Potential All-in-One Single Board Computers
19 Mar 2023 17:09 #267090
by Bari
Replied by Bari on topic Potential All-in-One Single Board Computers
Another Rpi4 replacement:
wiki.radxa.com/Rock3/3c
linuxgizmos.com/rock3-model-c-board-starts-at-39-00/
RK3566 64bit quad core processor
www.96rocks.com/blog/2020/10/21/rockchip-rk3566-highlights/
Quad-core Cortex-A55, frequency 1.6Ghz
GPU Mali G52
Memory LPDDR4@2112MT/s, 1/ 2/ 4/ 8GB variants
shop.allnetchina.cn/collections/top-new-...oducts/rock3-model-c
wiki.radxa.com/Rock3/downloads
GPU Mali G52
04 May 2023 17:25 #270650
by royka
Replied by royka on topic Potential All-in-One Single Board Computers
SBC with a s912 soc does also work well, did a test with a tv box:
forum.linuxcnc.org/18-computer/39371-res...cnc?start=330#270625
09 May 2023 07:35 #270996
by Ruddy
Replied by Ruddy on topic Potential All-in-One Single Board Computers
Anybody try RK3566 android tv box ?
it’s cheap, I wonder who done test this box ?
- echristley
- Thank you received: 21
10 May 2023 20:32 #271126
by echristley
Replied by echristley on topic Potential All-in-One Single Board Computers
Could we get another pinned topic called "All-in-One Single Board Computers That Worked"
I think you guys are doing great things, but you're inaccessible to the noobs. I'm looking to get a Bridgeport converted to LCNC. I've got a couple HP computers that I could gut, but I find the SBC compelling for having a compact installation. I just need to throw a little money around.
But, I get lost here. Y'all are into "the kernel loads on this board" and "don't buy that board, this board's ethernet is 5% faster". Which is exactly what you should do, because it is exactly what you want to do. But, I'd like to get a machine running, and then start playing.
So, how about a pinned thread of boards that have been demonstrated to reliably work, and I could feel happy spending some money on?
11 May 2023 00:05 #271139
by cakeslob
Replied by cakeslob on topic Potential All-in-One Single Board Computers
the only thing that is noob friendly and works is the raspberry pi with premade linuxcnc image. not exactly an all in one though. everything else is so fucking hard, all day, every day.
12 May 2023 02:41 - 12 May 2023 02:43 #271197
by Bari
Use a x86/amd64 PC. This thread was for devs and not for noobs.
Noobs should be looking into this thread forum.linuxcnc.org/18-computer/39371-res...or-use-with-linuxcnc
Last edit: 12 May 2023 02:43 by Bari.
13 May 2023 01:07 #271267
by buzzFab
Replied by buzzFab on topic Potential All-in-One Single Board Computers
I order one of these the other day, I'll add it to your list of potential boards.
I went with the 16gb/256gb variant
NanoPC-T6
www.friendlyelec.com/index.php?route=pro...oduct&product_id=292
www.rock-chips.com/uploads/pdf/2022.8.26...rief%20Datasheet.pdf
RK3588
4x ARM Cortex-A76(up to 2.4GHz)
4x Cortex-A55 CPU (up to 1.8GHz)
3x Cortex M0
Mali-G610 GPU
4GB/8GB/16GB LPDDR4X at 2133MHz
32GB/64GB/256GB eMMC
I really just picked it up for the 2x 2.5G Ethernet ports so I can use one for EtherCat devices and the 12v input so I can embed it in my control box and use an existing DIN mounted Meanwell PSU. I also paid for the optional M.2 WiFi Card (8822CE) but I don't think I will need it with dual RJ45.
NanoPC-T6
RK3588
3x Cortex M0
Mali-G610 GPU
The following user(s) said Thank You: Bari
18 May 2023 17:58 #271616
by buzzFab
Orange Pi 5 Plus with 16gb ram is available from aliexpress as of today
www.aliexpress.com/item/1005005585029938.html
www.aliexpress.us/item/3256805375595121.html
www.aliexpress.com/item/1005005572414487.htm
This is also a rk3588 SBC similar to the nanopc-t6 i posted above but with no integrated eMMc
I ordered one of these as well
20 May 2023 18:15 #271767
by royka
Ordered one too to replace the rk3588s which I'm going to use for LinuxCNC. I'll use it with a Mesa card.
Guglielmi has made a software stepgen driver for this board.
His latency test shows it's a very good all-in one candidate:
forum.linuxcnc.org/18-computer/48079-can...cnc?start=170#271679
21 May 2023 02:31 #271791
by buzzFab
I thought the driver Guglielmi was working on was for the OPi5 which has RK3588S
Are you talking about the OPi5 Plus which has a RK3358?Ordered one too to replace the rk3588s which I'm going to use for LinuxCNC. I'll use it with a Mesa card.
Time to create page: 0.215 seconds
