Reload Program Through Pin
18 Aug 2015 08:44 #61501
by Delron
Reload Program Through Pin was created by Delron
I'm interested to know if anyone has solved this yet?
18 Aug 2015 20:07 #61506
by ArcEye
Replied by ArcEye on topic Reload Program Through Pin
Unless you hack into Axis itself, there is nothing to solve, Andy has given the answer.
axis-remote --reload
Send that by whatever method you like, the M code script is the easiest.
The best programmatic solution would be to add to axisui and create a bit pin which triggers a reload.
See www.mgware.co.uk/ > Axis Modifications > Disable Run
for an example of how to add to the axisui pins
24 Aug 2015 00:17 #61703
by Delron
I have tried to use "Axis-remote --reload &" in every-which-way I can think of. It always hangs for seconds and then throws an error after executing.
Here is the last method I tried.
M101
#!/bin/sh
halcmd setp halui.mode.mdi true
axis-remote -m "o100 call"
axis-remote —reload &
exit 0
Sure would like to see Linuxcnc create a method to deal with this problem in the next release.
Replied by Delron on topic Reload Program Through Pin
M101
#!/bin/sh
exit 0
24 Aug 2015 00:54 #61705
Replied by PCW on topic Reload Program Through Pin
Did you try your script from the command line to see what the errors were?
24 Aug 2015 00:58 #61706
by Delron
Works from the command line fine.
Only delays and error when evoked from M-code
24 Aug 2015 01:02 #61707
what is the error?
(of course you cannot invoke this when running a program)
24 Aug 2015 01:06 #61708
by Delron
Running a z-probe routine evoked from a pendant.
Error is "can't do this in manual mode."
It does do it, just hangs for a long time then spits the error after reloading.
I see many other people having the same problem.
what is the error?
24 Aug 2015 01:08 #61709
by Delron
Same problem as this guy.
www.linuxcnc.org/index.php/english/forum...-vs-keyboard-end-key
this post led me to believe he may have solved it, but not for me. I'm running latest release.
24 Aug 2015 01:33 #61711
Wonder if there's is a race condition? (mode not changed before reload issued)
24 Aug 2015 02:52 #61714
by BigJohnT
Replied by BigJohnT on topic Reload Program Through Pin
If you get a wrong mode error then your code needs to check the mode and place LinuxCNC into the correct mode (MDI).
Take a look at halui modes.
www.linuxcnc.org/docs/2.7/html/man/man1/halui.1.html
You can also do this with the python interface.
JT
JT
Time to create page: 0.105 seconds
