Minor Annoyance -- One Terminal Icon Added After Each Reboot
- Scrappy_000
- Topic Author
- Thank you received: 8
22 Mar 2023 18:01 #267308
by Scrappy_000
Y'all,
I've got bigger issues to deal with (to be featured in another post), but in the meantime, I'd like to fix whatever is causing the accumulation of terminal icons, the number of which is incremented by one with each reboot. I'm rebooting a lot while diagnosing my setup, so I'm getting a lot of these and am getting tired of having to click "quit" for each one! Is there some setting that will prevent this?
(running 2.8.4 if it matters)
Thanks,
Scrappy
Thanks,
Scrappy
22 Mar 2023 19:05 #267310
by JPL
Replied by JPL on topic Minor Annoyance -- One Terminal Icon Added After Each Reboot
Here is how to solve this issue (nm-tray icon): forum.linuxcnc.org/38-general-linuxcnc-q...little-issues#226480
The following user(s) said Thank You: Scrappy_000
- Scrappy_000
- Topic Author
22 Mar 2023 19:25 #267313
by Scrappy_000
Replied by Scrappy_000 on topic Minor Annoyance -- One Terminal Icon Added After Each Reboot
Thank you! I must not have used the right combination of keywords in looking for the solution.
- Thank you received: 5944
22 Mar 2023 19:59 #267316
Replied by tommylight on topic Minor Annoyance -- One Terminal Icon Added After Each Reboot
That is not terminal icon, so no results will show on search, but a lot of wrong results will show!Thank you! I must not have used the right combination of keywords in looking for the solution.
23 Mar 2023 03:50 #267343
Replied by rodw on topic Minor Annoyance -- One Terminal Icon Added After Each Reboot
I had bigger issues at the time but I solved this altogether by upgrading to Bullsye and subsequently Bookworm.....
Time to create page: 0.218 seconds
