cycle timer not working
28 Nov 2012 20:16 #27040
by BigJohnT
I spend some time this morning fixing the description as the automagic generation of the man pages doesn't like a tab character and while I was at it I fixed some typos and reworded it a bit... see what you think about the description now. Might take an hour or so to show up in the online docs.
Replied by BigJohnT on topic cycle timer not working
the documentation over here could be improved
linuxcnc.org/docs/2.5/html/man/man9/time.9.html
29 Nov 2012 09:47 #27065
by jlviloria
Replied by jlviloria on topic cycle timer not working
Andy ...
Many times thought about retiring ...
thank you all for your help and patience.
Now I'm dedicated to learning HAL to improve.
tomorrow I'll upload videos and pictures
thanks
Jorge Viloria
Colombia
thanks
Jorge Viloria
Colombia
04 Feb 2013 21:14 #29568
by tommy
Replied by tommy on topic cycle timer not working
I'm trying to implement this timer into my machine configuration, but I guess I missed something...
What I did was:
-Copy/paste pyvcp code from HERE into my .xml file
- copy/paste contence for post-gui.hal into mine
I also took care about:
PYVCP = custom.xml
POSTGUI_HALFILE = custom.hal
HALUI = halui
in my INI file.
After running linuxcnc I'm reading this:
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/not.ko': -1 File exists
custom.hal:3: exit value: 1
custom.hal:3: insmod failed, returned -1
See the output of 'dmesg' for more information.
5670
PID TTY STAT TIME COMMAND
5756
Stopping realtime threads
Unloading hal components
What I did was:
PYVCP = custom.xml
HALUI = halui
in my INI file.
5670
5756
04 Feb 2013 21:56 - 04 Feb 2013 22:24 #29569
by cncbasher
Replied by cncbasher on topic cycle timer not working
see custom.hal:3: exit value: 1
are you loading the same component twice ? , what is line 3 of your custom hal file
are you loading the same in your machine hal file ?
difficult to debug without seeing your configuration files
i suspect you have a typo or duplicate entry somewhere
i have just try'd the code on my machine and it works fine
Last edit: 04 Feb 2013 22:24 by cncbasher.
04 Feb 2013 22:33 - 04 Feb 2013 22:34 #29572
You need to consolidate them onto one loadrt line in the first HAL file, and make sure that the custom.hal uses the correct index when referring to the not component.
It is possible that TWO_PASS in the INI file might resolve the problem, if you prefer. But I don't know if that resolves the component indexes. (probably not, as you might _want_ to refer to a component created in one HAL file in another).
www.linuxcnc.org/docs/html/config/ini_co...id_sub_hal_section_a
Replied by andypugh on topic cycle timer not working
You are trying to load the "not" HAL component twice (ie, there is a loadrt not line in two separate HAL files).insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/not.ko': -1 File exists
Last edit: 04 Feb 2013 22:34 by andypugh.
04 Feb 2013 23:02 #29573
by dgarrett
Replied by dgarrett on topic cycle timer not working
hal files can be made more modular and readable with TWOPASS processing if components are loaded with names= option
more details are at
linuxcnc.org/docs/html/common/starting-emc.html#_twopass
more details are at
05 Feb 2013 04:17 - 05 Feb 2013 04:21 #29596
by tommy
Yes, in my cutom.hal is loadrt not
and in my "main" hal file is also line " loadrt not count=1 " and its a part of section where are signals for scope created, for tuning servos (basically I'm using Pico's hal config modified for my machine)
So what can I do to solve this?
If I just delete or "comment out" this line in my custom.hal is not enough, because then I'm getting error on line : addf not.0 servo-thread
Last edit: 05 Feb 2013 04:21 by tommy.
05 Feb 2013 04:30 #29601
Change the count=1 to count=2 in the main HAL file, delete the loadrt not from the custom.hal file, use not.1 rather than not.0 in the custom.hal file.Yes, in my cutom.hal is loadrt not
05 Feb 2013 04:50 #29603
by tommy
Nice! Thank you Very much, problem solved!
Now just one more thing, that I'm not sure about ... I have not only this timer widget and would like to add also one for spindle rpm shown. Do I need to create new .xml file or simply add code to this one? And can I do same for my custom.hal?
05 Feb 2013 05:01 #29607
I think you can only have one XML file, but you can have as many HAL files as you like. So, you can have all the HAL code in one file, or split it in a way to suit you. There is nothing "magic" about custom.hal, if you look in the INI file you will see that the HAL files are simply read in sequence.
Time to create page: 0.189 seconds
