Reload Program Through Pin
05 Apr 2016 19:16 #72794 by bogie6040
andy wrote:
Where did you save the file? (ie, the Python file here:
I placed the newly created file in /usr/bin with all permissions and executable.
05 Apr 2016 19:34 - 05 Apr 2016 19:35 #72797 by andypugh
Replied by andypugh on topic Reload Program Through Pin
Does it run from the command line?
Is it possible that the #! does not point to your version of Python?
Last edit: 05 Apr 2016 19:35 by andypugh.
05 Apr 2016 19:41 #72799 by bogie6040
jake@debian-test:/usr/bin$ pwd
/usr/bin
jake@debian-test:/usr/bin$ echo $PATH
/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
jake@debian-test:/usr/bin$ ls -l update
-rwxrwxrwx 1 root root 319 Apr 4 14:44 update
jake@debian-test:/usr/bin$ halrun
halcmd: loadusr update
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
5 bit IN FALSE update.trigger
halcmd: exit
jake@debian-test:/usr/bin$ cd /home/jake/linuxcnc
jake@debian-test:~/linuxcnc$ pwd
/home/jake/linuxcnc
jake@debian-test:~/linuxcnc$ halrun
halcmd: show pin
Component Pins:
halcmd: exit
05 Apr 2016 19:43 - 05 Apr 2016 19:48 #72800 by bogie6040
Don't know if this means anything but.......\
jake@debian-test:/usr/bin$ python update
RTAPI: ERROR: could not open shared memory (No such file or directory)
HAL: ERROR: could not initialize RTAPI
File "update", line 4, in <module>
h = hal.component("update")
hal.error: Invalid argument
Last edit: 05 Apr 2016 19:48 by bogie6040. Reason: Here is the file as it sits in /usr/bin Remove .txt of course
05 Apr 2016 19:46 #72801 by andypugh
I think I have given misleading advice.
There is no "update" function as the component is a user-space program, not a realtime component.
Ignore the "addf" line, it will never work. But the component itself ought to have the desired effect if you toggle the update.trigger pin.
05 Apr 2016 19:56 #72803 by bogie6040
test_postgui.hal contains:
loadusr update count=1
# addf update servo-thread
net jake-update-backplot update.trigger <= pyvcp.update-button
I still get this:
Debug file information:
inifile: warning: File contains DOS-style line endings.
test_postgui.hal:3: Pin 'update.trigger' does not exist
22738
PID TTY STAT TIME COMMAND
22792
Stopping realtime threads
Unloading hal components
05 Apr 2016 22:08 #72815 by andypugh
First, get rid of the DOS-style line endings.
The pin existed before:
halcmd: show pin
Component Pins:
There it is....
06 Apr 2016 14:37 #72850 by bogie6040
DOS style endings.... I have seen this in other posts, I have yet to see a definitive answer on what they look like or how to find them....
I assume the warning is talking about the configurations main .ini file (in this case axis.ini which is attached) I have looked all through the file and I don't see anything out of the ordinary.
halcmd: show pin
Component Pins:
There it is....
I don't understand what your getting at here....
06 Apr 2016 14:45 - 06 Apr 2016 14:45 #72852 by andypugh
There is a (CR) at the end of the line "# EMBED_TAB_COMMAND = python camview.py -w {XID}"
I found it by turning on line-ending visibility in Notepad++
I think that there is a similar feature in gedit.
You loaded the component. The pin existed then. what has changed since if the pin does not exist now after you load the component?
Last edit: 06 Apr 2016 14:45 by andypugh.
06 Apr 2016 19:25 #72867 by bogie6040
OK, got rid of the dos style ending..... It's really nice it doesn't tell you where it found the dos style ending - it's like an easter egg hunt after finding a text editor that will display the hidden characters.......
Why does it care anyway just ignore them.....
I also got the error to go away but it still doesn't work, so this won't work with a pyvcp type hal pin??
Time to create page: 0.179 seconds
