M4 doesn't work
15 Sep 2023 19:09 #280880
Replied by PCW on topic M4 doesn't work
Yes I see that also, I think it may have to do with AXIS's spindle override
My (Axis) config (that works with M4) doesn't show the spindle override
- AlexMagToast
- Topic Author
- Thank you received: 66
15 Sep 2023 19:34 #280881
by AlexMagToast
Replied by AlexMagToast on topic M4 doesn't work
Update:
I asked a friend who owns the same Motor & Mesa card to send me his hal and ini files and after changing parameters to run on my machine, now M4 works even with stepgen. I will now try to figure out the difference.
15 Sep 2023 19:58 #280884
The following user(s) said Thank You: AlexMagToast
- AlexMagToast
- Topic Author
15 Sep 2023 19:59 - 15 Sep 2023 21:01 #280885
by AlexMagToast
Update 2:
I have now cut out the Spindle part out of his config. It contains some features, i don't need, such as Spindle Orient, so the change is not yet obvious to me.
However M3 & M4 works now.
I have no clue why....
If you would like to see, you can see the changes in the Git repo: github.com/AlexmagToast/WeilerPrimusCNC_...7a15b5beab3fa986eb50
I am still working on it to bring it back to output the correct Speed, but the basic functionality is there.
Thanks to everyone participating in this thread!
Last edit: 15 Sep 2023 21:01 by AlexMagToast.
15 Sep 2023 20:36 - 15 Sep 2023 20:39 #280886
Changing the spindle section of the ini file to include
the reverse velocity settings seems to fix the issue with M4
The default value of the reverse settings are supposed to be the
same as the forward settings but it appears this is not the case.
[SPINDLE_0]
MAX_VELOCITY = 2000.0 # or whatever
MIN_VELOCITY = 0.0
MAX_REVERSE_VELOCITY = 2000.0
MIN_REVERSE_VELOCITY = 0.0
[SPINDLE_0]
MIN_VELOCITY = 0.0
Last edit: 15 Sep 2023 20:39 by PCW.
- AlexMagToast
- Topic Author
15 Sep 2023 21:10 #280890
by AlexMagToast
@PCW Can confirm!
This fixes it indeed. Thank you
Time to create page: 0.080 seconds
