XHC-HB04 wireless MPG pendant HAL module
03 Jul 2013 05:03 #36254
by f1oat
Replied by f1oat on topic XHC-HB04 wireless MPG pendant HAL module
I do not know world mode: how can I activate it to investigate the issue on my setup ?
And there is another thing, as I need to run my machine in World mode, which disables incremental steps, so the only possibility to jog is in continuous mode, where jog wheel has no function for now ... any solution?
03 Jul 2013 16:55 #36265
Try running one of the robot configurations. The Puma ons is good, as you get a 3D model of the simulated machine.
You can switch from joint mode to world mode with the $ key.
Replied by andypugh on topic XHC-HB04 wireless MPG pendant HAL module
The following user(s) said Thank You: f1oat
03 Jul 2013 17:01 #36266
This might be over-elaborate. I would not be at all surprised to find that the button mapping changes randomly as they bring out different versions.
I would be tempted to simply call the buttons button-01, button-02 and so on, and then leave it to the integrator to figure out which physical button is which, and which function they want to give it in HAL.
Now, there is a configuration file to define the layout and associated HAL pins.
03 Jul 2013 20:36 #36271
by tommy
Thank you for your effort!
I might need some help or just for checking if I did right ...
for compilation, I did same as for previous version (make, make install), no errors there ... what I did change is in hal to xhc-hb04-layout2.ini, but when I run linuxcnc I get error on:
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
xhc-hb04.hal:45: Pin 'xhc-hb04.button-x0' does not exist
xhc-hb04-layout2.ini file is placed in same folder as rest of hal and ini files for my machine config.
Replied by tommy on topic XHC-HB04 wireless MPG pendant HAL module
Thank you for the table about buttons mapping, that helps a lot.
I have uploaded the V03 to the wiki.
New command line options, see first line of xhc-hb04.hal.
There is no more xhc-hb04.simu executable. The xhc-hb04 can run both in simulation mode or as a HAL module (-H flag).
The xhc-hb04-layout2.ini should be ok for you.
g++ is used instead of gcc: hope there is no compilation issue on your side.
Frederic.
03 Jul 2013 23:54 - 03 Jul 2013 23:55 #36280
by f1oat
You will need to delete erroneous lines in xhc-hb04.hal because there are no X=0, Y=0 and Z=0 buttons on your MPG.
Frederic.
Frederic.
Last edit: 03 Jul 2013 23:55 by f1oat.
04 Jul 2013 01:30 #36287
by tommy
So, I ran trough all buttons, if they have correct addresses and noticed that for Macro-2 is not 08 but 0B, probably my attached picture was a bit to small and hard to read ... all the rest is OK! So this version of device should be now fully functional under linuxcnc!
I was checking wrong ini...You will need to delete erroneous lines in xhc-hb04.hal because there are no X=0, Y=0 and Z=0 buttons on your MPG.
Frederic.
04 Jul 2013 02:37 #36289
by f1oat
Thank you for the report. That is a very good news !
Frederic.
Frederic.
04 Jul 2013 02:50 #36290
by f1oat
Yes, good suggestion. I have not chosen this option because I was not sure about the number of bits used for button coding on all MPG we can find on the market. I have implemented 8 bits, so 256 potential buttons. Lets wait for users feedbacks to see if only 4 bits are used !
Frederic.
Frederic.
04 Jul 2013 05:11 #36293
by f1oat
@andypugh: thanks, puma config has been useful for solving the issue
@tommy: I have uploaded V04 with support for world mode. You will find a dedicated .hal file. Please, be careful with this new release because I have not been able to test on a real machine !
Frederic.
Frederic.
04 Jul 2013 15:06 #36299
by tommy
I have tested it, and jog in world mode is very nonlinear, like it would be loosing steps from jog wheel.
Frederic.
Time to create page: 0.360 seconds
