Classicladder turret change help
07 Oct 2012 03:38 #25092
by LAIR82
Replied by LAIR82 on topic Re:Classicladder turret change help
Yes my turret is hydraulicly controlled. The position is determined by the 3 limit switches, BCD-1, BCD-2, and BCD-4 through a truth table.
When I get to work monday I will clean up my file and post a copy of my work.
08 Oct 2012 03:27 #25112
by jlviloria
Replied by jlviloria on topic Re:Classicladder turret change help
Hello Rick.
I have some concerns about your project.
1. using the servo motor and servo drives siemens original?
2. that references are servo drives and servo motor?
3. motor and spindle drives are Reliance? vector max plus?
4. I have no information of the hydraulic system, I can provide assistance on this part? please
this for now. jjejeje
thanks
thanks
08 Oct 2012 21:57 #25143
by jlviloria
Rick,
Too bad it bother you that you had problems with your PC, but please do not forget me.
thanks in advance
thanks in advance
08 Oct 2012 22:06 #25144
by LAIR82
Sorry I did not get back to you today Jorge, major problems on my end with some self generated software issues, regardless I will get you something tomorrow.
Rick
Rick
09 Oct 2012 00:59 #25154
by LAIR82
Hey Jorge,
I know offhand that,
1. using the servo motor and servo drives siemens original? Yes We are using the original servos and drives with resolver feedback on X,Z and the spindle
3. motor and spindle drives are Reliance? vector max plus? No the DC motor was bad so we just upgraded to an Automation Direct Durapulse 40hp drive
with a 40hp Baldor vector w/encoder feedback motor
4. I have no information of the hydraulic system, I can provide assistance on this part? please Yes we are still using the original Cincinnati hydraulic unit.
What is the model # of the machine you are retro-fitting?
09 Oct 2012 02:41 #25156
by jlviloria
Rick,
my lathe is:
Model: 12C CINTURN
SERIES: 1412
Model: AE
serial: 5340C12-88-054
YEAR: 1988
VOLTS: 460CA
60Hz
www.linuxcnc.org/index.php/english/compo...ew&catid=38&id=23023
my friend's reference drives are 6RB2030 for two axes.
I mean it does not work maxpakplus vector drive for retrofit? That would be bad news.
Friend You let everything and came back to do all the wiring?
friend a photo to see the machine would be excellent.
friend please advice in connecting the drives and encoder.
Thanks Rick I hope you can solve your problem.
my lathe is:
Model: 12C CINTURN
SERIES: 1412
Model: AE
YEAR: 1988
VOLTS: 460CA
60Hz
09 Oct 2012 20:56 #25185
by jlviloria
Rick
friend do not forget the old jorge!
and did nothing to set the gearchange?
I am aware of any help I can provide.
thanks in advance.
Jorge Viloria
thanks in advance.
Jorge Viloria
09 Oct 2012 22:09 #25189
by LAIR82
Hey Jorge,
Sorry buddy,
Yes in fact I have setup the gearchange component for our 2 speed transmission on the spindle. I had to set up some custom M codes (m141, m142) to be able to be used in the nc programs. I will try to find the info on creating custom m codes. I think there is some info in the integrator manual.
I had a machining center spindle drive go down today, on top of my resolver issues we are trying to iron out.
I will try my hardest to get you some info/logic tomorrow. I'm still working on my machining center drive issue. Gets a little hectic with just me looking after 7 turning centers and 5 machining centers.
Sorry buddy,
10 Oct 2012 00:02 #25194
by BigJohnT
Replied by BigJohnT on topic Re:Classicladder turret change help
Now I understand why Old No 7 is your profile photo...
10 Oct 2012 20:00 #25222
by jlviloria
Rick.
Friend ..
apology ... I wear it more tiring than ugly girlfriend.
but do not forget about me ... I have a question regarding the HAL, when you put in:
# External output signals
# net spindle-low-range-sun <== hm2_5i23.0.7i71.0.3.output-00
# Net ....
So are comments?
or actually connected with HAL
thanks.
Jorge Viloria
Friend ..
# Net ....
So are comments?
thanks.
Jorge Viloria
Time to create page: 0.146 seconds
