M4 doesn't work
- AlexMagToast
- Topic Author
- Thank you received: 66
14 Sep 2023 19:04 #280764
by AlexMagToast
M4 doesn't work was created by AlexMagToast
I am running out of ideas, so i decidet to ask here for help. The issue is, that LinuxCNC is not running M4 commands.
My setup is a 7i95 and a Servo Motor for the Spindle, which is controlled by a quadrature signal.
The motor works, i can send M3 S... commands and they are executed, Speed is correct.
However, when i send M4 S... commands, the spindle stops and nothing happens.
I know, the motor works. Flipping the direction also works by inverting the step_scale in ini and exchanging the A B signals of the quadrature signal.
Looking in the HAL i can see with M3 halui.spindle.0.is-on, halui.spindle.0.runs-forward, spindle.0.forward, spindle.0.on is all turned on.
with M4 only halui.spindle.0.runs-backward is turned on.
In the Forum i found this thread, which experiences pretty much the same behavior, however i am running on AXIS and i don't think i have the same issue.
Here is my complete Setup: github.com/AlexmagToast/WeilerPrimusCNC_LinuxCNC_config
Thanks in Advance,
Alex
Thanks in Advance,
Alex
- AlexMagToast
- Topic Author
14 Sep 2023 19:06 #280765
by AlexMagToast
Replied by AlexMagToast on topic M4 doesn't work
Forgot to paste the link to the Thread:
forum.linuxcnc.org/gmoccapy/36200-spindle-ccw-hanging
14 Sep 2023 21:17 #280785
by chris@cnc
Replied by chris@cnc on topic M4 doesn't work
What happens in these lines?
net spindle-manual-cw halui.spindle.0.forward <= arduino.din.46
net spindle-cw => arduino.dled.2
net spindle-manual-ccw halui.spindle.0.reverse <= arduino.din.42
net spindle-ccw => arduino.dled.0
net spindle-manual-stop halui.spindle.0.stop <= arduino.din.44
Usually should pin spindle.0.on go high in case of M3 and M4.
- AlexMagToast
- Topic Author
14 Sep 2023 21:52 #280790
by AlexMagToast
these are Hardware Buttons to start and stop the Spindle with an LED inside that lights up depending on the State.
Yes, thats what i am thinking too. Maybe i stubled on a Bug. Im currently running a 1.9pre Version.
15 Sep 2023 00:08 #280796
Replied by PCW on topic M4 doesn't work
As chris@cnc suggested, maybe something in halui or the user
interface is preventing M4 from working properly.
I would run LinuxCNC, issue a mdi m4 s100 and post the results of
halcmd show pin spindle*
The following user(s) said Thank You: AlexMagToast
- AlexMagToast
- Topic Author
15 Sep 2023 11:12 #280827
by AlexMagToast
Here are the results in the attachment:
15 Sep 2023 15:10 - 15 Sep 2023 15:24 #280855
Replied by Aciera on topic M4 doesn't work
Maybe have a look at these pins in halscope when issuing M4 S...:
Also commenting the lines that use the above pins and try MDI command M4 S... may give you some clue as to what is going on.
[edit]
Just to be on the same page, if you comment out these lines in your hal, does MDI m4 S... work or not?
[edit]
Last edit: 15 Sep 2023 15:24 by Aciera.
15 Sep 2023 15:15 #280856
Look like something is preventing M4 from working, maybe need to look at all spindle related pins/signals
halcmd show all | grep spindle > spindle.txt
and post spindle.txt here
- AlexMagToast
- Topic Author
15 Sep 2023 15:43 #280858
by AlexMagToast
Thanks for your suggestions.
@Aciera even with the lines fully commented out, nothing changes in the behaviour. so : no work.
@PCW how do i run this command?
i selected every spindle pin in halshow and append a screenshot here, this is after M4 S100 was issued.
now i have also upgraded to Linuxcnc 2.10.0. pre0, but the issue remains.
Again thanks for your help, guys!
-Alex
-Alex
15 Sep 2023 15:48 #280859
Run / start linuxcnc and issue a m4 s100
then in a terminal window, type
Time to create page: 0.272 seconds
