yalang yl620 VFD rs485/modbus communicaiton
13 Aug 2022 17:14 #249664
by DavidE
Replied by DavidE on topic yalang yl620 VFD rs485/modbus communicaiton
OK got it working. Cleared all the configs, started again. Used Classic ladder this time and it worked first try.
29 Mar 2023 07:39 #267777
by Funny
Replied by Funny on topic yalang yl620 VFD rs485/modbus communicaiton
Take a look at this
10 Apr 2023 14:54 - 10 Apr 2023 14:56 #268756
by phil_irl
Replied by phil_irl on topic yalang yl620 VFD rs485/modbus communicaiton
Not sure if this is the correct topic to ask this, or whether I should post it in the VFDmod thread at:
forum.linuxcnc.org/24-hal-components/387...trol-over-modbus-rtu.
I'm a noob LinuxCNC setting up for the first time and want to control my 220V 2.2kW 400Hz water cooled spindle over rs485 modbus.
I have installed VFDmod (as per instructions at github.com/aekhv/vfdmod), and then proceeded with the instructions given on xsnoopy's yalang yl620 VFD rs485 modbus page at:-
github.com/xsnoopy/LinuxCNC-Yalang-yl620...s485-Modbus---VFDmod
and also changed my VFD settings as instructed, but LinuxCNC errors out with:
Last edit: 10 Apr 2023 14:56 by phil_irl.
10 Apr 2023 15:23 #268757
Replied by andypugh on topic yalang yl620 VFD rs485/modbus communicaiton
Which groups is your user a member of? You might need to be part of "dialout" to access the serial port.
Maybe a solution here: askubuntu.com/questions/210177/serial-po...s0-permission-denied
The following user(s) said Thank You: phil_irl
11 Apr 2023 15:31 #268830
by phil_irl
Thanks Andy, adding the user to the "dialout" and "tty" groups fixed the problem.
Next problem: It's now erroring out with:
"pyvcp_options.hal:8: Pin 'pyvcp.spindle-speed' does not exist."
I imagine there's a simple fix, but I don't want to break anything by randomly applying my own fixes! Any help/suggestions are welcome.
Phil.
Phil.
11 Apr 2023 17:15 #268833
by phil_irl
Ignore my last message - after a bit more fiddling around (setting up a fresh mill configuration in StepConf) it all seems to work now! Fingers crossed.
16 Apr 2023 09:34 #269201
by phil_irl
Just a quick addendum for anyone setting up an RS485 Modbus PC->VFD link: I found it necessary to add a 120 Ohm resistor to both ends of my screened twisted pair cable. Without the resistors, LinuxCNC doesn't always see the RS485 connection and throws a error. As soon as I added the resistors, the connection was stable.
More here: www.analog.com/en/technical-articles/rs4...axim-integrated.html
- handsomebeast
- Thank you received: 3
26 Aug 2023 08:53 - 26 Aug 2023 08:55 #279001
by handsomebeast
Replied by handsomebeast on topic yalang yl620 VFD rs485/modbus communicaiton
hey david can you post your files that you used to get this working as ive done a fresh config with stepconf using classicladder but the pyvcp panel doesnt respond, the gauge doesnt move and the spindle at speed and rs485 indicator are red so i dont know what the problem is but i get a stable modbus connection to the vfd and can run and stop the spindle with the plus and minus buttons in axis gui,
Last edit: 26 Aug 2023 08:55 by handsomebeast.
08 Feb 2024 18:23 - 08 Feb 2024 18:27 #292868
by Funny
Last edit: 08 Feb 2024 18:27 by Funny.
Time to create page: 0.176 seconds
