M4 doesn't work
15 Sep 2023 15:58 #280861 by AlexMagToast
Replied by AlexMagToast on topic M4 doesn't work
ah, nice thanks.
Here is the spindle.txt
15 Sep 2023 16:11 - 15 Sep 2023 16:13 #280862 by Aciera
Replied by Aciera on topic M4 doesn't work
10 bit IN TRUE halui.spindle.0.override.count-enable
10 s32 IN 0 halui.spindle.0.override.counts <== SpindleOverride
Looks like you have your override active and turned all the way down which is like issuing
M4 S0
This will not activate spindle.0.on but it will activate halui.spindle.0.runs-backward.
Last edit: 15 Sep 2023 16:13 by Aciera.
The following user(s) said Thank You: AlexMagToast
15 Sep 2023 16:13 #280863 by PCW
Replied by PCW on topic M4 doesn't work
Not sure what the issue is but I still suspect something with halui
Basic spindle operation is as expected in 2.10:
M3:
File Name: m3.txt
File Size:1 KB
M4:
File Name: m4.txt
File Size:1 KB
15 Sep 2023 16:14 #280864 by AlexMagToast
yes, i've seen this too. I think thats a clue :P
15 Sep 2023 16:17 - 15 Sep 2023 16:21 #280865 by Aciera
Maybe check the value of this signal when you issue M4 S...:
net SpindleOverride <= halui.spindle.0.override.counts <= arduino.lpoti.1.out
[edit]
Actually, if you are using a potentiometer then you may want to use halui.spindle.0.override.direct-value rather than .counts which would probably be used with an encoder.
Last edit: 15 Sep 2023 16:21 by Aciera.
15 Sep 2023 16:30 #280866 by AlexMagToast
Thanks for the suggestions. I've had a closer look at it and i conclude, i don't think this is the root of the issue.
I've made a short Video to show you:
15 Sep 2023 17:39 - 15 Sep 2023 17:39 #280870 by Aciera
So basically the issue seems to be that the M4 S.. command turns into M4 S0 which gives me the same behavior on an axis simulation config.
I presume that you have tried M4 S100 in a simulation config and checked the value of spindle.0.speed-out.
If that works then I'm afraid the only strategy I can think of is to start with a new config and add things step by step to find out what actually breaks the M4 functionality.
Last edit: 15 Sep 2023 17:39 by Aciera.
15 Sep 2023 17:47 #280871 by AlexMagToast
I now opened the standard sim axis and indeed M4 S100 works as expected.
I kind of tried to start with a new conifg by loading the first commit in my Git repo.
However nothing changed....
Unfortunately i too have the feeling, it is something with my config and or my machine, not a LinuxCNC Bug.
15 Sep 2023 18:00 #280872 by Aciera
Fortunately for everybody else, that is likely the case. Although I'd sure like to know what is going on there.
15 Sep 2023 18:22 - 15 Sep 2023 18:23 #280876 by AlexMagToast
So i now i created a new machine configuration using Pncconf. If i set a stepgen for the Spindle output it breaks M4.
When i edit the same config with Pncconf again and rempve the Spindle from the Stepgen, M4 works again.
Can somebody else confirm?
Last edit: 15 Sep 2023 18:23 by AlexMagToast. Reason: misspelled smtg
Time to create page: 0.126 seconds
