New micro PC problems
- B.Reilly01
- Topic Author
- Thank you received: 11
11 Jan 2024 11:53 - 11 Jan 2024 14:14 #290421
by B.Reilly01
New micro PC problems was created by B.Reilly01
My old Optiplex bit the dust, so I picked up a very inexpensive micro PC off Amazon, a BMAX running an N4000 processor with 8gb of ram. I had no idea if this was suitable or not, and now I'm suspecting not. I got LinuxCNC 2.9.2 installed, but I'm getting errors. See the attached images. Also attached are my INI and HAL files. Based on the histogram latency, I suspect there's still power management turned on somewhere maybe? I'm running a Mesa 7i97T and 7i76.
Last edit: 11 Jan 2024 14:14 by B.Reilly01. Reason: Actual LinuxCNC was 2.9.2, not 2.9.1
11 Jan 2024 15:28 #290430
Replied by PCW on topic New micro PC problems
Have you disabled all power management options in the BIOS?
(C states > C1 EIST, turbo modes etc)
What are you ping times like?
First:
ping -c 4 -i .2 10.10.10.10
Then:
sudo chrt 99 ping -i .001 -q 10.10.10.10
Stop the last command after a minute or so with control C to see the stats
Also for the latency-histogram you should not use a base thread as it will
skew the results since that CPU/OS cannot handle a 25 KHz base thread.
latency-histogram --nobase --sbinsize 1000
First:
Then:
- B.Reilly01
- Topic Author
11 Jan 2024 20:05 - 11 Jan 2024 20:13 #290452
by B.Reilly01
Replied by B.Reilly01 on topic New micro PC problems
Ping numbers seem okay, I've turned off as much power management as I can find,although I know there are C States and I cannot find them again... Realized the latency histogram included opening linuxcnc which probably broke it - uploaded another image
Last edit: 11 Jan 2024 20:13 by B.Reilly01.
12 Jan 2024 02:36 #290467
Do you still get real time errors?
The 1.1 GHz is not terribly promising, you may need to run a lower servo thread rate like 2 ms on that hardware
- B.Reilly01
- Topic Author
12 Jan 2024 02:54 #290468
by B.Reilly01
I think the hardware is too under powered, I'm still getting errors at 2ms.
- B.Reilly01
- Topic Author
05 Feb 2024 23:52 - 05 Feb 2024 23:56 #292597
by B.Reilly01
New Computer, similar problems... See the attached error warnings. This is on a new(er) Optiplex 9020 with 16gb of ram. As you can see from the latency histogram, I don't seem to have a real latency problem, but I'm still triggering these latency errors and communication errors...
Last edit: 05 Feb 2024 23:56 by B.Reilly01. Reason: 16gb ram, not 32
- Thank you received: 5934
06 Feb 2024 00:57 #292602
Replied by tommylight on topic New micro PC problems
Disable "hyperthreading" in BIOS
06 Feb 2024 01:23 #292604
Make sure you disable IRQ coalescing if you have an intel MAC on you motherboard
Also disable all power management, EIST, Turbo modes and Cstates >C1 in the BIOS
What ping time do you have?
- B.Reilly01
- Topic Author
06 Feb 2024 02:34 - 06 Feb 2024 02:42 #292606
by B.Reilly01
Pings are between .2 and .33 ms, 0% loss. All hyperthreading, C States, Turbomodes, etc is disabled. Only thing still on is Multi Core Support i did not see IRQ coalescing
edit: Turning off multicore support did not help
Last edit: 06 Feb 2024 02:42 by B.Reilly01.
06 Feb 2024 02:57 #292610
by scotth
Replied by scotth on topic New micro PC problems
sudo ethtool -C eno1 rx-usecs 0
Try this.
Try this.
Time to create page: 0.187 seconds
