VMC related HAL questions.
26 May 2015 08:14 #59054
Ok, that sounds like a torque-mode system.
Rather than repeat stuff:
www.gnipsel.com/linuxcnc/tuning/torque.html
But let us know how that works for you, maybe your experience can expand that.
Replied by andypugh on topic VMC related HAL questions.
Encoders go back to the MESA card. If I were using brushless motors then hall sensors would go to the amps only.
- sspeed33317
01 Jun 2015 10:38 #59293
by sspeed33317
Replied by sspeed33317 on topic VMC related HAL questions.
Been working a lot lately and l i finally made it over to the workshop, pulled the computer and all my MESA stuff to bring back home.
Reinstalled LinuxCNC with the latest updates. And now I may be moving workshops again... and then next Wednesday the 10th of June I am heading
over to your side of the pond Andy. Coming over for the 24 Hour LeMans..
I am hoping i can get to work on it when i get back but I may be putting all of my stuff in a storage unit for a little while until I can find
a smaller shop. the rent has been a killer and i was hoping to be able to get a garage built but the $$ has been slow coming.
I am going to set up the controls at home and then bring the whole thing to the machine when its ready.
- sspeed33317
02 Jun 2015 08:40 - 02 Jun 2015 09:23 #59325
by sspeed33317
Having a slight problem.. getting an error when opening the VMC simulator.
I believe i followed your instructions to install the carousel comp.
But it doesn't look like it went to the correct directory
Was trying to attach the error file.. seems i got it to upload..
Last edit: 02 Jun 2015 09:23 by sspeed33317.
02 Jun 2015 16:20 #59336
No, it appears not "toolchange.hal:1: Can't find module 'carousel' in /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc"
Can you paste the output of(Or sudo halcompile... if using a development LinuxCNC version)
If it doesn't end with a cp... command then something hasn't quite worked.
sudo comp --install --install-doc carousel.comp
- sspeed33317
02 Jun 2015 21:55 - 03 Jun 2015 09:04 #59346
by sspeed33317
I got it !!!...
i did a lot of searching ...
i finally found your post 58057
followed the way it was done there and it worked ....
I was way off on the procedure.
Last edit: 03 Jun 2015 09:04 by sspeed33317.
05 Jun 2015 18:32 #59472
by thewho
Replied by thewho on topic VMC related HAL questions.
Well I finally had a go at the closed loop spindle control you helped me with.
I didn't really know what I was doing so I'll attach the files if you Andy or someone else have the time to take a look at them?
One thing, I have a +/-10V drive so there i no need for the fwd/rev outputs. I just commented those lines but I might have to edit something else to?
05 Jun 2015 21:28 #59480
You have
You need to un-comment the loadrt mux2, as I don't think you have that loaded elsewhere.
This needs to beTo send the bipolar speed command to the analogout.
loadrt orient addf orient.0 servo-thread #loadrt mux2 -- This has already been loaded in the sim_vmc.hal addf mux2.0 servo-thread # chooses which pid output goes to the spindle speed control
#for a real spindle run by a VFD loadrt abs addf abs.0.servo-thread net spindle-cmd mux2.0.out abs.0.in net spindle-cmd-abs hm2_5i25.0.7i77.0.1.analogout5 #net spindle-fwd abs.0.is-positive parport.0.pin-NN-out #net spindle-rev abs.0.is-negative parport.0.pin-NN-out
This needs to be
net spindle-cmd mux2.0.out hm2_5i25.0.7i77.0.1.analogout5
05 Jun 2015 22:14 #59485
by thewho
Like this?
loadrt abs
05 Jun 2015 22:21 #59486
No...
Replace the entire section I quoted with the single replacement line.
Like this?
#for a real spindle run by a VFD loadrt abs addf abs.0.servo-thread net spindle-cmd mux2.0.out hm2_5i25.0.7i77.0.1.analogout5 net spindle-cmd-abs hm2_5i25.0.7i77.0.1.analogout5
No...
05 Jun 2015 22:52 - 05 Jun 2015 23:29 #59488
by thewho
Oh, when reading your message again it seems quite obvious
Tried it in the machine but I see no change in behavior. I did not get any errors at startup.
Tried a M3 S100 but It doesn't compensate at all? Am I missing something here?
M33.1 Does not do anything ether.
EDIT: Oh wait, I´m stupid.. Did get an error though
EDIT2:
EDIT2:
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/pid.ko: File exists
spindle.hal:1: exit value: 1
spindle.hal:1: insmod failed, returned -1
See the output of 'dmesg' for more information.
4364
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Last edit: 05 Jun 2015 23:29 by thewho.
Time to create page: 0.139 seconds
