New micro PC problems
- B.Reilly01
- Topic Author
- Thank you received: 11
06 Feb 2024 03:04 #292613
by B.Reilly01
Replied by B.Reilly01 on topic New micro PC problems
Not sure what that does, but it had no effect... The first error pops up immediately on opening LinuxCNC and the Smart Serial port 0: Dolt not cleared from previous servo thread follows close behind. Other errors pop randomly if I leave the window open long enough
06 Feb 2024 04:03 #292617
Replied by PCW on topic New micro PC problems
Can you launch LinuxCNC and then (in a terminal) type:
halcmd show param *.tmax
and post the results here
- B.Reilly01
- Topic Author
06 Feb 2024 11:17 - 06 Feb 2024 11:38 #292643
by B.Reilly01
Sure thing:
Parameters:
Owner Type Dir Value Name
36 s32 RW 0 hm2_7i97.0.read-request.tmax
36 s32 RW 7031644 hm2_7i97.0.read.tmax
36 s32 RW 56740 hm2_7i97.0.write.tmax
29 s32 RW 6012 motion-command-handler.tmax
29 s32 RW 23456 motion-controller.tmax
39 s32 RW 14320 pid.s.do-pid-calcs.tmax
39 s32 RW 14072 pid.x.do-pid-calcs.tmax
39 s32 RW 5820 pid.y.do-pid-calcs.tmax
39 s32 RW 10496 pid.z.do-pid-calcs.tmax
30 s32 RW 7064596 servo-thread.tmax
Looks like I have a real problem on hm2_7i97.0.read??
Parameters:
Last edit: 06 Feb 2024 11:38 by B.Reilly01.
- B.Reilly01
- Topic Author
08 Feb 2024 01:06 #292805
by B.Reilly01
Any ideas what could cause this? Is my 7i97T defective?
- Thank you received: 5934
08 Feb 2024 01:21 #292807
Replied by tommylight on topic New micro PC problems
Try another 5V power supply for the Mesa 7i97.
And another network cable.
The following user(s) said Thank You: B.Reilly01
08 Feb 2024 01:27 #292810
Looks like multiple ms of response time, it could be cable or power related
but most likely a problem with the host PC (either setup, OS dependent or inherent
in the PC hardware)
If you get a red init light after LinuxCNC loses communication, the problem
is _not_ power related.
in the PC hardware)
08 Feb 2024 02:10 #292812
Replied by rodw on topic New micro PC problems
Please review th e heading Network latency on page 3 of the guide I've been updating ?
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
- B.Reilly01
- Topic Author
08 Feb 2024 11:29 #292839
by B.Reilly01
Thank you all of you. After reviewing your document Rod, I realized my m.2 network card (wireless) was Realtek. Uninstalling this solved the problem. I ordered an Intel M.2 wireless card and will give that a shot. If that also has a problem I'll try USB, then I'll just accept that I don't get wireless.
08 Feb 2024 15:42 #292852
Usually USB WIFI dongles are fine, conversely MiniPCIE WIFI cards
are often horrible for network latency. I suspect this is because
they include BIOS ROMs that contain unspeakably bad code...
09 Feb 2024 09:59 - 09 Feb 2024 09:59 #292922
I suspect that the unspeakably bad code means that the m.2 is not much different to pcie.
However I have noticed in more recent distros, performance has imnproved in one instance my Gigabyte Brix ran horrific latency with the pcie card installed when I first started so I ran a USB wifi dongle. On Bookwoem its now fine.
Last edit: 09 Feb 2024 09:59 by rodw.
Time to create page: 0.225 seconds
