XHC-HB04 wireless MPG pendant HAL module
23 Jun 2013 15:01 #35939
by f1oat
Replied by f1oat on topic XHC-HB04 wireless MPG pendant HAL module
I cannot see it, the access to this ebay item is blocked from my place.
23 Jun 2013 15:25 #35940
by tommy
Replied by tommy on topic XHC-HB04 wireless MPG pendant HAL module
23 Jun 2013 15:28 #35941
by f1oat
Looks identical to my unit.
30 Jun 2013 16:07 #36168
by tommy
A little help needed, to get things to work:
- where to put provided files (Makefile, xhc-hb04.c)?
- what to do with them (compile, how to compile, any customization needed)?
30 Jun 2013 17:46 #36170
by f1oat
I have updated the web page with additional instructions for compilation.
Let me know if something is missing.
Frederic.
Frederic.
30 Jun 2013 18:55 #36172
by tommy
Thank you, I tested out right away, and it works perfectly!
Next thing will be adjusting to my keys layout which is a bit different then the one I ordered, but shouldn't be a problem to modify HAL.
30 Jun 2013 23:09 #36176
by f1oat
I believe some C code modifications may be necessary for new layout.
Come back to me if you have problem, I will post the procedure to get the informations I will need for the patch.
Frederic.
Frederic.
01 Jul 2013 03:44 - 04 Jul 2013 01:52 #36179
by tommy
Last edit: 04 Jul 2013 01:52 by tommy.
The following user(s) said Thank You: bottleworks
01 Jul 2013 21:05 #36195
by tommy
And there is another thing, as I need to run my machine in World mode, which disables incremental steps, so the only possibility to jog is in continuous mode, where jog wheel has no function for now ... any solution?
03 Jul 2013 04:44 #36252
by f1oat
Thank you for the table about buttons mapping, that helps a lot.
I have uploaded the V03 to the wiki.
Now, there is a configuration file to define the layout and associated HAL pins.
New command line options, see first line of xhc-hb04.hal.
There is no more xhc-hb04.simu executable. The xhc-hb04 can run both in simulation mode or as a HAL module (-H flag).
The xhc-hb04-layout2.ini should be ok for you.
g++ is used instead of gcc: hope there is no compilation issue on your side.
Frederic.
Frederic.
Time to create page: 0.209 seconds
