2021 08:08 #228509
by jzolee
Replied by jzolee on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Hi epineh, I measured the execution time of the code and based on this:
120 kHz / number of axes.
1 axis: 120 kHz
2 axes: 60 kHz
3 axes: 40 kHz
4 axes: 30 kHz
1 axis: 120 kHz
2 axes: 60 kHz
3 axes: 40 kHz
4 axes: 30 kHz
08 Dec 2021 04:43 - 08 Dec 2021 04:43 #228594
by Bari
Replied by Bari on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Is than an LPT connector on the left side of the enclosure using a standard pin-out for connection to a BOB?
Last edit: 08 Dec 2021 04:43 by Bari.
- Thank you received: 5986
08 Dec 2021 05:46 #228598
Replied by tommylight on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Looks like DB15 used for MIDI and gaming joysticks back in the days.Is than an LPT connector on the left side of the enclosure using a standard pin-out for connection to a BOB?
- Micromachining
08 Dec 2021 19:52 #228644
by Micromachining
Replied by Micromachining on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Do you think this ESP32 CNC board would work?
nl.aliexpress.com/item/1005003511726139....4bdbaf9857080d3ff9b9
09 Dec 2021 01:09 #228667
by eng
Replied by eng on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
I'm watching this video, soon I'll run the tests and see if I could get tr more i/o,
10 Dec 2021 22:38 - 11 Dec 2021 08:18 #228826
by jzolee
Hi eng, I improved the system:
i added more inputs and outputs as well as pwm option.
GPIO 2 -> OUT-00 or PWM-00
GPIO 4 -> OUT-01 or PWM-01
GPIO 25 -> OUT-02 or PWM-02
GPIO 1 -> OUT-03 or PWM-03
GPIO 14 -> OUT-04 or PWM-04
GPIO 15 -> OUT-05 or PWM-05
GPIO 26 <- IN-00 {pullup}
GPIO 27 <- IN-01 {pullup}
GPIO 32 <- IN-02 {pullup}
GPIO 33 <- IN-03 {pullup}
GPIO 34 <- IN-04 {no pullup}
GPIO 35 <- IN-05 {no pullup}
GPIO 36 <- IN-06 {no pullup}
GPIO 39 <- IN-07 {no pullup}
GPIO 12 -> step-0
GPIO 13 -> dir-0
GPIO 16 -> step-1
GPIO 17 -> dir-1
GPIO 21 -> step-2
GPIO 22 -> dir-2
GPIO 5 -> W5500 SCS
GPIO 18 -> W5500 SCLK
GPIO 19 <- W5500 MISO
GPIO 23 -> W5500 MOSI
In the ethernet library, I modified the SPI frequency in the w5500.h file because sometimes the data transfer was faulty.
I used a new method to calculate the step period time, which is faster. So the step frequency may be higher, but I can't control it because my machine can't do more than 40 kHz.
pwm can be activated on the outputs by setting the value of the parameter udp.pwm.xx.freq (1...65000 Hz)
The pwm duty ratio can be set on pin udp.pwm.xx (0 ... 1)
GPIO 12 -> step-0
GPIO 13 -> dir-0
GPIO 16 -> step-1
GPIO 17 -> dir-1
GPIO 21 -> step-2
GPIO 22 -> dir-2
GPIO 5 -> W5500 SCS
Last edit: 11 Dec 2021 08:18 by jzolee.
The following user(s) said Thank You: Bari
11 Dec 2021 00:08 #228833
by eng
I'm grateful for your effort, I'll do the tests and see how it turned out, could you ask me a question? I'm wanting to go deeper into your code to be able to use it on the stm32f407, do you believe it would be possible to use this same code with changes? I'm thinking about it because it would be an interesting way out to have more i/o ports.
11 Dec 2021 01:22 #228836
by eng
You could leave us your ini file and hal file because I'm having errors because you removed the maxvel, maxacc and put the accel.
11 Dec 2021 06:39 - 11 Dec 2021 08:18 #228851
by jzolee
Hi eng, maxvel is not required, it was a remnant of an older code when I tried position tracking mode.
accel = maxacc.
The code is currently running in speed mode, with this acceleration following the speed command. I just renamed it, in fact the code only works with one kind of acceleration.
I'm sorry, but I also renamed the io pins in udp.comp:
udp.in.xx
udp.out.xx
ps.
In the code I took advantage of the following features of esp32:
four hardware timers up to 25 ns / tic -> step generation for 3 (4) axes
two cores: one deals only with step generation, the other with everything else
FPU -> fast floating point calculation
High cpu speed (240Mhz)
I think it's worth implementing the code on another microcontroller if it has these capabilities. You may want to take advantage of other capabilities that aren't in ep32.
accel = maxacc.
udp.in.xx
udp.out.xx
ps.
Time to create page: 0.862 seconds
