Potential All-in-One Single Board Computers
- Thank you received: 5938
27 Nov 2023 16:59 #286630
Please do check if everything is OK.
Link
forum.linuxcnc.org/18-computer/50792-about-mesa-bus-switches
Replied by tommylight on topic Potential All-in-One Single Board Computers
Done.Can the last 7-8 posts please go into a new thread about Mesa bus switches or similar. It going a bit off track for a list of SBC's compatible with LCNC.
Link
The following user(s) said Thank You: Bari
01 Apr 2024 16:15 #297382
This seems to be the ultimate all in one for LinuxCNC, granted it needs a slimmed down version of Linux and shoehorning the RT kernel somehow.
Still at 12$ with one ARM and one RISC core, optional wifi6, 100Mbps ethernet, USB C, 8051 MCU running at 25 to 300MHz, MIPI connector, VPU, NPU at 0.5 TOPS, CSI, 512MB ram, etc....
01 Apr 2024 17:01 #297386
by RDA
Replied by RDA on topic Potential All-in-One Single Board Computers
Purely hypotethical, how hard/big of a job it would be to break the UI and LCNC to teon separate ”entities”.
So that you would run LCNC headless with a board like that and then plug in ”any” pc/laptop with LAN to it and let the ”any” pc run the UI.
So in very basic and not in any real tech spec, pass example json messages back and forth and then update the GUI, pass commands etc?
The g-code file would reside in the LCNC and the ”any” pc is just for GUI.
01 Apr 2024 23:21 - 01 Apr 2024 23:26 #297403
by cornholio
Replied by cornholio on topic Potential All-in-One Single Board Computers
Pretty much the way Machinekit went.
Although not really related to the topic.
Last edit: 01 Apr 2024 23:26 by cornholio.
02 Apr 2024 03:07 #297412
LinuxCNC already has remote GUI's and web interface, i never used any of those, and i never aimed for that way of using it.
I am much more interested in using a lite Linux for running LinuxCNC, not the heavy weight desktop versions we use daily, something like Porteus would be perfect as it is quite up to date and is under 400MB total, runs like a dream on a lot of PC's and laptops i own, some are pretty old.
And even all that is just nitpicking as latest Linux still run nicely on 10 year old hardware, USFF are cheap. can be attach to monitor with 4 of M4 screws so a touch screen with it behind and a network cable to control box with Mesa or EtherCAT is very clean and near perfect.
02 Apr 2024 03:42 #297414
by blazini36
Replied by blazini36 on topic Potential All-in-One Single Board Computers
What "remote GUI"? The webGUI thing looked half baked, not even sure if it's available anymore. There are command line servers in LinuxCNC but I'm not aware of an actual Remote GUI.....It took Machine Kit alot of work to get that done, I don't think it's ever been ported.LinuxCNC already has remote GUI's and web interface, i never used any of those,
02 Apr 2024 11:02 #297428
Yes, the web GUI was pretty rough back when i last checked, but it did work.
More importantly, we are talking about Linux, so pretty much anything can run remotely, even using SSH works for a lot of things, Andy mentioned this often:
-In a terminal ssh -Y to remote PC with LinuxCNC
-linuxcnc
This will open the config picker, and last i tried it it will run Axis GUI without issues, as far as i can recollect, was several years back last i tried.
Issues might arise when local network is not set up properly, so ping the LinuxCNC machine, good ping times never go above 1ms. And yes, i have run a Mesa 7i92 through a switch for over a week without ever dropping the link, from a laptop.
There is also linuxcncrsh, no idea how good or bad it is.
-linuxcnc
02 Apr 2024 11:22 #297430
by cornholio
The only issue with ssh is if you lose the connection Linuxcnc stops running.
A Vnc client / server is slightly better as When the client loses a connection the server keeps going on.
As for MK I’m not even sure it’s being actively developed.
One nice thing was that it could use the PRUs on the beagle bone black for step generation. There was hardware support for quadrature encoders.
21 Apr 2024 14:13 #298777
by MX_Master
Replied by MX_Master on topic Potential All-in-One Single Board Computers
Radxa X2L: Low-cost x86 SBC with RP2040
21 Apr 2024 15:03 #298780
by cornholio
RP2040 is only connected to PC via serial port, shame, spi would have been awesome
