- Hardware & Machines
- Computers and Hardware
- linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
25 Jul 2021 16:50 #215887
by Cncninja
Replied by Cncninja on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
what happened to BeagleBrainz
25 Jul 2021 17:53 #215893
by Bari
Replied by Bari on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
I believe that he left due to the stupid CoC thing.
The following user(s) said Thank You: taylorcmq
25 Jul 2021 17:58 #215894
by Clive S
Yes that is true. But it is a shame as he was a well respected member of the community and I do hope he will return.
Replied by Clive S on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
04 Aug 2021 11:49 - 04 Aug 2021 13:03 #216901
by tjtr33
Replied by tjtr33 on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
re BreagleBainz
I dunno why he left or that he did leave
I thought the comments were about MXMaster
But lets not talk about the COC here please.
C'mon , he never complained about COC. He complained it was difficult to keep up with the os changes and not being allowed to use some techniques he preciously used to install the arisc code. Keep that spam generating topic outta here. Plus he was a one man band and no real job afaict. He gave what he could..
Thx Michael hope to see you again
tomp
tomp
Last edit: 04 Aug 2021 13:03 by tjtr33. Reason: small scrollback
06 Aug 2021 04:22 #217024
by taylorcmq
Replied by taylorcmq on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
the doubt i have is anyone ever had any real return with this code, i will try to reformulate it and maybe soon bring new results, i am also following the mx work, a pity it was closed, i believe that the H5 boards should have been implemented has more powerful hardware, but I'll be happy if I can use it with the H3 that arrives tomorrow, even so I still intend to study more about esp32
10 Nov 2021 16:29 - 04 Dec 2021 21:15 #226005
by jzolee
Replied by jzolee on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Hi, I'm new to the forum, I'd like to share my plans with you.I like do it yourself things. I have been trying to build a hardware step generator with different microcontrollers for a long time. I got the idea for a good implementation on this forum.
I uploaded a video of a test:
2021.12.04 - I optimized some esp32 code snippets
Last edit: 04 Dec 2021 21:15 by jzolee.
11 Nov 2021 13:24 #226100
by taylorcmq
hi brother, could you explain to me the logic you are using, what are you thinking, what is the .ino file you used in esp32? I did some tests here the program works fine but the step generator is square, the steps don't build a good acceleration ramp!
11 Nov 2021 13:28 #226102
by taylorcmq
sorry but now i see the cpp file, i will test your code and let you know what i see
23 Nov 2021 04:54 #227373
by viewtop1
Replied by viewtop1 on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Hi All
I have a test setup of the above, well the Dlhenkel version actually as my ultimate use requires an encoder. Anyway, on a bench setup with a laptop running Linuxcnc and looking at the step gens on a scope, the outputs seem to be pretty acurate every milisecond. My question is how realtime is this ethernet implemtation? Lots of literature out there about the challenges of realtime ethernet. not my area of expertise, so if anyone more knowledgeable please chime in. Is this worth building a machine on?
23 Nov 2021 06:02 #227376
by Bari
It is all in early beta as you can see. You will be a beta tester like the rest of us if you build it!
Do you dare to go where it has not been fully tested yet?
Time to create page: 0.260 seconds
